NewZed
72
Everything posted by NewZed
It says the first 1000 miles is critically important. Which is the regime the OP is in right now. It doesn't look like you've been keeping up with cam and rocker damage horror stories.
You should give numbers. Timing, fuel pressure, pretty much anything that can be quantified. And what does timing do when you rev the engine.? Does it advance? Valve lash is easy to check, even if you don't adjust it. Turn engine, stick in feeler gauges, write down numbers.
Some places say they have NOS. http://nissan.dealerdirectparts.com/Nissan-Part-number-54320-N3701-p/54320-n3701.htm http://www.carpartsmanual.com/datsun/Z-1969-1978/axle/rear-suspension/9
Describe "factory run-in". From 1981. Use details.
Transmission crossmember frame nut possibly crossthreaded?
NewZed replied to Stunt's topic in S30 Series - 240z, 260z, 280z
People have had your problem. You just need to find the nut from inside the car and replace it if you can't fix it from below. -
All of the ideas are out there. You've shown that the driveshaft is not firmly connected to the engine or the rear wheels. It seems to be spinning in space. The car should not have moved at all before the axles twisted, from what you've shown in your videos.
Aren't you screwed right now? You'll be in the same state, but at least you'll have tried something. http://www.carpartsmanual.com/datsun/Z-1969-1978/engine-240z-260z/engine-mounting/manual-from-c-hls30-46001-rls30-grls30 -
So, basically you're saying that you have a freshly built engine that has not been broken in. The main worry then would be the camshaft lobes and rocker arms. Zinc (ZDDP) seems to be key. There are a variety of break-in oils out there. VR1 racing oil seems to be popular, as one, for example. Not designated as a break-in oil but it's an older ZDDP containing formulation. People have had issues with using a non-zinc oil with added ZDDP break-in additive. Probably best to find a zinc-containing break-in oil. Brad Penn is a brand that seems popular. http://www.valvoline.com/our-products/motor-oil/vr1-racing-oil https://www.summitracing.com/parts/bpo-009-7120 http://www.competitionproducts.com/Brad-Penn-PENN-GRADE-1-Break-In-Oil-30W-Quart/productinfo/BPO30WTQT/#.V42S89IrKig Read up on failed camshaft swaps and you'll find many opinions but getting an oil with the ZDDP already formulated in seems like a good idea.
Your second video here is where it would have been informative if you could have had somebody press the brake pedal while the engine was running. You had video of the pinion shaft moving and the halfshafts. Pressing the brake pedal would have stopped the wheel flanges. Then things would have been clear, either both halfsahfts would have stopped and the pinion shaft kept spinning or only one of the halfshafts would have stopped.. The advice to remove the diff was a little premature, you were right on the edge of getting some good information..
Here's the original - http://forums.hybridz.org/topic/5380-broken-stub-axle-danger/
Here's another from a guy who broke his just tightening the nut. http://www.classiczcars.com/forums/topic/42487-rear-stub-axle-just-broke-when-tried-to-torque-nut/
Nice. Here's a link on how the 240Z's break their axles. It's titled "STUB AXLE FAILURE". About halfway down the first page here - http://forums.hybridz.org/topic/49194-differential-cv-lsd-hp-torque-r160-r180-r200-r230-diff-mount/
Here's a thought, that might be feasible - you have a broken stub axle in a wheel hub.The bearings will hold the wheel on, sitting in the garage. See if you can turn the wheel companion flanges at the hubs, without the wheel turning. This would let all of the things you've seen happen, without the car moving. It would be like lifting one wheel in a corner. The diffs need both wheels to have some resistance to motion for the diff to work right.
This is a very strange thread. You're not using some sort of odd two-piece splined driveshaft are you? You had a video of the transmission end of the driveshaft but not the pinion flange end. It's still not clear that the pinion shaft of the diff will turn without at least one of the stub axles turning. You have something missing in all of your descriptions and videos, either the wheels are up or the video doesn't show the right parts. If you could clamp the two stub axles in a large vise and use a wrench on the pinion flange you'd be able to tell if the diff is broken. If the diff is broken you should be able to turn the pinion shaft more than you described. "the pinion gear was turning for a brief period". You found a piece of a clip inside? Take some pictures. Down the spider gear holes and from the back. Bright lights, in focus. Take a video from the back with the cover off as you turn the pinion shaft. Lock the stub shafts down somehow and use a wrench to turn the pinion shaft. Something must be broken but it will take someone familiar with broken diffs to know. This should be a simple thing to figure out. Don't make it complicated. Your sig says "LS1" but your video shows an L6.
