ZDrifter Posted July 18, 2007 Share Posted July 18, 2007 Anyone know what part numbers or another car that has the same alternator belt for the RB25DET? I took my old one in to Autozone and they matched it as close as possible but it wont work out....They also didnt understand what it means that my motor isnt in there system. This is the conversationg as fallows.... Mr. Autozone-"What car does it come from" Zdrifter-" My motor is not in your system" Mr. Autozone-" haha Im sure it is" Zdrifter-"Alright its a RB25DET out of a skyline" Mr. Autozone-"Whats that? I have never heard of it" Zdrifter-"Exactly my point, please try and match this.":roll: Quote Link to comment Share on other sites More sharing options...
ZDrifter Posted July 18, 2007 Share Posted July 18, 2007 Anyone?? Anyone?? Bueller?? Bueller? Bueller?? Quote Link to comment Share on other sites More sharing options...
Bob_H Posted July 18, 2007 Share Posted July 18, 2007 10 hours on our RB board with low traffic isn't enough - give it at least a few days before you start asking why noone has responded. You also posted at near midnight - and its only about 10am your time - most of the traffic is in the evening - so I would wait at least until you've had the post up for at least 24 hours. Look at the part number on the old belt - and see if they can match that. Second, go somewhere like NAPA and get them to measure the old belt and match it that way. -Bob Quote Link to comment Share on other sites More sharing options...
Evan Purple240zt Posted July 18, 2007 Share Posted July 18, 2007 K040340 is the belt I use. Double check before you get it, this is by memory. Thats a Gates number btw. Evan Quote Link to comment Share on other sites More sharing options...
ZDrifter Posted July 18, 2007 Share Posted July 18, 2007 Thank you for the direct answer Evan_Purple240zt Quote Link to comment Share on other sites More sharing options...
Pop N Wood Posted July 19, 2007 Share Posted July 19, 2007 If you look at the part number it will tell you everything you need to know about the belt. The number of ribs and belt length are in the part number. If you have a belt that is too short or too long, then it is a simple thing to figure out what to add to the part number to get the correct length belt. Quote Link to comment Share on other sites More sharing options...
stony Posted August 12, 2007 Share Posted August 12, 2007 some more part numbers PM'd to me from Zdrifter Quote Hey Stony, I found these part numbers on accident for RB25DET belts. Wondering if you could add these to the sticky, thanks! Alternator Belt- Gates K040335 A/C Belt- Gates K040378 Power Steering- Gates K030328 This is unconfirmed but should fit. Quote Link to comment Share on other sites More sharing options...
stony Posted May 1, 2008 Share Posted May 1, 2008 Found this while i was trolling FA good info Thought this might be useful also: Part numbers for RB26DETT only, unless otherwise noted. Ignitor pack- R32/33- 22020-05U00 Spark Plugs- PFR6A-11 Clutch Pull to push conversion- Late Model R32, R33 and R34’s Front cover assembly :32110-05U11 (japan part only) Gasket :32112-05U12 Clutch fork :30531-01S00 (same part for a 1991-1993 240SX) Spring :30514-14600 Spring :30534-E9000 T/O bearing :30502-14601 Bearing sleeve:30501-S0160 / 30501-N1601 (14mm for