madkaw
    28
Everything posted by madkaw
  1. madkaw
    Ms3x install
    Ben, not sure what you mean as far as digital copies of my wiring. I am going straight off the pages of MS3 manual schematics. As far as a trigger wheel-not tested , but should work in theroy-see pic. I am going to use a hall effect sensor for a direct Flywheel trigger
  2. Maybe, but I have read plenty other threads where the fit was tight. Again, just run the suspension threw its travel before total assembling.
  3. 3800 at 70mph is a big factor. I run 3.90's with the t-5 overdrive and run about 3000 at 70
  4. If the urethane was shredded on the hub side, you have an issue. Fix your issue first, then when you reinstall, check for proper movement of the outboard LCA bushings
  5. I guess I am not recieving messages because i have 200 too many I tried deleting, but it says there is an authorization issue. moderators please delete my PM's
  6. I wish Todd would pop in on this conversation;)
  7. Leon, I guess my message box is full and I can't delete them. s_finnerty1018@comcast.net
  8. Holes in the E-tube or the bleed pipe? How would I go about contacting him? Or is that only through the Yahoo Group? The other interesting thing is that some mikuni's don't even use the bleed pipe.
  9. So I have verified that the emulsion tubes have a 8 stamped on them, but couldn't match that with anything in the catalog. The bleed pipes had a 'T' stamped on it, again, it matches nothing in the mikuni catalog. If I were to temporarily alter the emulsion tube/bleed pipe to start transition from the main sooner, how would or could I do that?
  10. leon, you seem to be saying here what I have seen myself with the Mikuni's.I've been trying fix a problem with transition by oversizing all around the issue. I tried many times to register on the Yahoo group, but never had any luck. I finally just got frustrated and gave up, but it sounds like some good info on there. I would also say cam selection and engine purpose have a lot to do with this. I almost think that the more radical the cam, the easier it would be to tune these 'racing carb' set-ups. My stage 2 cam puts big demands in the mid range which causes a big draw in this transition area, making it tought to tune out. Developing a tune with this carbs for everyday driving situations is a challenge.
  11. I'm a little surprised the OP didn't do the drill trick after the first cam ate it. I did it just out of curiosity and to prove the double oiling method wasn't folk lore. If I had lost a cam, I would have had even more motivated. Since I am posting I am going to throw this out to you guys pertaining to oil pressure issues. If the block oil supply hole WAS enlarged for better oiling but the HG hole was not, would that somehow effect pressure?
  12. It's funny I just happen to pop on this page to see you guys are discussing my same issue on the Mikunis!! Transition- transition- transition I have exhausted all angles to fix my lean issue in the 3500rpm range- sometimes a bit higher. It is only a problem during moderate acc under load. I have been up and down the scale of main air and main jet. I have increased float levels and have changed acc pumps and settings- nothing seems to eliminate this. I can watch my wideband gauge as AFRS climb 16+ or more during this lean- stumble area. The only thing I haven't tried is changing emulsion tubes, but not many options for that. So I am intrigued about this conversation of plugging some of the holes in the bleed pipe. Not sure if Webers are the same, but probably similar enough. I was thinking of modifying the bleed pipe, but wasn't sure of the theory of how it works. So shutting off some of the holes at the top of the bleed pipe should help draw more fuel in sooner??? I couldn't be happier with the way the carbs run everywhere else . Cruise is 14.5-15 and WOT is 13ish Idle I set at 13ish because the car starts best there.
  13. When you tighten down the nut -at the end of the spindle bolt- you should be pressing the large washer against the metal sleeve tight enough to keep it from moving. The urethane bushing should pivot around the metal sleeve. The metal sleeve should be long enough so that the urethane bushing- flanges also have room to move-but not too much to create slop. Make sense? Sounds like you still have some bind somewhere
  14. So there's no option to move the fuseable links forward where you have all that space?
  15. I would disconnect the LCA's from the inboard side and check how the LCA pivots on the spindle. Hopefully your 'repair' on the hub didn't make things unsquare. Did you use a t square or something to make sure the spindle bushing surfaces were 90 degrees flat to the spindle bolt ? The forward and rearward bushing surfaces should also be parallel to each other and perpendicular to the spindle bolt. You might have filed or sanded at an angle .
  16. I would bet your LCA is in a bind. I had squeaks from the same reason. Something's no pivoting correctly and the noise is transmitting everywhere.
  17. Loved it. Sounds as obsessive about his car as I am of mine. My exhaust is not that loud, but duals sound great on these cars- regardless of the fact that it adds weight, not much performance gains, etc... I need to get a video of my car down the road- from the outside listening in:)
  18. madkaw
    Ms3x install
    Got my coil bracket done-almost!! A few loose ends to do, but was excited to see stock LS1 wires worked out well. So no expensive custom sets to make. Got these wires on ebay(stock GM) for 24$ shipped!
  19. Never had read much goo as far as knock sensors, the best one is the two on your head(ears). Guys have made homemade versions using a hearing-aid device they sell on the late night infomercials. Basically using the mic from the hearing aid and putting it in the engine compartment to pick up early signs of detonation noise. Then you where a ear piece or headsets inside the car. Just google and you will find. It seems this device is more reliable then a knock sensor.
  20. Glad to give you your first ride in a Z. Like I said, just add about 50% HP to my HP and that's where you'll be:) Sorry about your bad luck having to go to Hawaii-I really feel for you. I'll be in franklin Monday to pick up a 280zx motor some guy is selling---more power!! Let me know if your still in town.
  21. But the one singular ground point - according to MS 3 readings is better to be the engine.
  22. Good thread to bring up, but not sure about the statement as far as the engine not being a good ground. All the MS stuff I read says to use a good engine ground and NOT the body/frame. As far as understanding ground loops - I am still unsure but reading more everyday. Matt Crammers book on high performance FI discusses ground loops and has some diagrams
  23. I thought of doing the turbo route with my CAI valve cover, but thought better of trying to pressurizing mikuni's. You could use the valve cover with some minor welding by someone else. The tough part will be getting it to seal without having to come with more bolt down points. Not sure if my 6 bolts would seal to a backing plate during pressure.
  24. So no mods to the stock FI? When you get into the power it might get interesting.
