28
Everything posted by madkaw
Well don't feel bad guys, it seems to be the major culprit in with ECU issues-OEM and aftermarket. I'd like to brag and say my set-up is working perfect, but if you have read my thread you would see I am still stuck at this point. The direction I went of drilling the flywheel was an attempt to avoid all issue like this, but..... I think once I get my MS wired correctly for my sensor I might be okay. Just got off the phone with a buddy who had all kinds of issues with his Jeep-CPS. It was replaced by the dealer but installed wrong by the technician, so thinking that was not the issue, he spent money trying to fix other things. Turned out that the EXACT procedure for install was not followed which varied the gap ever so slightly and caused miss-fire codes.
Well I went with this issue to the MS forums, but not getting much response. I'm not sure what to expect from the forums being a newbie. So do the DIY pundents or owners respond to issues on the forum, or are the responses by users only? I was hoping for more direct support, but maybe I am missing something. In the end I went with the megamanual instructions without a direct confirmation from anyone really. The issue I am refering to is using the Hall effect sensor and appropiate board changes. It only amounts to jumpering to points and adding a resistor, but I am having someone else do it. I was just hoping that someone on the forum would chime in and say YES, you are correct on your assumption. After looking inside the MS box(which I never wanted to do-ever), I saw items that were too small for me to be comfortable with altering. Big hands, weak eyes, no resistors dictated that I take it down the road. Now I have to wait for it to be done to move on.
Triple Webers and forced induction? Anyone do this?
madkaw replied to a topic in 6 Cylinder Z Forums
From what I have researched you need a box for pressurizing. Not just a 2x4- something to disperse the air evenly thru all cylinders . Ignition control- spend the money on mega jolt or something to make effective ignition curves and save your engine. Better yet, get a MS 2 unit to control everything but fuel, boost, fans, ignition, run a MAP sensor, data logger. Be prepared for a LOT of work and not a lot of support -
Um, it's seems you are saying the exact opposite
This is what I am going by; he gear-tooth sensor is a variant of the hall sensor - the key difference is that it has a magnet built into it and switches when close to steel, no external magnets are required. This makes them very easy to use. These are almost exclusively a three wire sensor. In CAS (crank angle sensor) units a multiplug may be used to combine multiple sensors. The sensor itself acts like a switch to ground when close to steel. The gear-tooth sensor requires a supply voltage which is usually 12V from a fused 12V supply or 5V from the TPSREF output of the Megasquirt. The sensor is then grounded at the Megasquirt and the third wire connects to the tach input. Typical use of geartooth sensor with steel trigger wheel. When a steel tooth passes the sensor it grounds the output. (0V) At other times, the output is inactive. (The pullup in the ECU will make this 5V.) A commonly used sensor is the 1GT101DC from Honeywell. This is rated from -40C to +150C. The Megasquirt board needs to be set for VR input. V3.0 VR+pullup setting - V3.57 VR+pullup setting (Note, that previous Megasquirt versions may have used the optoisolator input, but for better high frequency response with toothed wheels and to match the input on the MS3X card, it is advised to use the VR circuit.) The Megasquirt main board has provision to adjust the trigger threshold on the input signal - these is by two small potentiometers inside the case. These are labelled R52 and R56. Using a small screw driver, carefully turn both about 12 turns anti-clockwise. (There is no dead-stop, but you may feel a "click" when the end position is reached, they can't be damaged by turning too far.)) Then rotate R56 a few turns clockwise.
Okay- did some studying on this no rpm signal. Apparently I have the wrong settings on tuner studio for my ignition trigger setting/ sensor. I am using this http://www.cherrycorp.com/english/sensors/Speed_Direction/gs1001_1004.htm Which I considered a Hall effect sensor, but I guess technically speaking its a VR sensor and that's what MS wants. Not sure how I was getting a rpm signal earlier. I am away from my car so I can't test this, but the megamanual seems to be clear that my sensor is a VR
I had my coil harness on backwards, so the rear coil was firing while testing the front coil--oops. So I get past test mode on the coils and I try and test timing during cranking--NO spark. Then I notice that I have lost my rpm reading--WTF 1 step forward-2 steps back.
Okay-during test mode, when I hit start -the coil buzzes, that was at a ONE coil test. During sequence it still just sounded like one coil buzzing but I had spark plugs attached to the coil wires and PUFF-it lit off fuel vapors in one of the cylinders. I want to check timing during cranking, but I'm afraid the engine will fire off with all the fuel thats in the carbs. So leave off all but number 1 coil wire?
