- Past hour
SLA S30 Front Suspension Conversion
Zetsaz replied to baby_Carlton's topic in Brakes, Wheels, Suspension and Chassis
There's a reason I defer to "experts" for most things. You can be relatively knowledgeable about a lot of things, but no one can have truly extensive knowledge of more than just a few things. True expertise and experience just requires so much time and commitment. What engine is that?? Very exciting! After many roadtrips in my car and realizing it is fully a street car, I've been brainstorming going fully the opposite direction as you and focusing on making it more comfortable, even if it means moderate sacrifices to handling. - Today
IMSA GTU vintage racer build
Got the sensor figured out. It is idling around 130-140 F. Should be OK. I have to post a video. Sorry but I think this thing sounds bad ass. I have an insert in the exhaust so I dont need earplugs. -
So I took my Z to C&C -150 mile round trip. Engine ran strong but not right. Afrs were off between the banks. Thought I had a sync issue but I believe I have an injector issue. One plug looked rich and that was the bank running rich. #4 valve clearance checked and compression test is good. I've swapped injectors around to see if it follows. Weird thing is the AFR,s smooth out under more load-its worse under light throttle. It seems more than what a small butterfly sync issue , but maybe not . Used my new airbox also. It does quiet down the stacks. Speaking of stacks can someone buy me some TTT horns ? lol My 50's look to small in the box
My late 70s build had an ignition key, and the door keys fit the hatch.
- Yesterday
New lock set or rekeying?
Mike Mileski replied to Mitchel0407's topic in S30 Series - 240z, 260z, 280z
Z cars came from the factory with two keys. One key was for the ignition and rear hatch and the other was for the doors. -
baby_Carlton replied to baby_Carlton's topic in Brakes, Wheels, Suspension and Chassis
Update: after speaking to Cortex and getting some spindle dimensions from them for CAD mockup, looks like I’ll be using their Radial X spindles. Very exciting stuff, I am a bit weary about using aluminum spindles but the car is a track car and last weighed at ~600# over each front wheel so I think I’ll be alright. Thanks! Excited to share my progress with you guys. I’d eventually like to make my work/design open source and see what more talented suspension engineers can do with it. If I didn’t just buy one of these yesterday I’d offer to trade you a complete kit for one of them KN20 heads XD. A bummer indeed, just another bump in the road! Funny you mention Stock Car blade-swaybars. It’s basically all I’ve been looking at for switching over to that design. Plus the parts are pretty cheap & standardized. Thanks everyone. -
jhm started following SLA S30 Front Suspension Conversion
jhm replied to baby_Carlton's topic in Brakes, Wheels, Suspension and Chassis
Wow, cool stuff. That's a real bummer about the AE kit, considering the investment; but I guess this approach gives you the freedom to go wild and do whatever you want! I like your idea of an adjustable blade-style sway bar...this has been on my to-do list for a couple years, and just haven't gotten around to it. You may want to consider the NASCAR-style mounting, above the engine. Makes the adjustment linkages and hardware a lot easier to engineer and fabricate. Good luck with it!! 👍👍 -
Derek replied to baby_Carlton's topic in Brakes, Wheels, Suspension and Chassis
Threads like this make me realize just how ignorant I am when it comes to suspension geometry. I'll stick to castings Great work and welcome back. -
What you're missing is that that the Holley lights have two +12v receptacles and one ground receptacle. The stock wiring harness supplies one constant +12v feed and two switched ground feeds. By using a simple wiring adapter you could make it work with either high or low beams, but the stock switch wouldn't work both High and Low beams properly because all it can do is switch ground on and off. If you didn't want to use his method of rewiring the light switch, you'd have to use two relays to supply 12v High and 12v Low to the LED bulbs, and the common terminal would go directly to Ground. Does that make sense?