twin / trip disc) Bearing sleeve: 30501-K0404 (24mm for single disc) Dust cover :30542-31610 Slave cylinder :30620-21U01 Flywheel bolt: 12315-04U00 Factory Clutch R32 GTR Disc- C0100-05U15 Cover-30210 - 05U01 Bearing- 30502-21000 R33 GTS Disc- 30100-21U01 Cover- 30210-21U00 Throw out bearing- 30502-12U00 (300ZX part) or 30502-45P00 (300ZX part) Bearing Sleeve- 30501-S0200 (18mm) R33 GTR Disc- 30100-0V708 Cover- 30210-24U00 Bearing- 30502-12U00 R34 GTR Disc- 30100-0V708 Cover-30210 - AA300 Bearing- 30502-12U00 R32/33 Brembo Brake pads- F 41060-12U87 R 44060-12U87 Belts- RB26 R32 4 Ribs AC- 925 mm Power Steering- 950 mm Fan- 880 mm RB26 R33/R34- 4 Ribs AC- 910 mm Power Steering- 969 mm Fan- 875 mm R32- RB25 AC- 4 ribs 925mm PS- 3 ribs 845mm Fan- 4 ribs 860mm R32- RB20 AC- 4 ribs 925mm PS- 3 ribs 855mm Fan- 4 ribs 860mm R33- RB25 AC- 4 ribs 910mm PS- 3 ribs 845mm Fan- 4 ribs 850mm R33-RB20 AC- 3 ribs 910mm PS- 3 ribs 855 mm Fan- 4 ribs 850mm R34- RB25/RB20 - 4 Ribs AC- 910mm PS- 865mm Fan- 890mm Water Pump-21010-58S25 N1 Water Pump- 21010-21U26 N1 oil pump- 15010-24U01 Thermostat-21200-42L06 for the RB25DET and RB26DETT. Part # is 21200-42L00 or 21200-42L01 for the RB20DET. R32 ABS Unit- 47600-05U00 R33 ABS Unit- 47600-15U00 R32 Power steering pump- 49110-05U00 Intake gasket- 16175-05U70 (3 needed) Nismo AFM’s 22680-RR580 Standard AFM’s 22680-05U00 Lower rad hose- 21603-72L00 Upper rad hose- 21501-05U00 R32 ATTESA valve- 49836-01U00 R33 AC Compressor- 92600-24U15 R32 Clutch master Cylinder- 30605-05U00 R32/33 CAS 23731-02U10/1 R32 Starter- 23300-20P00 N1 Block- 11000-24U00 Injector O-Rings- 16635-78A00 Valve cover gasket- 13270-58S11 and 13270-58S01 Valve cover half moon seal- 11051-58S00 R32 AAC- 23781-05U11 R32 GTR ECU- Hitachi- 23710-05U02/01 R32/R33 Twin Cam valve cover strip- 13290-05U00 R33 Front Hood Spoiler-65834-24U00 R32 Oil Pressure Sender- 25070-30P01 R33 AC Hoses Flexible low pipe - 92480-98U00 Front cooler high line- 92440-24U20 Flexible low hose- 92490-24U10 R33 Heater core compatible with Z32 heater for you must reuse your plastic inlet and out lines- TBA RB26 Dip Stick- 11140-05U02 R32/33 Starter- 23300-20P05 R32 Alternator (Mitsu unit) 23100-20P10 (90 amps) 23100-86L11 Mitsu (90 amps) and 23100-86L12 Mitsu R33 Alternator 23100-70T13 Mitsu (80 amps) 23100-70T03 hitachi (80 amps) 2/97~up 23100-0V010 Mitsu (80 amps) R34 Alternator 23100-0V016 R32 2WD model Alternators 23100-59S01, 23100-85L00 Hitachi 23100-85L10, 23100-85L11, 23100-85L11 Mitsu Found this on GTR UK BNR32 Part Number Item Description Common To Other Source Notes 13028-20P25- Belt - Timing no 16400-72L00- Strainer Assy - Fuel U13 21200-42L05- Thermostat Assy Y32 22401-58S15- Plug - Spark KN13 w/CA18DE 28890-01U00- Blade Assy - Windshield no 28890-51S10- Blade Assy - Windshield B13 28790-56E00- Blade Assy - Rear Window U12? 30100-04U00- Disc Assy - Clutch no 30210-73L00- Cover Assy - Clutch no 30502-21000- Bearing - Clutch Release Z31 turbo 46210-04U00- Hose Assy - Brake, Front no 46214-01A11- Hose Assy - Brake, Rear B13 37521-01U26- Bearing Kit - Center (Driveshaft) no from 89/11 to 90/08 38300-84M79- Final Drive Assy no without EAL sensor 39241-73L25- Repair Kit - Seal, Outer (outer CV boot, rear) Z32 non-turbo 39741-03P27- Repair Kit - Seal, Inner (inner CV boot, rear) Z32 non-turbo 30611-71L25- Piston Kit - Clutch Master Cylinder WD21 '90-'91 30621-26E25- Piston Kit - Clutch Operating Cylinder no 32114-Y4000- Seal - Oil, Front Cover (Transmission) D22 '00+ KA24DE 32112-04U00- Gasket - Front Cover (Transmission) S13? 