madkaw
    28
Everything posted by madkaw
  1. I think I used the inner and outer boot from the t5 . Nice heavy boots that insulate sound well and fit my aftermarket shifter very well
  2. Must be nice to be just down the street from rebello.
  3. Jon, Appreciate you staying with me on this. I will revisit and verify what you have said. I don't know if you remember but I was running a heim joint set up that connected the rear control arms. I did this to clear a r200 LSD fin cover. The heim joints were connected( welded via a stud) to the rear cap bolts of the LCA. These joints made tie adjustments possible, but I am thinking that my design might be part of the issue. I no longer need this since I am running the Subby r180 , so I am going to put back the stock bracket , relube everything and slap it back together.
  4. Sorry Leon that didn't help. To me, the fact that the inner sleeve doesn't rotate causes axial load on the bushing. I guess I wonder why the urethane isn't just made the same ID as the control rod mounting point. Sorry I'm so dense on this guys
  5. You say the sleeves are longer off the car, but it's bad if they are longer on the car?
  6. I guess I learned something today about bushings. I was really thinking it would be better for the sleeve to rotate because you wouldn't want any binding of the ID of the urethane against the sleeve . Having a hard time wrapping my head around it for some reason.
  7. Okay guys, help me out here. I took off the rear control arms and suddenly noticed the length of my inner bushing sleeve( steel sleeve) was longer then the control arm pivot. So that tells me that my sleeve is not rotating on the control arm because it is locked in place by the cap bolt. I guess I have the wrong ones ? I'm going to trim the sleeve down and put it back together. Comments?? Also, talked to a buddy who said his urethane bushings on the rear control arm( inner) is one piece where mine is two pieces. What do you guys have.
  8. I think I'm going to give that a shot. I remember installing them and the tolerance was so tight on the steel sleeve that it seemed that the supplied lubricant just squeezed out when assembling. I think length wise groove(s) coming off the zerk would help. It would be great to have another set of fine grooves running around the bushing ID to spread the lube around. I always wondered how well anti-seize would do. I have this permatex shit that won't hardly come off your hands if you get it on you. By the way- I have a loud exhaust and stereo- still not cutting it.
  9. I'll second Leon's comments for Clive. Getting rid of those wires sure looks great and very clean!
  10. This has been covered on a thread before. Not telling you to search, but it was dealt with in detail before and I don't have an accurate answer for you.
  11. Looks like a 1.25mm HG is in order to get you in a good spot. Did you shave any off the block?
  12. That's exactly what my machinist did- didn't know if I got that across in my explanation or not. Some of my rockers were off .014 + in that little area , I should say most if them were off some what and 2 were off really badly. You can actually see the wear pattern on the cam lobes too. Great video and thanks for posting
  13. Well crap- the inner LCAs are the ones that make all the noise I believe
  14. Thanks for the ideas and links. So I guess I will have to clean off all that sticky shit that's on there now and trim the bushings? I will look at the link provided since you said it had pics. I can deal with the harsher ride, but I can't deal with my car sounding like a jalopy going down the road.
  15. Thanks John, I'm about ready to go back to rubber. I think I would be willing to give up the small amount of handling to have back some cushion and no squeak maintenance . There's nothing like having a sweet ride that sounds like a wagon
  16. I know this isn't old news but... I have black bushings that I purchased many years ago. I have read the black ones are graphite impregnated , but is that true with all? I have re lubed the bushings with lots of lube and after a while they squeak again. Is there a way to tell visually that they have graphite?
  17. My set up will use stock 5.3 wires. I will eventually get a pic of it. Wherever you put them it seems there is hardly enough room!
  18. Thanks for the ideas guys. Dan, I've seen setup s like yours before. Only thing I don't like is having all the harness above the coils. I'm working on an aluminum 2" square bracket that bolts to the block where the heater hose attaches. It's a shame those 585 coils are such a funky shape, it makes it a challenge to set up
  19. Would you share how you mounted your coils also? I am attempting to mount the d585 truck coils myself and using MS3x to run everything. I think I have my coils mounted worked out but would like to see others
  20. http://www.ebay.com/itm/2002-2004-Ford-Mustang-V6-3-8-3-9-OEM-Stock-60-mm-Throttle-Body-w-TPS-Sensor-/230777068197 This looks like a great candidate. Genuine OEM with sensor
  21. Exactly. Modulation at the tip in of the throttle gets harder to control because even a slight throttle increase of a large TB is letting in a lot of air. Not a problem if you are always flooring it:) but as a daily driver might be hard to dial in .That's why I asked about the driving characteristics of your car. What TB are you using?
  22. Glad to hear the 70mm is working well for you. Can't tell if your serious or not with the Tip-in comment, but I am guessing you are not having any drivability issues with your set up. No issues easing into the throttle or any transitional throttle issues? 70mm is overkill from a math standpoint based on engine size.
  23. Say what? You should always check for 0 ohms before measuring. Never heard of testing or measuring the tester leads. Then you better test the tester that tested your test leads:0 You have a stock coil to try out as suggested?