bajajoas joined the community
- Last week
And clutch now finally working as intended. Needed to grind the bolt heads down to 0.200inch to keep from hitting clutch rivets. Now have an overheating problem. But I think it's just a sensor reading wrong. Hopefully easy fix. And a small leak in a water hose fitting. Keep thinking I am almost ready for testing but the hit list keeps getting bigger. More pics coming. -
Took the day off to work on the car. Got the front suspension almost complete. Was going to do brakes, but I didn’t get the caliper bolts, thought they came in my BBK. Got those ordered, so should get them on next weekend. -
TR's 260z L28 Build Thread
At long last I finally got my engine bay fuel lines replumbed. Working around the brake lines in a confined space was an adventure, but things look so much cleaner now. It's to the point I need to pull and paint my valve cover, and start dressing things up. It's been interesting watching my fuel temps. I'm definitely going to spend some time seeing how that affects my tune. I have a bit more dialing in to do on pump gas, then I'll swap to E85 and start cranking up the timing. I also got fed up with seeing my voltage go nuts once my alternator was heat soaked, so I decided to finally upgrade from the 280zx 60a to a Powermaster 7294 100a alternator. I went the route of cutting 1.5" off the front of the factory mount, drilling it most of the way for a 10mm bolt, and tapping the backside so I don't have to use a nut. I was already using a turnbuckle for the adjustment, so I'm running the stock belt. I still see a bit of a voltage drop below 800rpm, so I found a 2.125" pulley I'll swap on when it's not 100* out. -
08-21-2025 Day 2 progress pics. Fuel system fully installed and wired up in the rear. Same for engine compartment. One pic you can see I abandoned in place the old fuel lines up in the trans tunnel. You can see the T fitting I installed where the nitrous line can be installed at a future date when I'm ready to melt my engine down. The temp sensor that comes with the Sniper 2 is too large, ONE other company makes one, and it's a very small one, smaller than the size I need to screw in. If I screwed it into a bushing there wouldn't be enough of the probe sticking into the stream of antifreeze to work right, so what I had to do was cut a bushing down on both sides. I tried to thread it on, but it wouldn't budge, so I ground down the threads on the smaller probe and got the bushing (which was now basically a sleeve) to fit over it. I JB Welded it together, and by tomorrow it should be ready to install. Wiring awaits me and some other little do-dad's, and the finish line is within sight. I had to change my air cleaner, as the round one was too high and hitting the hood. No one makes a thin air filter for it.......So I went with the tried and true Edelbrock foam one, and it clears. Here are some pics:
calZ replied to baby_Carlton's topic in Brakes, Wheels, Suspension and Chassis
This is awesome. We haven't had a good engineering project on here in a while, so this is a good to see. -
Weber started following Weber jets??All who live for their triples please read this
Weber replied to datfreak's topic in Nissan L6 Forum
Disclaimer: I haven't read all 42 pages of this post. However, I have read some posts by what seem to be very knowledgeable folks here. Most of what I've read indicates that the throttle plate adjusting screws shouldn't be used to set the idle (like most carburetors), rather the air bypass screws should be used. I'm very early in my Weber tuning path so I used this from the Redline site. Will someone with experience please comment on this? The car runs OK, no stumbles etc. but probably needs work. on mid to top end. Before I head down that path, I want to be sure the basic idle is set correctly. From the "Redline" site: DCOE Adjustment controls Tuning & Adjustment http://www.redlineweber.com/images/Tech/dcoe_a1.gif 1. Critical! Be sure for initial carburetor set up all air by-pass screws should be in closed position. These are not commonly used in standard carburetor adjustment. 2. Set the idle speed screw at ¼ to ½ turn in after contact with throttle lever. When doing multiple carburetors all linkage should be disconnected. All carbs should be bench adjusted to same setting. -
After a 2000+mile trip this summer in the Z I'm inclined to agree with this. Part if me is tempted to go back to stock arms on rubber, are at least all poly instead of some of the heim joints on my T3 parts. The performance benefit of some aftermarket arms is marginal at best. That said, the tension rods might be one place where solid almost makes some sense even on a street car because changes will be more noticeable there under braking.