32136-U0100- Seal - Oil, Rear Extension (Transmission) D22 '00+ KA24DE 32870-V5003- Socket Assy - Control Lever (shifter bushing) S13 32862-V5001- Boot - Control Lever (inner shift boot) S12 38342-P9000- Seal - Oil, Differential Side Z32 non-turbo 38440-N3100- Bearing - Differential Side WD21 '90-'93 38189-21G00- Seal - Oil, Drive Pinion WD21 '88-'90 38120-13210- Bearing, Drive Pinion, Front Z32 non-turbo 38120-10V00- Bearing, Drive Pinion, Rear Z32 non-turbo 39711-73L00- Joint Assy - Inner (rear CV joint) Y32 43210-AA000- Bearing - Rear Axle, Inner no 43206-01U00- Rotor - Disc Brake, Rear Z32 '90 40210-33P02- Bearing Assy - Front Wheel Z32 40206-04U00- Rotor - Disc Brake, Front no 54524-01U67- Link Complete - Front Suspension, Upper RH no 54524N 54524-01U67- Link Complete - Front Suspension, Upper LH no 54500-01U01- Link Complete - Transverse, RH no 54500 54501-01U01- Link Complete - Transverse, LH no 54590-01U25- Extension Complete - Knuckle Arm, RH no 54590 54591-01U25- Extension Complete - Knuckle Arm, LH no 56112-A0100- Bush P11 56112 54618-56S11- Rod Assy - Connecting, Stabilizer S14 56112-V0100- Bush P11 56112+A 54468-01U00- Rod Complete - Tension, Front Suspension no 54476-35F20- Bush - Mounting, Tension Rod G50 54613-01U11- Bush - Stabilizer no 54050-01U11- Bumper Assy - Bound no 43252-30P00- Seal - Grease, Rear Hub Z32 non-turbo 55157-33P00- Bush Z32 43052E 55152-35F00- Bush G50 43052D 56219-33P00- Bush Z32 43052F 55130-32P00- Link Complete - Upper, Rear Suspension Rear Z32 8903 - 9008 55130M 55120-71L00- Link Complete - Upper, Rear Suspension Z32 8903 - 9006 55120 56113-33P00- Washer - Rear Stabilizer S13 56113M 54612-35F00- Bush - Rear Stabilizer Z32 56243+A 54612-01P00- Bush - Rear Stabilizer Z32 56243 55501-35F00- Arm Assy - Rear Suspension, RH Z32 non-turbo to 9006 55501 55502-35F00- Arm Assy - Rear Suspension, LH Z32 non-turbo to 9006 55502 54613-71L10- Bush - Rear Stabilizer S13 56243+B 55490-01U00- Damper Assy - Dynamic, Rear Suspension no 55475-35F00- Stopper - Member Mounting Lower S13 55475M 56217-71L00- Bush - Rear Shock Absorber P11 55154-30P00- Ball Joint Assy - Rear Axle Z32 turbo 55114-39F10- Link - Lower, Rear Suspension S13 55114+A 55114-39F00- Link - Lower, Rear Suspension S13 55114 48203-39F25- Boot Kit - HICAS Actuator S13 36530-71L00- Cable Assy - Brake, Rear Right no 36531-71L00- Cable Assy - Brake, Rear Left no 46011-30P25- Piston Kit - Tandem Brake Master Cylinder no same as GT-R 46010-04U20- Cylinder Assy - Brake Master no Three different brake master cylinders listed - check first 48080-50M11- Joint Assy - Steering, Lower KN13 49110-04U00- Pump Assy - Power Steering no 49200-04U00- Gear Assy - Power Steering (steering rack) no 49271-04U00- Rack Assy - Power Steering no 48521-72E00- Socket Assy - Tie Rod, Inner P10 48520-71L25- Socket Kit - Tie Rod, Outer no 49365-10V26- Seal Kit - Oil, Rear Housing (of steering rack) B14 49277-42L00- Seal Set - Piston Z32 '90-'92 49297-10V25- Seal Kit - Housing, Power Steering Gear U12? 