28
Everything posted by madkaw
Questions regarding wire eliminations; I am probably going with PWM idle control and PWM control for additional devices(electric fan, etc..) It seems that the 3X plug should cover about anything i want to run. It doesn't seem like I am using the main plug for much more then powering the MS and sensors. At this rate I am eliminating 14 wires from the main plug-but don't want to short myself. What reason would I need any of the digital outputs or spare pins on the main plug?
Your question is kind of confusing. So you have a p90 head you want to put on a L24 block? I'm pretty sure the p90 is drilled for using the carb intakes, but someone else might chime in. Meanwhile-please clarify what you are doing
Have a driveline vibe you cant figure out? Read this
madkaw replied to 240zdan's topic in Drivetrain
I don't believe that is the point being made here. Certain year DS have NON-replacable U joints. i know the T-5 combo from a ZXT had staked u-joints and they can't be replaced. The OP said they remachined the yokes and installed U-joints-not about shortening the shaft -
Doing "deals " with friends is usually the best way to end a friendship . Rarely works out well unless both parties are responsible and give a shit. Bodywork is $$$ - so you might still be ahead money wise. Look him in the eye and say -"what's up dude ". Ranting here will just get you no where
Thanks for sharing -
DIY front end alignment- what's your method?
madkaw replied to madkaw's topic in Brakes, Wheels, Suspension and Chassis
Doesn't the car need to be on the ground or at least the weight of the car on the tires?? -
I will get this professionally done in the end, but curious what ways you guys have measured and dialed in your alignment? I just changed out a tie rod end and I want the alignment to be close before driving. I have looked at some you tube videos that use everything from string-lines to tape measures. As you know measuring front inside front wheel to inside front wheel has some obstacles. One suggestion was a straight edge on the outside of the wheel and low enough to use a tape measure to measure front to back of the straight edge. I also tried running string line around all 4 corners . I notices that the drivers side front wheel seems to stick out more then passenger side- is the rack adjustable? Maybe some pictures of your measuring devices?
Floor board/frame rail replacement question
madkaw replied to fyanrudger's topic in Fabrication / Welding
I also bolted in the trans mount to keep the tunnel dimension correct -
Are your seat rail supports still there? They will keep things together . If your inner rockers are solid then you should have a lot of movement. I think I welded a support across the floor from trans tunnel to inner rocker because I was replacing seat supports too. My car was also on jack stands. -
I went the Chevy route and bought the Turbo Sonic. Very happy with handling and brakes and would love to spend the 500$ on a ECU upgrade for more HP. My budget crashed at 20K and Ford is pretty proud of their cars. I like the looks of the Ford.
Not a lot of progress, but mother nature has grounded the Z so I have started routing the MS. I thought i would post of some pics showing how far the 8ft harness goes. Taking into consideration that my box is mounted on the trans tunnel and routes out the AC holes in the passenger footwell, the wires still reach all the way to the front of the engine. I'm cutting it kind of close, but I don't think the 12ft wires are needed. Mounting the MS box on the passenger side kick panel would have gained me another foot of wire if needed. I'm going to wrap the unused wire up as shown and just hand them out of the way behind the blower motor. I was able to route the sensor wires behind the heater box to the drivers side and they will go thru the firewall at the choke grommet. Next I need to make a grounding strap/bar that will be attached at the block where my coils attach. I am thinking of making a copper strap that fits inside my coil bracket that I will attach all my ground too. There isn't a whole lot of options when it comes to direct grounds to the block.
As said- probably Harrington Group. I bought a rear bumper last year from them. Those are a STEAL at 350$ each. I paid 700$ just for the rear. The fit was very good- but not perfect. Watch out because the SS is very thin and the bumper will ding if you just look at it wrong . The finish is very close to chrome and most won't be able to tell the difference. Plus consider that QUALITY rechrome of a stock bumper will cost you 300$ +
I've been talking with a local guy that does CF parts. I would only consider asking him to make one that is a complete replacement - not a cover. If you are going to all that trouble to make a mold for the dash, do the whole thing and save weight
I'm about to finish up mine. If it works out I might make another since I have another piece of aluminum. I'm in the process of wiring now so I want to see how that works out with the bracket. This winter should provide plenty of work time on the Z
- 17 replies
- megasquirt
- ms3
(and 3 more)
Tagged with:
Chris, What did you come up with for your d585 mount? Pics?
- 17 replies
- megasquirt
- ms3
(and 3 more)
Tagged with:
Thanks for sharing. What are you using to trigger from the cam to make full sequential?
- 17 replies
- megasquirt
- ms3
(and 3 more)
Tagged with:
Hate to see that nice ride torn up. E-mail me and send you pics of a door I have. S_finnerty1018@comcast.net
I am assuming you are referring to the rear flanges that were original meant for the drums. I didn't even measure mine, I just took the stub axles off and sent them to the machine shop to have machined. I figured Arizona Z knew what they were doing , so I didn't question it. I don't think much had to come off and I haven't had any issues. Measuring .003 out of flat on the flange will mean that further out on a 12" rotor -it will be worse. It's a PITA , but you probably need to do it.
I wouldn't spend a lot of money for an original shaft when you can probably have one made for around 300$. The OEM DS has non -replaceable U joints. You will also have to have the diff yoke from the ZXT r200 to mate with that DS.
It's always too slow isn't it?! Looking good.
Have you verified your timing with a light- total advance ?
