jhm Posted August 3, 2023 Share Posted August 3, 2023 Oh man….that’s a huge bummer, Ben. Glad you’re ok, and the underlying structure’s ok — but it’s still a bummer to see. How long are you expecting repairs to take? Curious what kind of dyno was used? Glad to hear you’re happy with the new motor. Don’t hesitate to ask if you’re needing bits & pieces for the rework. Quote Link to comment Share on other sites More sharing options...
Ben280 Posted August 3, 2023 Author Share Posted August 3, 2023 PRE uses a Dynojet. Can't remember if those are supposed to read high or low, but it's a good metric if you always use the same one! I'd have liked a bit more power, but I think ~400hp is more than enough to get into trouble. (clearly!) So far the repairs are minor, and the trick has been sourcing panels. A PNW local reached out and had a set of fenders and headlight buckets he sold me for a song, and I'm taking a trek up north on Saturday to pick up a new hood. I think the airdam is mostly savable, but the old headlight covers and flares are toast. Working to get a new set of flares from Japan, and another instagram follower was super kind and sent me some replacement headlight covers! Planning to have the car back out August 19/20 at ORP. We'll have some crazy mis-matched body work and a plywood splitter, but I think we should be in decent shape for continuing to shake the car down! Quote Link to comment Share on other sites More sharing options...
Ben280 Posted August 3, 2023 Author Share Posted August 3, 2023 As a side note, if anyone wants to support myself and the car, check out this sticker pack from my BFF Jake at Aerowolf https://www.aerowolfusa.com/products/team-stickerpack Quote Link to comment Share on other sites More sharing options...
Ben280 Posted April 23, 2024 Author Share Posted April 23, 2024 Hi HybridZ universe! Been taking a break from the car for a bit, but starting to get more motivated here. Let's do our quick catch up first. ORP was an interesting event. We had positives, but the issue that wrecked the car in July surfaced it's head again. Turns out the ABS was overpowering the master cylinder seals on the front circuit and causing massive pressure losses. I had more pronounced but less consequential failure out there, but had good data to show what was wrong. I got my hands on some Tilton Type 79 master cylinders, developed specifically for the Audi LeMans teams who were seeing a similar failure in their master cylinders. I also had to upgrade the pedal box as these are bearing mount master cylinders. The plan was to run the car again at PIR, but that event ended up getting canceled, and so the car has sat since September. Slowly getting poked at, and trying to figure out where I wanted things to go. I made some aero mods to the fenders, and have been slowly cleaning up the firewall and some other areas. The big change I'm in the middle of here is with my ECU. I'm ditching the megasquirt and going Haltech. The LS never really ran right on the megasquirt, and when I started seeing some odd stuff starting it up for the first time this year, that was all the impetus I needed to ditch that. It'll be for sale shortly, expect to see it soon. Hoping to get to an event this year with the car, but really not sure when or where. For now, here's where we sit. I put it down on the ground for the first time since August last year. 1 Quote Link to comment Share on other sites More sharing options...
