Guest rbz Posted April 14, 2008 Share Posted April 14, 2008 240swapped said: lol, i almost bought that shell! crazy small ass world. That's funny!! The shell does need a little work though. Whoever did the floor and the roll cage was using a "fisher price" welder. I'm going to redo them both. Quote Link to comment Share on other sites More sharing options...
Guest rbz Posted April 14, 2008 Share Posted April 14, 2008 synthtk said: Beautiful car! Thanks, I love the color of yours. What engine mods do you have?? I see you had the windows up in all the pics, does your a/c work?? Quote Link to comment Share on other sites More sharing options...
synthtk Posted April 14, 2008 Share Posted April 14, 2008 rbz said: Thanks, I love the color of yours. What engine mods do you have?? I see you had the windows up in all the pics, does your a/c work?? Engine is stock, just running a full fuel system (-10 lines, A1000, RC 1000cc injectors, fuel cell, blah blah blah), boost is set to about 18-20psi, custom ChinaBay FMIC setup w/ 3" pipes and custom 3.5" exhaust and I have the AEM EMS using a MAP configuration with a 5 minute industrial park tuning session based on the AEM base maps. The car has no AC, It just happened to be cool out that morning the pictures were taken, heck I just recently hooked the heater back up Quote Link to comment Share on other sites More sharing options...
mattyice Posted April 15, 2008 Share Posted April 15, 2008 synthtk you car is sick...any links to pics of the exterior of your car? your car is the main car im basing my clean swap off of and i hope i can do as good of a job as you did...i just need one of those SST oil pans instead of the RB20 pan that i do not want to use Quote Link to comment Share on other sites More sharing options...
synthtk Posted April 16, 2008 Share Posted April 16, 2008 mattyice said: synthtk you car is sick...any links to pics of the exterior of your car? your car is the main car im basing my clean swap off of and i hope i can do as good of a job as you did...i just need one of those SST oil pans instead of the RB20 pan that i do not want to use I will have to see if I can find any other pics, most of the good ones are posted. I need to get the car cleaned up and have my friend take some new shots with the new rims and brakes, I have a good amount of the car before the RB and then some after the RB but without the new rims, flares and brakes. Thanks for the compliments! Quote Link to comment Share on other sites More sharing options...
tonycharger72 Posted November 16, 2008 Share Posted November 16, 2008 Here is some pics of my RB30 powered Zed!!! Quote Link to comment Share on other sites More sharing options...
Mike Rowe Posted November 16, 2008 Share Posted November 16, 2008 Mine's about 3 months away I think. Engine rebuilt & gearbox in, wiring under way, exhaust system in about 1 month, new ali radiator from China in next two weeks hopefully. The to the Police Dept to see if they will approve it???!!!! Quote Link to comment Share on other sites More sharing options...
jerryb Posted November 16, 2008 Share Posted November 16, 2008 Nice install I like the polished look very much! A small tip....I dont think you will be needing that ignition coil! Mike Rowe said: Mine's about 3 months away I think. Quote Link to comment Share on other sites More sharing options...
240Z_Master Posted November 16, 2008 Share Posted November 16, 2008 jerryb said: Nice install I like the polished look very much! A small tip....I dont think you will be needing that ignition coil! He's going to remove his individual coil packs and run points. Quote Link to comment Share on other sites More sharing options...
jerryb Posted November 16, 2008 Share Posted November 16, 2008 ???? Hmmmmmmmm. 240Z_Master said: He's going to remove his individual coil packs and run points. Quote Link to comment Share on other sites More sharing options...
240Z_Master Posted November 16, 2008 Share Posted November 16, 2008 Just kidding Quote Link to comment Share on other sites More sharing options...
900ss Posted November 16, 2008 Share Posted November 16, 2008 Great seeing all those pics ! Deffo some excellent ideas can be had from them Quote Link to comment Share on other sites More sharing options...
RIPSNZ Posted November 17, 2008 Share Posted November 17, 2008 Here's some links to mine with the latest changes: On the dyno at medium boost: First test runs at the strip with the new setup: so we turned the boost down to 21psi and had another go: This is how she used to go at 30 psi in full street trim: Hopefully we can get some grip and get the boost wound back up again Rob Quote Link to comment Share on other sites More sharing options...
stony Posted November 17, 2008 Share Posted November 17, 2008 NICE!!!!!! what rpm are you launching at.... seems like not much higher then idle???? using the NOS yet??? Quote Link to comment Share on other sites More sharing options...
stony Posted November 17, 2008 Share Posted November 17, 2008 Oh yea and your last 2 youtube links are the same ones.... damn guy with the hat is annoying !!!! Quote Link to comment Share on other sites More sharing options...
RIPSNZ Posted November 17, 2008 Share Posted November 17, 2008 The 8.90 was with low rpm and basicly no boost on the trans brake, roll gently off the line then feed it on slowly with peek boost of just 21psi, no NOS at all and wheelspinning bad over the finish line (had 9300rpm in top just after 1/2 track and had to pedal it plenty), lol. Should be good when we can give it to it the whole way. Quote Link to comment Share on other sites More sharing options...
RIPSNZ Posted November 17, 2008 Share Posted November 17, 2008 stony said: Oh yea and your last 2 youtube links are the same ones.... damn guy with the hat is annoying !!!! Sorry, last one was suppose to be: how you going with yours? Rob Quote Link to comment Share on other sites More sharing options...
stony Posted November 17, 2008 Share Posted November 17, 2008 Track is closed here. wont be able to run again till i get to UTAH and at an elevation of 4500 ft above see level i don't think i will see the same performance i had in Alaska but we will see. start it up every week or so to keep it lubed up. Oh yea i still have some body work to do Quote Link to comment Share on other sites More sharing options...
Temujin Posted November 17, 2008 Share Posted November 17, 2008 6 months of time, effort, money and scratched knuckles ... and it'll hopefully be finished by late january '09 Quote Link to comment Share on other sites More sharing options...
Careless Posted November 17, 2008 Share Posted November 17, 2008 not feelin the flares, they look like they're inverted flares or something. and I like green so I hate to see another green z be banished from the face of the earth, but atleast it's getting a new lease on life. Quote Link to comment Share on other sites More sharing options...
