My not so Fairlady Z...VH Swap
Hey fella's,
I'd like to introduce myself and my project. I am transforming my 1990 Nissan 300ZX N/A from completely stock to a VH45 monster. I plan on having this car my model car for the custom VH parts I am selling. Custom parts that I have already designed are: intake flanges, engine mounts, and throttle body plates. I am still working on the oil pan flange as well as the custom intake manifold and transmission adapter plate. I also have some other odd's-n-ends on my website.
Engine:
'91 VH45DE rebuilt to stock specs
PerformanceVH Z32 Engine Mount Kit
PerformanceVH Intake Manifold
Custom Top Feed Fuel Rail
36# (370cc) Bosch Injectors
PerformanceVH Rear Sump Oil Pan
Custom Headers
Trans:
'90 Z32 N/A 5-Speed
Chromoly Lightweight Flywheel
Short-Throw Shifter
Brakes:
SRT-8 Front Brembo Calipers
SRT-8 Steel Braided Hoses
370Z Nismo Front Rotors
370Z Nismo Rear Rotors
N/A Front Calipers adapted to Rear
Suspension:
Urethane Bushings
Powertrix SS Coilovers
Powertrix Adjustable Arm Kit
Exterior:
Wingswest Front Urethane Bumper
TBO Sideskirts
TwinZ Type II Rear Bumper
TwinZ Roof Spoiler
Winfactory CSL-R Spoiler
Night Garage Style Rear Fender Flares
Wheels: Varrstoen 2.2.1. Matte Black
Front: 18x9.5
Rear: 18x10.5
That's just a small parts list off the top of my head. Here are some pictures of my progress so far.
  • Replies 106
Removed the rear subframe today, getting ready for a complete overhaul. Ordering the energy suspension master kit, saving up for Powertrix's lovely N/A rear arms kit. Take the diff. cover off and take some measurements. Stitch weld the subframe, powder coat, and throw her back in... eventually! Swapping out the N/A diff for a Q45, along with the axles, and hubs. I'm pretty sure I'll have to use a Z32 TT driveshaft.
TwinZ Type II Bumper Test Fit!
I also disassembled my SRT-8 front brembo calipers so they can get powder coated.
Test fit the front wheels with the brake calipers bolted up. I have to space the wheel out 5mm to get the spokes to clear the caliper. Still will be able to keep the stock fenders without modification or camber. Just a slightly narrower tire. I'll get some Nismo wheel studs then.
Next I'm going to start disassembling the rear subframe.
So sad. Not only does this "other V8" section get very little traffic, but Z32 stuff doesn't get much attention either!
I'm sure 90% of us think this project is awesome, so don't feel like we don't love what you're doing!!! Keep the updates rolling.
Thank's mate, I think there should be a Nissan engine section for "pure bred" Z's lol not just "others"
It doesn't bother me any though, no worries, more updates to come! Right now I'm knee deep in refurbishing the rear subframe assembly, Swapping in a 97 Q45 rear diff (3.69) All new suspension arms, poly bushings replacing every piece of rubber. Also moving my front calipers to the rear to clamp down on some 370z Nismo rotors. More pictures soon!
Update!
Got all the rubber bushings pushed out of the spindles, rear sub frame, and the arms I'm going to be reusing. Sending everything out to be powdercoated this week. Got some misc brackets back from powdercoating as well. Once I have everything back I can get the front and rear suspension back together. Then off to my buddies bodyshop to finish shaving the engine bay and paint!
778835_10151435240938829_1067865498_o.jp
337658_10151440547868829_1279845091_o.jp
Well this weekend I was able to get the passenger side wheel well refinished and undercoated, also made some progress with the engine bay. Removing paint, and rust. Got all the rust removed and surfaces treated. Just have to remove a little more paint on the firewall and the engine bay will be ready for paint!
It's such a tedious process! I can't wait until the body work is done!
Thanks guys! Got more progress made this weekend. Engine bay is 99% complete. Just need to finish the lower radiator support. Got the driver side wheel well treated and painted. Used a can of Eastwood internal frame coating on the passenger side frame rail, have to re-weld the frame rail since the rust has been treated.
Got the solid rear bushings installed on the subframe, and installed the diff. More pictures soon! Got my WW urethane bumper in today! So excited to get home and unwrap it! The Z is soon ready to be hauled off to the bodyshop!
Updates:
Solid diff. bushings installed
Y33 w/ Z32 yoke diff. installed
Godspeed Suspension Arms
Stillen Sway Bar
Every bushing replaced ES. Bushings
New lower ball joints
Got my Wings West Urethane bumper in today. Just waiting on the TwinZ roof spoiler, then I will have all the exterior pieces.
Next, bolt the suspension back on, sit the engine in, mock up the rear sump oil pan...
I installed the mock up block in the car again to get measurements for the oil pan. I was able to keep a quart capacity of 5.5 without dropping below the sub-frame, and leaving plenty of space for exhaust.
I got everything drawn up last night and ready for production!
59751_217343095074972_829249522_n_zps8c4
  • 3 weeks later...
Sorry, moved those pictures... Here are the updated links
Quick update:
Wheel spacers came in today for the rear.
Well, I finally got the flat patterns in for the oil pan! No time to waste! Start welding!
Made some more progress on the pan tonight.
Edited by PerformanceVH