Ben280 Posted December 19, 2024 Author Share Posted December 19, 2024 Howdy HybridZ! Seems like the trend, y'all get an update at the beginning of the year and at the end of the year! Might need to reframe my temporal perspective and do every 6 months. This was a slow year for the car and myself. First year since I've owned the car that it hasn't gone to any events! Wish I could say it was because I was doing a bunch of sweet mods and we're hitting the track hard next year, but that's not how it went. Overall, since 2020, the "smiles per $" has been way down, and I think I probably burnt myself out doing the V8 swap as quickly as I did it. Combined with the wreck, I felt like I really needed to step back, re-evaluate and take the year off to figure out how I want race cars to fit into my life! A big thing I've found is that since this just isn't a street car, and has no ability to be a street car, it's tough to get that "just gonna go drive the dang thing" and get excited about the project. Starting to find motivation again, which is nice, and I'm aiming for an event or two next year. That's not to say I didn't get ANY mods done this year! I got the Haltech 2500 into the car, and got it tuned. That was a fun small project, with a bigger price tag, but I'm hoping that it solves a lot of problems moving forward. It did reveal that some of the problems with this current engine are just that. The current motor is a L33 aluminum 5.3, but it's just not making great power. Compression and all that looks fine, but it's only putting down 330hp, when we'd expect closer to 400. Putting that out of my mind for now, and going to run it like this. A new engine is just not in the budget right now. I also did quite a bit of work on the front suspension. I've been running the Apex Engineered arms up front, and have been happy with them. Full disclosure, Ohm is a supporter of the build, you may have seen the car on his page! After running a handful of events, I felt like I had 2 problems to resolve. 1) I needed more track width. I have a 1" spacer in the front, and it's just another thing to check on the car, also while making scrub radius work. 2) I needed a beefier ball joint. The Apex arms use a factory sized ball joint, that is a better material, but after running a few track events, getting up on curbs and getting pretty spicy, they were just not up to the task. Bigger is better, so I went and upgraded to a Howe Racing TA2 front control arm, with their thread in ball joint. The arm is 2" longer than factory, and allows the use of an improved ball joint, the design of which is derived from a 3/4 ton truck. I feel pretty good about this mod! I got some work done on managing airflow on the front of the car. With the freshly chopped fenders, I needed a way to get air out of the wheel well, and made up some Kevlar pieces to help with that. I also made a plug for a radiator extractor vent that will help direct air out the hood, rather than spilling around inside the engine bay. I'll need to snag one more fitting for the dry sump, but otherwise, things are looking in good shape. I'm excited to let the car be "done" for a little bit this year. 2 Quote Link to comment Share on other sites More sharing options...
Zetsaz Posted December 19, 2024 Share Posted December 19, 2024 Good update! 2 hours ago, Ben280 said: A big thing I've found is that since this just isn't a street car, and has no ability to be a street car, it's tough to get that "just gonna go drive the dang thing" and get excited about the project. Starting to find motivation again, which is nice, and I'm aiming for an event or two next year. This right here ^ is why I committed to keeping mine fully a street car and I'm glad I did, but part of me also wishes I could go race occasionally without being scared I'll ruin it haha 2 Quote Link to comment Share on other sites More sharing options...
Jboogsthethug Posted December 19, 2024 Share Posted December 19, 2024 Hey dude right there with you! I've been working on my z since June 2015. Kids, houses and responsibilities have all pushed it farther and farther back. But I feel like this is the year and I'm hoping you get back in the game too! also, are the Howe Racing TA2 front control arms made for the 240z or do you have a different cross-member up front? They sound enticing for sure! 2 Quote Link to comment Share on other sites More sharing options...
Ben280 Posted December 19, 2024 Author Share Posted December 19, 2024 14 hours ago, Zetsaz said: part of me also wishes I could go race occasionally without being scared I'll ruin it haha If you are near a SCCA/NASA group that runs the "Track Night in America" or whatever the NASA equivalent is, I HIGHLY recommend it! Much more laid back, and geared towards beginners. If you apply mechanical sympathy to your car you'll be in great shape. Big braking zones are the hardest thing with these cars initially, so just go out, take it slow, and enjoy hearing that straight 6 roar! 12 hours ago, Jboogsthethug said: Hey dude right there with you! I've been working on my z since June 2015. Kids, houses and responsibilities have all pushed it farther and farther back. But I feel like this is the year and I'm hoping you get back in the game too! also, are the Howe Racing TA2 front control arms made for the 240z or do you have a different cross-member up front? They sound enticing for sure! Thanks man! There are a handful of builds on here that have been going on long before I started and are still far from done. I have a newfound respect for the patience those folks have. For the Howe Racing arms, they are extremely not for the Z platform. haha. They are for the Trans Am cars (tube chassis) but they manage to utilize a similar lower arm configuration. I had to add some additional brackets to mount the tension rod in the right spot, remove some "stock" brackets, and design a sway bar attachment point (still not 100% happy with that one). Was hoping I had a photo, but no such luck! I'll do a photo dump here shortly! Quote Link to comment Share on other sites More sharing options...
