aviation fuel mix with gasoline?
ussbhr
It's headlight fluid, gosh get it right! :P
Perhaps you're confusing AVgas with Jetfuel, which will give you tons of extra power... right before your engine melts. :lol:
Down to business - So, is there a legitimate reason you're wanting to run this stuff? Potential for increased timing, reduced knock, higher boost, a cheaper (???) solution to other high octane fuels?
Avgas is just simply higher octane fuel. Which pretty much means that the burn will be much more steady and consistent. This is great for turbo cars, because they can run more boost without detonating. As far as NA applications go, unless you're running really high compression, you probably won't notice a staggering difference. Although if you can afford it, better gas never hurt anyone. Especially since avgas is so refined and filtered its ridiculous.
You guys are being needlessly rough.
What you want to do will raise the overall fuel octane. More av gas then pump gas and the higher the octane goes. You are essentially making premium gas.
But unless your car NEEDS premium gas, you won't get any extra power out of it. Turbo cars can dial up the boost or timing to make more power with higher octane gas, but like mentioned above there is only so much you can do to a non turbo car to make better use of the octane.
And leaded gas is no more hazardous then unleaded, except to your catalytic converter, if you have one.
Oh, and jet fuel is just low quality kerosene. Your car won't run at all on kerosene.
  • Administrators
I have not spent the time to research the accuracy of the following, but Gene Berg wrote it and his success speaks for itself (underlines are mine)...
"Aircraft fuel is often considered as a high octane fuel that may be used in a high performance car engine. When talking to the engineers at one of the major refineries I was rather shocked to find that they use a totally different octane rating system. Aircraft engines are rarely ran over 2500 RPM so the piston pressure is changed far less than that of the auto engine that has a wide RPM change. The higher the performance usually means even a higher RPM range. They also rate the octane according to the rich or lean mixture device on the dash of the airplane. The aircraft fuels octane ratings were considerably lower compared to the automotive fuel rating system and should never be used for automotive applications. In fact, one of the new big things for aircrafts is to use automotive unleaded gas."
Well Ron you are right.
My plane was certified to run unleaded gas, so I was bringing my Canister at the pump and filling the plane with them. Cost was a lot lower. I was only doing this in the winter, in the summer it was not going as well if the plane was heavy.
I guess with the unleaded gas, the plane was more sluggish, had less torque/power.
Dayz
Well when my engine pinged on 92, I cut it with 100LL and the pinging went away. Car made a lot more power as I was able to adjust the timing to something close to "proper" as well. I've also run leaded race gas cut with 92, and Tolulene and Xylene cut with 92. I've also bent over at the race track and paid big bucks for unleaded race fuel.
All of these solutions worked. For my engine my butt dyno said the 112 leaded race gas and the 100LL cut with 92 worked best. I don't doubt that its true that the octanes are rated differently, but when I calculated it out I needed about 95 octane with car gas to keep from pinging. That's what I shot for with the AVGas not knowing that it is rated differently, and it didn't ping either.
Higher octane fuel contains less BTU/gallon than lower octane fuel. plain and simple. Unless you can make up for this loss of energy somehow like listed above, there are no advantages to running higher octane fuel. Given the fact that there is less overall energy in a given amount of fuel, in turn makes it more stable for combustion. Add more boost, change ignition timing, raise compression, One might be able to use this to their advantage to achieve more overall power. With that said, Ill go out on a limb and say that an engine in a given state of tune, will make more power on 87 octane pump gas, than it will on 100 octane race gas. Personally, I run the lowest octane rating that I can without pinging.
  • Administrators
I’ll throw in my $.02 as well.
Back in the mid ‘90’s one of our flag ship engine projects we built for Justin Boice and his unlimited class white water endurance race boat, (Wade was owner of the shop overseeing, planning, ordering parts, etc, for this project, I merely machined and assembled it). That engine was run only on 100LL Av-gas. This was a Twin Turbo, 540 CID Big Block, 10:1 static compression ratio, 12 lbs of boosts, water to air intercooler, (IAT after the intercooler was only 85 degrees), and on the engine dyno at Sunset Engine Development produced 1168 HP at 5800 RPM! Engine was not revved past 6200 RPM, (that is what we told Justin to keep it under, whether or not he did?) This engine would run at WOT for 80+% of the time during the race for stints exceeding an hour at times, set many records down and UP several rivers, (lower Rogue, Snake, etc), and would run a whole season between tear downs. I still have the pistons and Rods from the first season here in the shop. Pistons look great, under side shows no signs of coking, rings all show very little wear and could’ve easily ran another season, bearings look like new.
That is one application where Av-Gas appeared to work.
Also as a certified Aircraft and Power-plant technician and private pilot, I also know that Av-Gas is not formulated like auto gas, i.e., they are quite different. Av-Gas is formulated for longer shelf life as some air planes will sit for extended periods between fill ups. Av-Gas is also formulated to withstand the extreme temperatures of higher altitude and for many other factors that is not taken into account with auto gas.