48203-10V25- Boot Kit - Power Steering Z32 22433-60U01- Coil Assy - Ignition G50 '91 does not include protector 22020-05U00- Transistor Ignition Unit no same as GT-R 23731-79S10- Camshaft Position Sensor no two listed, check first 25080-89903- Sensor - Temperature Z32 25080X 25070-55S60- Sensor - Oil Pressure Z32 '90 25085-89900- Sensor - Boost Z32 23100-59S01- Alternator Assy no 23300-20P00- Motor Assy - Starter no 23343-20P00- Switch Assy - Magnetic (starter solenoid) B14 '94 GA16DE MT 25567-71L01- Body - Combination Switch no 25570-71L00- Switch Assy - Mirror Control no 24345-51E60- Cover - Connector (for battery connector) P10 24080-01U00- Cable Assy - Battery Earth no 24077-01U00- Harness Assy - Engine no 24022-F6100- Wire Assy - Fusible Link F31 24022 24022-55S60- Wire Assy - Fusible Link no 24022+A 24010-01U13- Harness Assy - Main no 25560-02U00- Switch Assy - Combination no 25260-01U00- Switch Assy - Wiper no 25260P 25260-01U10- Switch Assy - Wiper no 25260PA 25290-01U00- Switch Assy - Hazard no 25160-01U00- Switch Assy - Lighting no 25350-01U00- Switch Assy - Rear Defogger no 25540-01U22- Switch Assy - Turn Signal no 25450-01U10- Switch - Sunroof no 25401-04U00- Switch Assy - Power Window, Main no 25431-01U00- Switch Assy - Power Window, Assist no 28515-01U00- Amplifier Assy - Auto Power Window no 28511-01U01- Amplifier Assy - Windshield Wiper no 28475-01U00- Sensor Assy - Steering no 26025-01U00- Housing Assy - Head Lamp, RH no three kinds listed, check first 26075-01U00- Housing Assy - Head Lamp, LH no 26719-C9946- Bulb (headlight) G50 '91-'93 26011AD 26124-01U00- Body Assy - Combination Lamp, RH (front) no 26129-01U00- Body Assy - Combination Lamp, LH (front) no B6554-04U00- Body Assy - Combination Lamp, RH (rear) no B6559-04U00- Body Assy - Combination Lamp, LH (rear) no 26552-04U04- Rim - Combination Lamp, RH (rear) no 26557-04U04- Rim - Combination Lamp, LH (rear) no 28930-01U00- Nozzle Assy - Washer, No. 1 (driver's side) no 28931-01U00- Nozzle Assy - Washer, No. 2 no 28970-01U00- Nozzle Assy - Rear Window Washer no 28920-71L10- Pump Assy - Washer no 27140-71L10- Core Assy - Front Heater U12 27220-91L00- Motor & Fan Assy - Blower P10 21410-04U00- Radiator Assy no 21501-04U00- Hose - Radiator, Upper no 21503-72L00- Hose - Radiator, Lower no 21430-01F01- Cap Assy - Radiator B13 48470-04U00- Cover Set - Steering Column no G2716-89901- Dam Rubber - Sealant S13 72750-04U10- Moulding Set - Windshield no 72712-05U05- Glass - Windshield no 72725-04U10- Fastener - Moulding no G2716-89902- Dam Rubber - Sealant (rear window) D21 79780-04U10- Fastener - Moulding no 79712-04U17- Glass - Rear Window no 79750-04U10- Moulding - Rear Window no 80730-F6100- Motor Assy - Regulator, RH S13 80731-F6100- Motor Assy - Regulator, LH S13 80720-04U00- Regulator Assy - Door Window, LH no 80721-04U00- Regulator Assy - Door Window, LH no 80300-04U00- Glass Assy - Door Window, RH no 80301-04U00- Glass Assy - Door Window, LH no 83306-04U10- Glass Assy - Side Window, RH no 83307-04U10- Glass Assy - Side Window, LH no 96365-35F00- Glass - Mirror, RH Z32 96366-35F00- Glass - Mirror, LH Z32 96321-01U00- Mirror Assy - Inside no 10101-73L25- Gasket Kit - Engine Repair no 11042-72L25- Gasket Kit - Valve Regrind no 12279-42L00- Seal - Oil, Crankshaft Rear no 11121-42L00- Gasket - Oil Pan no 11044-58S01- Gasket - Cylinder Head no 13270-58S01- Gasket - Rocker