Valve spring seat pressure
jonbill
Hi,
I've been running a. 585 lift 307/8 duration cam for 3 years now (8 or 9k miles).
A couple of the lobes have just started to lose material from near the tips. And I'm looking for how to avoid when I fit a replacement copy of the cam.
The cam is reground from an oiled 1981 f54 l28.
I have Schneider 68025 springs with a seat pressure = 125 lb ( I think)
Are the seat pressures too much? I could swap for 68022 springs at 110lb.
Should I use a spray bar too?
Was I just unlucky or used the wrong zddp additive this year?
Thanks for any pointers.
Jon
I can't answer your question about spring seat pressure but you didn't say anything about what rocker you're using.  Do not use re-ground/surfaced rockers. Use only new Nissan OEM rockers. I would use both a drilled cam and spray bar with a high volume pump. Lucas makes a good ZDDP additive or just go with a good racing oil like Brad Penn with zinc already blended in.
Edited by rossman
Expand
Thanks, yes, they were new Nissan ones. They don't have any damage. It has a high volume pump.
Thanks for info on spray bar and lucas zddp.
  On 7/21/2019 at 7:02 PM, JMortensen said:
It's been 20 years so my info may be out of date, but my machinist who did my E31 picked Schneider springs because they had much lower seat pressures than the competition, which I think was Erson and ISKY.
Expand
Thanks, they've certainly worked fine for 3 years with lots of revs, so no real reason to suspect them other than search not showing anyone here using the 68025 springs.
  On 7/21/2019 at 9:41 PM, zbloke said:
Do the couple of lobes that have lost material look like they've been overheated? if they do are the oil ways partially blocked or could the original hardening depth be thin where the cam was re-profiled?
Expand
Thanks. DSC_0270.thumb.JPG.a0a3872f3edcc98b160d3c5bd4c955ca.JPGThere's no discolouration, just missing material, so assume not overheated. Oil holes are definitely clear.  Could be thin hardened depth, I'm ignorant of any treatment applied to cams TBH.
Thanks.
My engine I suppose got to about 6 or 7k miles before I discovered this wear. I've always used zddp additive with decent synthetic oil. I've had the cam repaired and discussed the springs with the cam grinder/repairer and others and consensus is that the schneider 68025 springs are a little too stiff for the L engine rocker arm setup; I probably have near 300 lb pressure at full lift with them. So I've bought some 68022 which are in the right range.
I'll also be stripping the engine down and drill the block oil jet out to 3mm over the winter.
I'm hoping those two changes should see it good for many more miles.
You shouldn't need to drill the oil restrictor out at all. Plenty of oil available by Spray Bar system or internal oiling of Camshaft.
One caveat, idle speed. With higher pressure springs or ven stock springs with a more aggressive profile, increase idle speed to no less than 1,000 RPM. Local Datsun Engine guru Andy Pearson ( Specialty  Engineering ) recommends this on all of his modified engine builds. Since Andy's car have hold 5 SCCA GT3 runoff titles in 5 invites ( An SCCA record ) ... pretty sure he knows what he talking about.
BTW,  he's done a lot of oil testing with Big Camshafts. Motul 300V has proven the best oil to use on REALLY big Camshafts. Some of his " Street " stroker engines have over 0.600" valve  lift.
Rockers will sometimes fail before cams with OEM Japanese cam cores . This is a result of either oil film failure or Valve floating. You will see a pitting or flaking of rocker pad. This is a metal fatigue failure. Either oil film breaks down, or you have Valve float. Usually valve float. You get a hammering effect on Cam Lobe and Rocker arm when Valve bounces on seat. Pound the s**t out of the Valvetarin.
Thanks,  that's really interesting about the idle speed. Since I installed this engine it's been idling at 1100, except this spring I installed Speeduino mapped ignition and dropped the idle to 950, just because I could really. I did maybe 2k miles like that before I found the damage.
It would be very nice to not strip and rebuild the bottom end this winter to drill that oil jet.
Maybe I'll just fit the new springs, skim the head up to 12:1 and finish the conversion to EFI.
Another possibility might be the steep ramps on a high lift re-ground cam. Re-grinding a stock l-28 cam to a higher lift does change the ramped geometry as oppose to grinding a new cam on a full material blank billet. I have as spare a re-grind on a Nissan stock cam of a 530 lift Isky cam that has really steep ramp profile & less material at the lobe tips then my new Isky cam of the same spec. The cam was passed on to me as a spare a while ago & have not run it as of yet. Just something I noticed when comparing both cams so I'm just throwing it out there that it might be indicative of wear on a high lift re-grind. Others would have to chime in on their re-ground cam lifespans.
Edited by JohnH
  • 1 year later...
Jumping on this thread . Ready to buy some springs and the price difference between the ISKY and Schneider is significant . Not a lot of info out there and too many variables . I will using them on a Nissan core re-grind. I’ve been running ISKY with no issues on my 530 lift cam. Not enough miles for a long term review . Only thing I’ve read negative about Schneider is with cams that weren’t Nissan cores . Can’t find the pressures on the Schneider springs and it seems that the ISKY springs you utilize the stock inner spring?
Schneider list their spring pressures on their website.
for info, when I went to swap out my 68025 (125 lb) springs for new 68022 (110 lb) it turned out the 68025 springs were only exerting about 95 lb anyway. (aiui, lots of high rpm action tires the springs quickly)
Anyway, I think the Schneider springs and caps have been great value for me. I'd recommend them to anyone.
Edited by jonbill
I highly recommend beehive springs guys. I was able to drop a huge amount of mass per valve, and you can have a smaller diameter & thicker retainer which can remain steel, given how much weight you have saved in the springs.
im not sure if anyone makes them off-the-shelf for L-series, but there are several machine shops that can make them custom for you (and retainers). I used Steve’s machine shop in Azusa, CA.
while you are there, look into replacing the typical rubber valve seals with one made from better material (Viton, for example). Besides ring wear, these seals are the most likely oil burn source. They will last much longer.
speaking with Greg Ira yesterday, he is running beehives as well.
Edited by AydinZ71