Jboogsthethug Posted December 19, 2024 Share Posted December 19, 2024 Yes please share how you made that! Very interested in that setup! I initially planned on swapping my front crossmember/setup to an r32 gtr cross-member so I can give it AWD (I've swapped an RB25 in) but if your setup gives me more travel/width (need to research bit to confirm either way) then it would make sense to go that route and do a custom setup for the AWD. Quote Link to comment Share on other sites More sharing options...
tube80z Posted December 20, 2024 Share Posted December 20, 2024 8 hours ago, Jboogsthethug said: Yes please share how you made that! Very interested in that setup! I initially planned on swapping my front crossmember/setup to an r32 gtr cross-member so I can give it AWD (I've swapped an RB25 in) but if your setup gives me more travel/width (need to research bit to confirm either way) then it would make sense to go that route and do a custom setup for the AWD. You can find cheap options on eBay by searching for "used IMCA lower control arm." These straight arms can take various balljoint combos and use a rod-end mounting or a bushing. That will get you options like this https://www.ebay.com/itm/156253492635?_skw=used+imca+front+lower+contrl+arm&itmmeta=01JFH1PRRQS4VARS84HE8VBR09&itmprp=enc%3AAQAJAAABAHoV3kP08IDx%2BKZ9MfhVJKmlnKptmEq49QXHuYUVK0t%2FVqtBOgHRzDCm%2BhuINAAj7rXduUHGplWvDm0w32o9rUYodX6FM68bik%2FtkVdR1OEgMQ4I6PEadB120ZYc9zeSyv94OLc3GuJyjb6aYDdKVZxcAMN9rjS5T4ibk%2FjJBDnCv3n%2FZTMwwRG4otjIm1OadN3F8Hka5QshaeMFiCF5qnoASz4Twy1WWKQTodhNhuPEYc28a4ZzlZ8AqqHhHRyyLV34MiKRX9jF82K8A48bmtIK3tFolRCJaAaOOv6BNOSwfDE8qOE5oa9QaEviKS4QtPVw4DgxBXjo4Dm4bOU3SGk%3D|tkp%3ABk9SR7aM26H8ZA. Two types of TC links are used. One has a stud and uses a solid rod end for connection. The other uses a clevis that connects the TC link. For research, you can get a few used examples off eBay for $20 to $30 or get the manufacturer's catalog for options. Sorry for the hijack. Cary 1 Quote Link to comment Share on other sites More sharing options...
Ben280 Posted December 20, 2024 Author Share Posted December 20, 2024 Hijack away Cary! I like the Howe Racing as i knew it would work with the balljoint I wanted to use, and it had the correct thread for an inboard heim joint. I had to modify it enough at this point, I think next time I'll have some fully custom ones bent up, and use a spherical bearing on the inboard side. 1 Quote Link to comment Share on other sites More sharing options...
Michael Posted December 30, 2024 Share Posted December 30, 2024 Ben, long-term projects take... a long term. So, here's another long-term voice of support! We're almost a quarter of the way done with the 21st century. Some folks started their Z projects back in the 20th century; should hopefully be done, in one capacity or another, before the 22nd! Question: what was wrong with the megasquirt, in terms of successfully operating your LS engine? And what does the Haltech do, that renders the improvement? 1 Quote Link to comment Share on other sites More sharing options...
Ben280 Posted January 3 Author Share Posted January 3 On 12/30/2024 at 12:06 PM, Michael said: Question: what was wrong with the megasquirt, in terms of successfully operating your LS engine? And what does the Haltech do, that renders the improvement? The Megasquirt wasn't wrong. It was working well enough, but it wasn't able to provide any higher level diagnostic functions, effectively run the IAC valve, run drive by wire, or integrate a comprehensive traction control strategy. My tuner was also moving away from tuning megasquirt, and as someone who relies on a tuner, I figured giving him want he needed to succeed was important. The Megasquirt is a powerful computer than can do a lot, but I was running into those limits. The Haltech also provides a lot more I/O functionality, which I was out of on the Megasquirt. 1 Quote Link to comment Share on other sites More sharing options...