Cover no 13270-58S11- Gasket - Rocker Cover no 15255-40F00- Cap Assy - Oil Filler B13 w/GA16DE 11220-02U02- Insulator - Engine Mount, Front no 89-'91 11320-41L03- Insulator - Engine Mount, Rear no 13231-58S12- Lifter - Valve no same as twin-cam CA engines 13070-73L00- Tensioner Assy - Belt (timing belt) no 14035-72L10- Gasket - Manifold (intake manifold to head) no 14032-72L00- Gasket - Intake Manifold (intermediate) no 14036-58S00- Gasket - Exhaust Manifold no 14415-V5300- Turbocharger Inlet Gasket Z31 turbo 14445-V2700- Turbocharger Outlet Gasket no 14465-26E00- Gasket - Inlet Tube (turbo compressor) Z32 turbo 8907-8912 15196-P7600- Turbocharger Oil Outlet Gasket Z31 turbo 14401-72L26- Turbocharger Gasket Kit no 15010-79S05- Pump Assy - Oil no 13510-19V00- Seal - Oil, Crankshaft Front no 22620-02U00- Throttle Position Switch no 16175-79S00- Gasket - Throttle Chamber no 22670-72L02- Regulator Assy - Pressure (fuel pressure) no 25060-01U00- Sender Unit - Fuel Gauge no 21010-42L25- Pump Assy - Water no 17042-73L02- Pump Assy - Fuel no 17251-79915- Cap Assy - Filler B12 BCNR33 Suspension part numbers 54618-05U00- front anti-roll bar link (goes on the end of the roll bar) 40160-AR510 front inner ball joint 40160-05U00 front outer ball joint 54613-01U11 front anti-roll bar bush 54614-05U00 front anti-roll bar bracket R32/33/34 Wheel bearings 40210-05U00- Front 43280-AA3001- rear 43281-AA3001- rear Hub seals 40232-33P55- front 43252-40P00- rear R34 CAS- 23731-5L300 Updated 3rd, 4th and 5th gear trans part (R32-R33) 32606-30P10 Coupling sleave 32251-30P14 2nd gear 32604-30P60 ring 5th 32261-12014 3rd gear 32604-30P61 ring 32811-05U10 shift fork 32611-AA510 Coupling sleave 32609-70L15 Shifting insulator X3 32201-05U71 Main drive gear 32604-40P61 ring 32605-30P11 Hub 32603-30P00 Spring shifting X2 32212-AA504 Counter gear 32230-054U24 First gear 32137-AA500 Plate 32341-30P04 Over drive gear ( 5th gear ) 32245-30P60 Reverse gear 32220-30P60 Reverse gear 32614-30P60 Ring 32615-30P60 Shifting insulator X3 32214-01G21 Corn counter 32616-30P20 Coupling sleave 32282-30P61 Reverse gear 32320-VB361 Shaft 32139-VB300 retainer 32312-30P24 gear 32320-VB361 shaft 32139-VB300 retainer should i sticky it? Quote Link to comment Share on other sites More sharing options...
Careless Posted May 1, 2008 Share Posted May 1, 2008 you should grab the ones from GTRCanada too, and sticky them as well. Quote Link to comment Share on other sites More sharing options...
synthtk Posted May 1, 2008 Share Posted May 1, 2008 Nice find guys! Quote Link to comment Share on other sites More sharing options...
RB26powered74zcar Posted May 1, 2008 Share Posted May 1, 2008 stony said: should i sticky it? I thought we were putting that kind of info in this thread> http://forums.hybridz.org/showthread.php?t=97516 Quote Link to comment Share on other sites More sharing options...
stony Posted May 2, 2008 Share Posted May 2, 2008 HMMMM when i merged the threads the old name changed????? Anyways that thread is for links and the such this one is for part numbers ect ect Quote Link to comment Share on other sites More sharing options...
ZT-R Posted November 18, 2010 Share Posted November 18, 2010 Nice job stony, posting so i can find this later Quote Link to comment Share on other sites More sharing options...