VQ37 300zx Update #2
Hello all, it’s been a good while since i’ve made any updates towards the build. So after purchasing the CD009 (i’m pretty sure it’s technically a CD1 code…) i’ve been focusing on the teardown of the VQ. I had purchased a low mileage VQ37, from a G-chassis kid, that clearly had been sitting after being oh so delicately ripped out of a G37. Silver lining was an aluminum block, with 93k miles and $900. what he has neglected to tell me was the G-car donor was AWD. Made the odd splined-spindle system in the oil pan make more sense lol. After popping off the oil pan i found maybe 16-18oz of water mixed with the oil. While this would freak any rational petrol-head out, I kinda expected it, due to the top of the engine missing a few coil packs/spark plugs, and being turned over multiple times to check for seizing. So a simple flush of the engine after a thorough inspection of the bottom end should be just fine. All gaskets are getting replaced and heads are already getting resurfaced. The engine is still awaiting removal from the Z31. I just recently was able to get the intercooler system removed, which for some 80’s Japanese-Technology reason is fully attatched to my pre-freon A/C system. A few questions that have stumped me lately, are the input shaft from the transmission (might be completely wrong term) going into the crankcase, are the splines going to fit correctly, or when i mate the transmission to the engine will it be a case of “square peg, round hole?”
Progress has been put on the back burner for the time being, as i’ve acquired another project. I’ve been getting into motorcycles a lot more lately with my father, so next to my ‘98 Buell Thunderbolt, I have purchased my dream project, in a 1989 Honda VTR250 Interceptor in Taco Bell colorway. So my time has been dedicated to getting that little sucker running and driving, then lock myself in my garage for the (hopefully snowy) iowa winter.
Rhanks for reading, if you have any advice or input of any of the above please feel free to reach out! Thanks again
Hazy
Small update, I've moved to a new thread on designing my own front SLA suspension. Regarding the OTS kit from AE, its nice, the tubular front cross member is perhaps the best of its kind on the market. Part of me wishes they used slot-nuts instead of their current configuration but its not a huge deal. Interesting, sorry to hear. I find their rear suspension pretty well designed, the rocker ratio is 1:1 which is not great but nothing you can't fix by making your own. Though for $4000, I feel it should've been disclosed at the very least. Their new packaging system for hardware is great, though their shipping packaging is quite bad. Their customer support offered to replace some parts that were damaged in shipping, need to follow up to check what the ETA on those RMA'd part is. Regards to you giving them feedback, not surprising. I've also tried starting a technical discussion with them that they didn't seem super interested in, understandable they're running a business and are more concerned with keeping the doors open than answering questions from a guy that already paid them lol. These guys are developing kits for a bunch of Datsun/NIssan chassis, and now the E36 chassis so I doubt they have a lot of time for guys like us.
72 or 73 240z Japanese / Euro Tail light wiring
brianZortiz replied to brianZortiz's topic in S30 Series - 240z, 260z, 280z
Oh, I think I figured it out. I do need a 3 wire bulb on the inner upper bulb to make the top two lights as brake lights. Per my first picture the 3rd wire on inner upper would be G which is shared with outer upper and outer lower, this is how early 240z's are. I need to snip top two G wires and run that to the brake output wire which I changed to GY on the picture which is Green / Yellow the color of brake switch output wire. Should look like this to make it work: -
Hi HybridZ, Some of you have already seen my Apex Engineered Track Attack information/discussion thread here, I've decided after reviewing the design of the Apex Engineered front suspension kit, the best solution moving forward is to design my own. In this thread I will be documenting my progress and hopefully gaining knowledge on suspension design from you guys (or from what's left, f**k Facebook groups). To start... Why don't you just use the AE kit? It was $4000, you're just gonna waste $4000??? (Yes) Not enough shock travel, that's pretty much it. Once I received the shocks from Viking I realized immediately that 3.20" of stroke was not going to be enough and thus set out on a fool's errand to find alternative solutions. Viking shocks, from what I've found, have the most shock travel per the physical dimensions of the shock that I've seen so far. They're compact and the adjustment knob is well-designed to take the least