Ben280 Posted May 1 Author Share Posted May 1 Well, winter was quiet! Spent most of the winter skiing, rather than being cold in the shop, but spring has sprung and we have some exciting progress on the car. Since the car is in good mechanical shape, the big to-do's have been cosmetic. Mainly the air dam! It's such a cobbled together thing that I knew I had to make some improvements. To that end, I bought a 3d printer, whipped out my iphone and got to designing some new end areas. I'm keeping the same spirit of the airdam as before, but symmetrical sides (just flipped this piece and printed again) meant that I can be confident in the tolerances that I'm working with on both sides of the car! Pretty impressed how well this lined up fresh off the printer, and from a medium quality iphone photogrammetry scan of the front end. I opted to use the PLA as a core for the fiberglass layup, we'll see how that does long term. People have issues with PLA as a finished surface as the "glass transition" temperature is pretty low, and normal temps for sunny car parts will result in significant softening. I think inside 5 layers of fiberglass it should be just fine. (Glassed, sanded down and filler primer. It's easily the nicest part of the airdam at this point!) There is a pretty good gap between the bottom of the air dam and the splitter, so I printed up another whole piece that I will use to pull a direct positive part from. I don't want this to be super heavy duty, so I'm not going to encase the PLA core. (printed and glued) This piece had some scaling issues, even though I modeled it from the same references as the airdam pieces. Oh well! Final bit was that I really needed to make the car all one color again, and install some of the fun stuff I had made up before the winter. I had aspirations of painting the car, but when that plan met with the reality of budget, I opted to go back and vinyl wrap the front end again. The hood might get a re-do, but otherwise I'm rather happy with how it all turned out! Hoping to have the car mostly back together this weekend, and then aiming for an auto-x event at the end of June to shake out the cobwebs from car and driver! 2 Quote Link to comment Share on other sites More sharing options...
FastFloridian Posted May 5 Share Posted May 5 Looks good. What width tires are you running and what’s the width of your wing? I’m a long ways from my build being complete, but those are two things I haven’t decided on yet. Quote Link to comment Share on other sites More sharing options...
Ben280 Posted May 5 Author Share Posted May 5 315/30r18 rear and 295/30r18 front. I think the rear wing is 72" wide with a 13" chord length. I wanted the wing to match the rear track width which is quite a bit wider than factory. Got the airdam painted and mounted this weekend, and finalized the splitter wire mounting positions. I have to fiberglass up the blending piece, but that should be pretty speedy once I get material. A couple photos of the mounting/airdam fixed on: I have a radiator to hood duct/extractor that i'll throw glass up while I'm at it in the next few days. 1 Quote Link to comment Share on other sites More sharing options...
FastFloridian Posted May 5 Share Posted May 5 Thanks. Glad to see someone running something that wide. Car looks fun, good luck at your next event. 1 Quote Link to comment Share on other sites More sharing options...
jhm Posted May 6 Share Posted May 6 Wow...she's looking great, Ben! Nice rebuild after that off at GTA a while back. 1 Quote Link to comment Share on other sites More sharing options...
Ben280 Posted May 6 Author Share Posted May 6 7 hours ago, jhm said: Wow...she's looking great, Ben! Nice rebuild after that off at GTA a while back. Thanks!! It's been a bit, refinding the stoke has been a challenge, but I'm getting excited again. Life changes (wife going back to school) means the race budget is way reduced this year, but I got my eye on a couple days. 1 Quote Link to comment Share on other sites More sharing options...
Ben280 Posted Tuesday at 05:12 PM Author Share Posted Tuesday at 05:12 PM Got into the fiberglass over the weekend to start popping out the last few parts I need to get this thing "finished". First up is the 3d printed splitter transition piece. I think in a modern car this would be a lip, or airdam, but we all know the area it's filling! I knew I didn't want to encapsulate the PLA core, since this is just a wind diverter, so I taped down a bunch of plastic sign board to the bench, and then used hot-glue and foil tape to attach the piece to the boards. Polyester resin doesn't like to attach to foil tape, or corrugated plastic sign board, so I was pretty sure I could pop this piece off when I was done. A little bit of fiberglassing later, and we had the piece ready to go! Side note; People who are able to take in progress photos of fiberglassing are wild, and have a huge budget for gloves. Once the glass cured (which took a long time, I'm using a resin that i'm not super used to, under catalyzed to extend the working time), I was able to mark my trim lines, and then pop the part off! Super satisfying de-molding the part like that. For a Positive to Positive process, I couldn't be happier. I do think I'd like to try printing a mold, rather than a buck like this, it might make the finishing process just a little nicer. Needs to be sanded, some filling bondo applied and then primer and paint. This piece will then get a little rubber lip along the top, and likely be "speed taped" to the splitter. The front of the car is already low, if this were attached forever, I'd be in trouble! Quote Link to comment Share on other sites More sharing options...