This different formulation alters Av-Gas so much that its specific Gravity is much less than that of Auto Gas. That means for given volume, there is actually less mass, (less dense, i.e., in a running engine, Av-gas burns leaner for a given jet size/injector pulse width compared to auto gas). With that means for us Auto guys, is that if you just switch to Av-Gas from auto gas, you will have to run slightly larger jets in the carb or slightly longer pulse widths for the injectors if the engine is fuel injected. You may have heard old timers talk about running Av-Gas in their cars, motorcycles, lawn mower, etc and mention that the Av-Gas is so much hotter that they burned a valve or melted a piston! Uh, yeah they burned the valves and melted pistons, but not from Av-gas being hotter. Av-Gas is NOT hotter, i.e. no more BTU in Av-gas vs Autogas, it is less dense, those bone heads didn’t compensate for that and as such, their engines were running too lean and THAT is what burned their valves and melted their pistons. wink.gif
Another attribute that Av-Gas has a slower burn rate, ie. flame speed. I have only read this in one other place, but the source was credible so I believe it to hold water. A slower flame speed could be a hindrance at elevated engine speeds as the rate at which pressure rises due to combustion is slower and therefore depending on the combustion chamber size, the engine could become less efficient at making power the higher it revs, i.e. burn event is not happening fast enough in the time available at high RPM.
In summation;
1) Don’t mix Av-gas with auto gas. nono.gif They are very much different. Use one or the other, but don’t mix unless you are a gasoline engineer and know what you are doing. Most of us just are not that savvy to know so we are better off not mixing.
2) Auto gas is known to work in auto engines as well as Air craft engines just fine. Av-Gas is for Air planes, (yet I have been know to run it in my … )
3) If you plan to run Av-gas in a race car, I feel it is ok so long as it is not in a high revving engine with a large bore, but do not forget to tune for it, i.e. make darn sure the mixture is correct, do NOT just tune for auto gas then switch over to Av-Gas without retuning the fuel map.
4) Automotive Race gas works just fine and is actually formulated for high RPM, high compression auto engines, though it is generally more expensive. If Race gas is too expensive for you, then to be perfectly honest, racing in general is too expensive and you should just sell the car as the price of gas should NOT be the determining factor of whether or not you can race. cool.gif
That is my $.02
Paul
ad...
In summation;
Actually from what I can tell different types of race gas have different specific gravities and need to be tuned for when you have a motor on the edge. Probably not something you'd worry about in a normal auto engine. But something still to think about.
Cary
Can someone post a link or list of the specific gravities of various fuels listed here.
I am also interested in how Toluene and Xylene rate in comparison, Either pure or mixed.
Just for kicks and hazard prevention... what about the poor fella who mixed up his brake cleaner and his carb cleaner one day? I know there are variations of each.
Also what effect do normal dosages of Marvel's MO, other preservatives, and top cylinder oils have on the fuel performance?
Alcohol is EVERYWHERE... uhhhh?
For you Aircraft guys.. I have read in Smithsonian's "Air and Space" a story of how a pilot lost his life due to large quantities of Marvels' Mystery oil in the fuel tanks. Not a very good preservative in his case...
But the whole point IS to modify the engine to make maximum use of the fuel. The availability of higher octane gas will allow you to build a higher HP motor.
And even though much has been made of the different methods of measuring octane in av gas, no one has posted anything to say what the actual octane of pump and av gas is. Except Jon, who posted some empirical result that supports the idea that av gas does increase octane.
Plus I am not seeing the "don't mix av gas and pump gas" warning. Don't see much to support that contention.
Been following this thread for kicks, but this Q I might be able to give some input on.
I believe his "don't mix" warning was based on the fact that over time two substances with different enough specific gravities will separate, and at any one point you might be running a higher concentration of one or the other, or just have an unpredictable mixture.
Assuming that's correct, I didn't know the various fuels would have a different enough specific gravity to make a serious difference. Shows what I know! Now back to the experts...
  • Administrators
Ok, I retract my “no mixing” statement. Everyone can mix the two all you want, for whatever special elixir you guys feel that it then becomes.
Personally, there is enough of a difference in their formulation that I see no reason to “mix” them. Either you want the benefits of the formulation that Av-gas affords or you do not. Like mixing Chevron Super unleaded and Texaco regular unleaded to meet some sort of goofy middle ground. I don’t see the point . Just use one or the other and be done with it. Better yet, if your motor was built to take advantage of high octane fuel, just use Race gas! No guessing or speculating.
But the whole point IS to modify the engine to make maximum use of the fuel. The availability of higher octane gas will allow you to build a higher HP motor.…..
Yeepsie doodle. I agree…