amount of space with respect to the rest of the shock body. Very nice, but I will ultimately use either JRi's Mod series DA shocks or Penske's 7800/8300 series DA shocks as now, getting a shock long enough to reach between the strut tower and the LCA is more important. Design (pictured with 17" diameter wheel) The most prominent feature of my SLA design is the UCA pickup being located within the engine bay. The shock tower must be cut and a box structure is welded to the frame rail. This design is based on both the Maier Mod 2 design and Cortex Racing SLA kit seen here: Maier SLA Design Cortex SLA Design The reason I moved the chassis pickup for the UCA inboard was to extend the length of the control arm which should allow for a more compliant spring than the offerings from Apex. Mike Maier inferred the reason for the obscenely high rates was to keep the super short UCA from camming over and ruining the geometry. Fine for a super stiff autocross car but for a road-course car with kerbs, burms, and undulations in the track surface? Unacceptable. With this shock, I'll be looking at around 7-8" of total shock stroke travel. The remaining part of the design lies with the spindle (not shown) and the boxed-structure (also not shown). The boxed-structure was fairly straightforward to design - shout out to @Ben280 for sending me frame rail measurements while my car's been at the body shop. The boxed structure welds to the chassis frame rail located in the engine bay which the cross-shafts then mount to. The spindle is obviously not straight forward, fortunately for me there's plenty of resources on the LocostUSA forums for me to look at as well as Chassis Design and Race Car Vehicle Dynamics by Milliken and Milliken. Once the completed version 1 of the design is done, I’ll begin FEA with a safety factor of 1.15-2.00 at some lateral load to make sure everything should work without buckling. Until then, I have two separate designs, one utilizing Mustang II style cross-shaft mounting structures and one using Maier’s. The main difference being the orientation of the cross-shaft mounting bolts to the boxed-structure with the Mustang II’s bolts facing down, and Maier’s facing sideways. With the bolts facing sideways relative to the longitudinal axis of the chassis, side load is transmitted into the boxed structure through the bolts on their axial axis as opposed to their shear axis. Bolts do not like shear, however the Mustang II design is insanely popular so I suppose I could be overthinking this. Maier Cross Shaft Mounting Design Cortex/Mustang II Cross Shaft Mounting Design Methodology Starting with a 3D scan of the 240z that I re-topologized into ~10000 quads, I modeled an accurate-enough solid body of the fender well and shock tower. From there, I (roughly) modeled the Apex Engineered LCA (will probably try to use the T3 ones I currently have installed on the car as they are boxed structures), the Penske 8300 coilover at ride height, and upper control arm. You may have noticed the bottom of the shock clipping into the LCA, please ignore that, you didn't see that. In regards to swaybars, I will try to get the OEM sway bar design to work with my suspension, however due to the bottom of the shock being mounted on the LCA roughly where the swaybar links, this may be difficult to engineer. I could copy Maier’s LCA design, using a bent-tubular lower arm picture here: Moving forward, it might be easier to design my own boxed structure and try to mount a blade-style sway bar instead. Procurement While there's going to be a lot of custom laser cut metal from SendCutSend, I wanted to keep this kit as OTS as possible. I am not particularly interested in spending buku-bucks on one-off billet parts nor am I keen on dipping my feet into scaled automotive aftermarket product design & manufacturing. That being said, the spindles will likely need to be entirely custom if I can't find an alternative OTS. If I can find an upright on the market that fits my criteria I will definitely go for that, I’m trying to avoid using a Mustang 2 spindle as its shorter than I’d like it to be and completely wastes my steering knuckles and 370z spindles supplied from Apex Engineered (though steering knuckles and spindles are relatively cheap). Next Steps The complete version 1 of this design will be complete soon. Once I've finished my spindle and boxed structures the real work starts, articulating the design through all of its axes of rotation and movement will reveal conditions of binding and the dynamic geometries of the suspension. I started work on this project about a week or two after I placed my order for Apex Engineered SLA kit and have been doing it in my free time which is quite difficult to come by. God willing I shall endure.
Who's Online 3 Members, 0 Anonymous, 1215 Guests (See full list)
