Progress on my insane VQ35HR 240Z project
On 11/18/2021 at 9:14 AM, zack_280 said:
Mark, I'm going to be at COTA for the WRL race.  Any chance of you running the open lapping HPDE on Friday, 12/3?  Mostly, I just want to see the car in person.
sorry. did not make that event. But just ran COTA on 12/19 and had a great time. Car ran great. I did take it a bit easy just to get through the day without any surprises. I posted a video of the last session. My brother rode along, getting to experience the track for the first time.
https://www.youtube.com/watch?v=RKw4UNuSOoM
  • 3 months later...
Activity here may slow down quite a bit since the car is mostly finished. However, I am doing small bits of work to refine the car. The original steering rack was one I bought from Morrison and it is really set up for big hotrods. It's too slow. So I bought one that allows for custom ratios. This is a much faster ratio so I can do full turns without taking my hands off the wheel.
Also, Andris, who builds race cars at the shop had a 4th gen Bosch motorsports ABS kit available that he had pulled from a car so we are installing it into the car. True motorsports ABS is a game-changer.
And a few changes to oil breather and fuel venting exhaust plumbing will tidy things up. Then lastly I started some early work mapping out a more aggressive front splitter for the track.
Those Coleman racks are not very nice.  They are a cheap dirt car setup meant for serious abuse.  Do yourself a favor and buy a Woodward steering rack.  They will custom build to your specs or you can use one of many pre-built setups.  If you're not using electric power steering their servo allows you to change the force level of the assist but doesn't have any production car damping.  Jon went this route on his car.
Awesome news on the Bosch motorsports ABS.  Totally jealous of that purchase.
On 3/28/2022 at 7:31 AM, 1 tuff z said:
Mark, are you going to make it ZCON this year?  Love to see your Z run at Barber!
Please do share- what's not nice about the Coleman racks? They were one we found that fit and had a lot of options for steering ratio. Certainly the hardware looks pretty robust in hand. I think we looked at Woodward and something didn't work out. I can't recall atm.
Also, not going to make it to Zcon. Will try and make it to Znationals though.
In response to the Coleman rack I'll add that they are heavy, need to be greased often, rely on small friction surfaces to keep play down, and if you're using hydraulic steering the servo lacks feel.  I have seen a bunch of them with bent racks that are often felt as a stickiness in the steering.  I got two of them used and had to do a bunch of press work to get them straight.  One was listed as bent so I knew that but was surprised that the "good" one also had a smaller bend in the rack housing.  Perhaps Coleman has fixed all this and they are somewhat decent these days.  I think they are great for dirt cars but I'd prefer one that has proper seals on the rack and had a better system to take up any play between the rack and housing.
Cary
Cary
thanks. I'll report back how it feels. This one is new so I'm not worried about bent parts, but a good feel and no slack will be important.
  • 4 weeks later...
On 4/23/2022 at 3:17 PM, 73Ed said:
Amazing build, incredible attention to details..
Do you have any pictures of how you set up your digital cluster behind the dashboard pods?
here are a few images. The dashboard was originally a matte black fiberglass repro and we covered it with carbon fiber.
ABS is working. Really nice to have on track. I'll really get to test it out at COTA on July 15th. I'm now working on a track specific front splitter. The original is fine for street use but the car has some front end lift at speed I'd like to cure. So I'm working with some Klegicell structural foam, plywood, and carbon fiber to make a splitter with some 3D features. I'll also model and print some new canards to fit the new form. The shape is a best-guess from reading/watching as much as I can about the subject along with a little aesthetic constraint.
Right now the shape is just getting worked out and then I'll apply a finishing layer of carbon.
  • 6 months later...
For the most part I've just been driving the car on the track, working out the kinks, and getting used to the car's particular dynamics. The bosch ABS is a game-changer in terms of keeping up with modern cars. It's easy to make any car fast but it's a real art-form to get it to stop.  I did finally get around to working on the new splitter. And I started on a new project to create some "race-fenders"- essentially some fenders to pop-on for track events that relieve a lot of front-end air pressure. Since the body is CF over a tube frame it's easy to swap these particular panels out.
Edited by markrolston@mac.com
forgot pic
  • Like 1
  • 3 years later...
if anyone's still tracking this build I have what might be a last update since the car is mostly done (lol is it ever done?). I finally cad-designed the front fenders and then had a local shop 3D print the parts, then took that to a bodyshop to integrate into the existing fender part and paint it. After that I overlayed the inside walls of it with carbon fiber for added stiffness and protection. I also cut the lower part of the rear fenders and put in a horizontal cf winglet to better extract air. Overall I think it looks great and the resulting new parts helps downforce a ton by extracting air from the wheel wells.
  • Like 3
On 3/16/2026 at 1:47 PM, Jboogsthethug said:
Dang, that looks so tight, turned out amazing! So they printed the part but then used that to make a mold I'm guessing? That's not the actual 3D printed part?
Not a mold. I just left the original 3D part sandwiched between the outer layer of fiberglass, bondo, and paint used for fit-and-finish, and the inner layer of carbon fiber used to ensure the whole part is stiff enough to last.
