Zipper
Everything posted by Zipper
Greg Ira returning to SCCA Run-Off's for another title bout!
Zipper replied to AydinZ71's topic in Announcements
Will miss the orange 240Z, but good luck Greg! -
Slow reply - Yep, I used TTT tie rods too. They have both right/left and right/right thread options, so check what's on the car. Have to drill steering arms. Adding parts could help, but you need a patient alignment tech too. Problems move around as you add parts (compromises). I also have out-of-whack rear toe, too much and uneven left/right. I think I can feel that at the track. I'm interested in adjustable arms rather than bushings.
jgkurz - You mention 'dartiness', also lowering springs and bump steer spacers. Have you considered bump steer? Hybridz bumpsteer-faq Not a suspension expert - but I experienced a big improvement in handling feel with similar mods to you after changing to adjustable tie rods. On alignment rack, toe changes were obvious by ratcheting suspension down/jacking up. Was able to tune a lot out with adjustable tie rods. Bigger tires, quick steering arms, and a smaller steering wheel contribute to heavy steering feel.
Stance coilover kit, front woes :(
Zipper replied to sileightygx's topic in Brakes, Wheels, Suspension and Chassis
Check with cgsheen on this site, maybe get some pics. Something sounds odd to me I have these on my 260z and there is a huge range of adjustment - think I could lay the rails on the ground if I wanted. -
Same. I got new seat belts from Wesco Performance - the roadster type. I used this approach to install 350Z seats - cut off extraneous stuff and weld cross members, use S30 rails: http://forums.hybridz.org/topic/103970-another-350z-seat-install-for-tall-people/ Super comfortable for me - but went to a track day and my helmet hit roof hard, so I have them fixed position, bolted straight through the floor now. Cut more from seats to get them as far back and low as possible and removed the sliders.
Here's another thread talking about a 'K' stamped P79 http://forums.hybridz.org/topic/57930-how-much-is-a-shaved-p90-worth/ That stamp isn't listed on the Atlanticz cam specs page. I just looked at couple heads I have here - have a 'B' marked P90 from a turbo (expected). And my P79 is blank. That 'K' looks like a similar font/marking style as the stock 'B' on my P90. My 260Z also has a F54/P79. Get it running (but maybe without the flat tops).
OBX Differential for R200 Open Diff to LSD Conversion
Zipper replied to Saxofonist's topic in Parts Wanted
I think they're on Amazon? R200 "longnose" is standard R200, no? I think shortnose has different requirements, but the OBX for R200 should work for your diff I would think. (Disclaimer: Don't have an OBX, have an MFactory). -
280z dual duty brake setup suggestions
Zipper replied to mforget's topic in Brakes, Wheels, Suspension and Chassis
Interested too. Someone will point to the FAQ thread (http://forums.hybridz.org/topic/39435-help-what-brake-options-are-available-for-s30-z-cars/). But it was started in 2005 and is out-of-date. Silver Mine has a bunch of options now, for example, and solid reviews from experience are tough to sort out. But clarify your requirements. You talking about road racing "track"? 20 minute sessions, concern over fade, etc.? I've been using the stock brakes with Motul and Porterfield R4S pads at track days - but I still have to bleed between sessions or can lose a lot of bite. Also think the pedal feel with stock drums is wooden and requires frequent fussy adjustments. Like the idea of rear discs providing better feel and power. -
I paid $825 shipped. You interested? No, didn't think so. Just posting for smells apparently.
Satisfied buyer here in the Group Buy thread. No mystery, no foggy. I bought what was advertised and got it. Am pleased with my product and factory warranty. You have no intention or interest but are shitting in the thread. Frankly think it violates forum rules. That's clarity.
exlifesaver posted two weeks ago congratulating a successful install post by an endurance racer. Why questioning his thread? I bought the MFactory diff a few months back. exlifesaver easy to deal with. Arrived in 2 days! Install was straightforward - swapped out open carrier and added new carrier bearings. Measured 0.001" additional backlash after install with same shims, etc. So far so good. Have been to the track twice since and really liked the change - still learning how to use traction, especially to pick up throttle earlier in corners without inside tire spin. On a really hot/greasy day I set a personal best at my local track - beat it by a few 10ths on a day where others were off 1.5 seconds or more. Only other change was CV axles installed at same time.
Genius! (fear no spindle pin). Get an aviation tech with his pliers and it's perfect.
"Tighten all Grade 8 bolts to 35 ft/lbs. These bolts have a cross drilled head for safety wire." Nuts mounting adapters to stub axle and companion flange specify 50 lbs. Let me know if you need more info or a scan or something. That hub side safety wire about kills me. I'd like a lift, drop control arms for access, and an aviation tech to do the work.
Fuel Tank-Fuel Starvation in left turns
Zipper replied to gira's topic in S30 Series - 240z, 260z, 280z
Struggling with this issue with my early 260z - starvation and fuel pump cavitation at anything under half a tank at track days (with my modest street tire G's). But no real problems on the street unless a very hot day - can go to below 1/4 tank no problem. I'm suspicious of pinholes/leak in my pickup tube. My tank is coated. Have been thinking of a solution like this, but trying to keep fuel gauge sender - like a replacement pickup via bulkhead next to the sender for wrench access - maybe a Holley hydramat on end of pickup. Are bulkhead fittings reliable? Next option is significant rework of tank - chopping, drop-in pump with baffles, etc. A lot more work.- 11 replies
- Fuel tank
- fuel delivery
(and 1 more)
Tagged with:
Need pics of A/C with dash removed please.....
Zipper replied to Ken Smith's topic in S30 Series - 240z, 260z, 280z
Just came across this pic - probably not informative, but a reminder of how bad things can be... rock bottom of my interior project: -
I have faith that Derek will easily half that price. ***complex milling sounds***
What a neat product idea, perfect for the hybridz restomod set. Like to see some more pics on how the injector rail (lids) work. "Sir, we're gonna need you to roll into tech inspection here. Couple protests on your weber setup."
- 17 replies
- SURGE TANK
- TURBO
(and 4 more)
Tagged with:
Techno Toy Tuning Tie Rod
Zipper replied to Keepn it OG's topic in Brakes, Wheels, Suspension and Chassis
With the T3 tie rods, I believe you must drill out your steering knuckle (even your nice Nissan race/european quick ratio ones, dammit). Just haven't heard any first person feedback on how they worked, sufficient threads for widened stances, etc. https://technotoytuning.com/nissan/240z/outer-tie-rods-datsun-240z-260z-and-280z -
Yes - Techno Toy Tuning = T3 (TTT!) Original question was about tie rod ends, but some comments seem about tension control rods and other bits. Interested about the tie rod ends and ability to tune for bump steer on lowered cars. -
Bumping because I keep noticing WTB replies from zero/low post users offering exactly the rare item needed. Also see a lot of scammers posting randomly to increase their post counts. I'm a low post user myself, and have benefited from buying from members. But seems like a reply to a WTB thread is pretty much the same as a For Sale offer, no? Any thoughts on restricting WTB replies?
There's some pics here at this link that might be helpful if you poke around. Like this:
What are these wheels?
Zipper replied to endofzworld's topic in Brakes, Wheels, Suspension and Chassis
Look like Shelby Mesh maybe? I had a set came with my 260Z, live on a 510 now. http://community.ratsun.net/topic/48417-14inch-shelby-mesh-rims/ -
Twin cam head for the L6 from Derek at Datsunworks
Zipper replied to Derek's topic in Nissan L6 Forum
Fantastic achievement, Derek! I'm sure there's more R&D to come, but a great milestone. And no chain thrown! More please