I think that your clutch is either slipping or stuck in the disengaged position. It's the link between your engine and transmission. With the car on stands there's enough drag to turn the driveshaft and wheels. With the wheels stopped by the ground,it slips. Check your clutch fork first to see if it's stuck pressed backward. If the clutch is jammed open though, the clutch pedal will require very little pressure to move. The slave cylinder rod will be extended. If it's not the clutch, then it's the transmission. Nice sounding engine. Must be a bummer to have it stuck in the garage.
Are the halfshafts still disconnected? If the car is up on stands, put the stub axles back in and put the transmission in gear. Crawl underneath, grab both stub axle flanges at the same time and see if you can turn them the same direction. It's sounding like you will be able to turn them and you have a problem with the splines or your spider gears. You may have broken somehtng when you were trying to pound the old twisted shafts in. The problem you're having in this thread is that you're reporting two contradictory things at the same time. You say the wheels turn when they're up, but they don't turn when they're loaded, on the ground. But you haven't confirmed that the driveshaft is turning when the wheels aren't. That's the key to knowing where to look. Is the main, center, driveshaft turning when the wheels (stub axles) aren't?
Grammar? You only have three topics and they're all unlocked. Must be someone else's thread.
They being ..... what? The stub axles or all three? You didn't say if the parking brake was on while it was on the stands. That would lock the wheels. You're trying to determine if the axles are mechanically attached, via the splines, to the spider gears. It's not clear what didn't turn while the car was on the ground. You said "they" instead of actually using the words. The wheels could turn just from viscous drag of the gear lube, that's why you need to lock the wheels with the parking brake. Look inside the diff holes and see the splines. They interlock with the splines on your new axles. The clips just stop the axles from sliding back out fo the hole. http://mech.sharif.ir/~durali/design/Shafting/details/Lecture%2020.pdf http://www.4x4abc.com/4WD101/diff.html
The driveshaft turns but neither wheel does? You're sure the stub axles are not turning? You didn't do something weird like forget to put the halfshaft flange bolts in? You can put the stub axles in the wrong sides but I think that just turns the LSD in to an open in the worst case, like with a VLSD. Not sure what it would do to the Subie CLSD. You have an odd problem if the main pinion shaft of the diff (connected to the driveshaft aka propeller shaft) turns but neither output shaft (stub axle) does. Could be that the splined section of your axles is too small and they're actually stuck in the diff by the seal area. I'm just making a WAG. Pull the axles and confirm that the inner splines turn is the next option.
Is my 1973 240z an origional scarab?
NewZed replied to nicholas1122459's topic in Gen I & II Chevy V8 Tech Board
What did you read? No use suggesting things you've already looked at. -
Put it back on the jack stands, put the transmission in neutral, apply the parking brake, crawl underneath, grab the driveshaft and turn it. Does the drivehaft turn freely? If not, the problems on the front end, not the part you just worked on. Or just watch the driveshaft while you have it in gear with the engine running. If it's turning, the problems in the back, if it's not it's up front.
How to measure ride height?
NewZed replied to ZMONSTR's topic in Brakes, Wheels, Suspension and Chassis
Should have put your "real question" in the title. Your car is not super low now and you want the same stance. So regular springs should put you in the middle of the coilover adjustment range. "Super low" means slammed. -
I found some images of Nissan versus aftermarket lash pads and see that Nissan cut grooves inside the seat area for the tip. Aftermarket is flat. So the groove is just "normal" wear. Still kind of wondering how the rockers got on the engine. Is it a Rebello engine? He recommended used Nissan but went with reground used Nissan. Just seems inconsistent. Didn't offer to repair their error either. He's seen it before so knows about it. Seems like they should have owned it. Anyway, good luck with it.
Looks like the Paraut symbol. I just picked this image off the interweb. Paraut was/is, apparently, an indirect OEM for Nissan. Paraut/Atsugi/Nissan, something like that. http://www.elautoparts.com/item.wws?sku=A4040-51981&itempk=86615&mfr=Paraut&weight=0.20 The wear on the other end of the arm is interesting. Isn't the tip supposed to fit inside the lash pad? Shouldn't it be worn across the full face? Looks like it's sitting on top of something else and it's worn a groove.
