Brad-ManQ45
    9
  1. +1 on the turbine A/R. You also have no idea what trim the compressor section is, so forget it - not worth the money.
  2. Please be aware that a toothed ring is not the only way to achieve CAS w/MegaSquirt. You can use the same types of magnets that Electromotive uses and mount them (epoxied) in holes drilled in the back of the dampener and fab a solid mounting bracket for a Hall sensor, which is what I will be doing. MS can be set up to utilize either VR or Hall sensors, and it's easier to use the Hall sensors - less circuitry. It is the same setup that you would use for the stock distributor, since it's optical (both Hall sensors and optical sensors output a square wave signal, versus a sine wave for the VR sensors, which require signal modification to be a square wave to work w/MS. Doing a 12-1 setup is not that difficult, but you can go 36-1 if you want - just buy more magnets. 6-1 would be the least you can get away with. More magnets = greater resolution. Either way, once you determine where the sensor is to be mounted, and where TDC is, you want the missing tooth to be ~60 degrees ahead of where the timing mark shows TDC on #1 cylinder. This eliminates a lot of hassles with the toothed ring thickness, pulley alignment and having to have the bracket go through the belts so the senso can read the teeth if mounted on the front of the pulleys...
  3. It's gonna be a GM 4L60E and I have a converter from PTC that is around 3K based on what I gave as parameters. Boost onset ~2800, full boost ~3500. Torque @ 3000 ~300 lb/ft. This ought to be fun - basically the same 1st gear as the T5 w/a torque converter - 2nd ought to hit HARD!
  4. Since I am converting my car from a T5 to automatic, I'll leave the linkage the way it is - let the torque converter work for me!
  5. I think that I remember only the 406 and 427 engines were cross bolted. All of the blocks were "Y" blocks w the main rails extending below the centerline of the crank for rigidity though.
  6. I think the wheels look good - and you need to reread the rules about double posting...
  7. I'm 56 and have been in and driven/rented quite a few cars as software trainer all over the US. I have 2 Z's, a '96 Lincoln Town Car and a '94 Q45a. A few years ago my wife was hit in the Q by someone and we rented a 4 cylinder Sonata. It had more leg room in the back than the Lincoln! Great mileage, just as if not more quiet perky acceleration. This was the year that C"&D ranked it over the Camry in a shootout. They have gotten nothing but better since then. Good choice!
  8. Don't know about the rise in temp issue - most of it goes out the exhaust anyway, but if I were to get the tops coated, I'd make sure it is a 3 layer coating. A single layer coating, which is what most everyone not in the aviation/racing business uses will flake of fairly soon. It takes 3 layers with different expansion rates to keep the coatings on the piston. Most expansion on the top layer and work your way down the scale closer to the piston. Swain has their Gold coat that I believe is the 3 layer coating - I hope that's what you got...
  9. Did you take the stock Pop Off Valve off the intake manifold and plug the hole? If you didn't then once you build more than ~7 psi you WILL run rich. I believe you would be better off buying a MegaSquirt or other aftermarket ECU and using the settings that others have already set up for their cars (with the same basic setup ie: turbo size and injectors) as a base point.
  10. I've always put Cibie's on my cars and have loved them.
  11. Looks like you don't have the stock fuel rail behind the bracket on the left side looking from the front. You will want to make sure you have a washer that thick if you aren't using the stock fuel rail.
  12. Nigel is right - only the automatic ZXT's had oil coolers - that's because the load the tranny put on the water cooling system was too much along with the turbo to keep oil cool.
  13. Having been backed into 3 times in 2 years, all by women, I am firmly convinced that putting a car in reverse disengages their brains...
  14. I'm not a professional welder, but have taken classes and just got done welding in 1/2 of a firewall and 1/2 an inner fender panel and fabricating part of a battery tray and welding it in. I could weld about 2 feet in 10 minutes skipping around to keep the heat down. I haven't had your problem so I will tell you how I did my welding and smoothing in the hope that your process will go faster and with better results. I use Harris Twenty Gauge wire. This has to be used with gas, but has a powdered metal core. This is the easiest wire I have used on sheet metal, but I try to always have a piece of flattened copper behind what I am welding held by a magnet to act as a heat sink - once again to minimize heat buildup and in some cases to actually keep the patch in position - nothing like killing two birds w/one stone! If I didn't have to reposition this piece of copper I could weld faster maybe - but then I also might be more afraid of burn through and maybe not get penetration, but I really don't think lack of penetration is a problem with sheet metal... I really don't like using a grinder on sheet metal - used it plenty when building my rotisserie, so I use cut off wheels and flapper disks as suggested already. No big secrets except for maybe the Harris wire. Hope this helps.
  15. I think if Warren has trouble with another turbo he may be following in your footsteps! Nicely done!
  16. I have anautomatic drain for my compressor - it drains every time it shuts off. Got the kit from HF but had to replace everything but the valve and a t fitting to feel comfortable.
  17. You might also want to provide more room for the two slots on the end to expand w/o touching the studs in them - the manifold will lengthen and jam the inside edge of the slot against the stud = leaks and possible stud breakage. I've already ground out the insides of the slots and smoothed/port matched the manifold and hogged out the passage from the first four cylinders to the plenum on mine. I will use stainless studs when I mount it - it is going to get Jet-Hot coated...
  18. Sorry I can't hep you with the Z31 stuff - I decided that I will skip that lame step w/my '83ZXT and go straight to MegaSquirt...more programmability and better ignition/not stock (which has stranded me numerous times over the years - even after 20 minute waits w/hood up).
  19. I use a simple filter/separator/regulator unit that looks like the Sharp one from HF w/no problems, and I have 1 for each of 3 drops. 2 in the garage and one in the basement workshop.
  20. Well, comparing those specs to turbo wheels in the Turbonetics catalog, the exhaust is small and the compressor smaller than the ideal. Ought to have good spool.
  21. I have one bought in the late 70's - must be one of the good ones....
  22. Sounds like somebody didn't tune the MS properly w/a wideband O2 sensor. There is simply no way that Weber's day in/day out all year long (where there are seasons) can run as cleanly as FI. I can imagine w/all the knowledge accumulated about them w/Z cars that you could get a real close to ideal tune from the get-go though.
  23. Don't forget that tire diameter is also a part of gearing and unless flared/tubbed we are dealing with shorter tires...