I meant -200 rpm is what my rpms are showing during cranking-is that how fast the starter actually cranks the engine? Also trying to do the coil output test. Do you crank the engine during test mode and how do you know the test is successful? Can I use an advance timing light to verify timing?
I guess my cam input was set to MAP sensor, which is incorrect. Changed it to MS3x and all is right with the world!!!!!!!!!!! IS 200 rpm about right for cranking rpm?
I think I am attaching my tune here-test Well that didn't work
Shooting for complete stock replacement
I am waiting for someone to lend me his dash to take it to the fabricator. The fabricator is finishing up a Porsche 996 CF dash now, looks pretty sweet. I will be interested to see what he says about the Z dash. I told him, it's all or nothing as far as the dash, no cover. I'm also taking a center console to go with it!
I did set it to Event average and still got the message. I can't post up my setting yet. I had to use my sons laptop(windows) to connect with the MS, because my netbook(Linux OS) wouldn't. When I get it back(laptop) , I can post something. He's filling out a questionaire for Harvard, don't want to disturb that Little more background though. I was able to calibrate all my sensors, but need to check to make sure I have the right MAP sensor listed. I had DIY install the MAP Daddy inside the MS3 box, and not sure I have the right one burned to tuner. The water and air temps were reasonable. No rpm signal, but not sure if I have that setting right. I am using a Hall gear sensor, on a 36-1 tooth wheel(drilled flywheel). The AFR gauge is sitting at 14.7, but the megamanual said until the engine runs, it could be anything? Anyways, pretty damn exciting to get this far!
Lenny, i guess I forgot to send my response to your PM on CZCC, but I have that 83 AFM, just need your address.
Help with error message; MAP phase detection requires 1,2 cyl,dual missing, wasted -COP and windowed MAP Not sure what MS is trying to say here. Is it all one error or several errors
Not sure how to answer the wiring question. You should always use relays for high amp stuff. The megamanual will advise you what to use current driver wiring for. MS will control about anything you cam imagine, but can only direct power a few things. I am not using an electric fan.
I decided to tidy up some of my wiring. I had too much wire coming off of my relays and things were getting cluttered around the battery cables. I also got my IAT installed in my CAI(bottom left) and wired up. I ran my 5v lead out to the end of my box for a TPS if I decide to install one on my triples. Cam sensor wire is there too for future install. I installed my hall sensor which you can't see, but it is set -up for sensing the flywheel. Didn't get any pics inside the car, but things are getting tidy there too. With the center console out I took time to shorten and stash wires in better places. It's hard to believe but I think I am ready to go thru the check list to get this puppy started. Waiting on my MS cable so I can plug into my laptop so i can get started on settings
Metro, thanks for the reply. The output wire from the Hall sensor is black--never like twisting a black and white together, but I guess i need too:) Well I was able to at least test the iginition ON with my MS, and I guess I have that wired right since my Wideband came on and so did my fuel pump small victory-I know, but still. The pump shut off after just a few seconds since the MS sensed no rpms. Now waiting on my cable.
Dam the luck, I'm ready to plug in my laptop and i don't have the right harness to do it with-argh
Need help!! Trying to figure out my wiring for my Hall sensor. The MS3x has the sheilded VR/Hall sensor wire with a black and white in the sheilding. So what wire should be signal and which one is ground? I guess I could Assume white is signal, but don't want to assume anything.
ZG Flares in stamped steel or injection molded plastic
madkaw replied to RebekahsZ's topic in Body Kits & Paint
You got a hell of a deal, I paid around 400$ shipped -
Whatever you do or make a copy of- use good templates like Shoukia . I had owned those and the cheapie copies, there is no comparison . Cheapies crack because they don't fit right. Shoukia's just lay up against the body. I wouldn't mind seeing a weld able metal flare though!! -
Quick question re: MS3X and full sequential spark/fuel
madkaw replied to Chris83zxt's topic in MegaSquirt
I like the link Metro put up. I was considering doing the same thing but wasn't sure how I was going to trigger the hall sensor. The tab would work well! I would prefer to do something off of the dizzy shaft just because it would be out of sight , but the hall sensors are small enough it wouldn't matter. I went this route for my crank sensor, but haven't got my MS up and running yet.
