Everything posted by morbias
240z lower quarter panel replacement. Yay or nay.
morbias replied to 5 Star Rising's topic in S30 Series - 240z, 260z, 280z
Keep in mind the jacking point strengthening panels are inside the dog legs and could need replacing if they are rotted. As far as I know, repros aren't available so they would have to be fabricated. -
Tachometer illumination issue [Solved]
morbias replied to Oblithian's topic in S30 Series - 240z, 260z, 280z
This. I swapped my dash bulbs for leds, pretty sure a couple of the sockets were wired the 'wrong' way around for leds. I ended up pulling the ends off the leds and soldering them back on reversed rather than rewiring the sockets. -
A bit further up the page you mentioned you don't know what engine setup you have or what sort of needles you have installed; that's pretty critical with regard to your issue tbh. You really need to hook up a wideband O2 sensor and AFR gauge to figure out what's going on, or even just take the car to a shop and see if they'll hook up the gear they use for the emissions test while you rev the engine. That would at least give you some rudimentary idea of if the carbs are leaning out further up the rev range - if they are then no amount of fiddling with the carbs is going to fix it and you probably need different needles, assuming the carbs are in good working condition and don't have hidden issues like worn throttle shafts.
Without reading the whole thread again, I would suggest checking the ignition system including strength of the spark, whether you have the correct weights and springs in the distributor, whether the variable timing plate in the top of the distributor is moving freely, if the vacuum advance is functioning properly. It also might be worth checking your valve clearances if you haven't already.
I agree with what you're saying re the drip rail, but there is an added potential for a bolt to break the surface layer of the stainless and the paint layer on the mild steel so it acts as a conductor. Also, the potential for battery acid to get between the layers greatly increases the probability of a conductive environment forming.
I personally wouldn't even risk bolting it in to be honest, stainless steel contacting mild steel will result in the mild steel rusting at a faster rate than normal.
morbias replied to k3werra's topic in Brakes, Wheels, Suspension and Chassis
They look like Momo Altairs, no idea what they're worth though. -
Are your door bumpers missing? They should be fitted to the lower rear corners of the door openings, if they're missing then that could possibly cause this issue, though I would have expected the door rubbers to be enough to stop the doors moving when closed. Are they the correct weatherstrips because new weatherstrips usually cause the opposite problem where the doors are hard to close!
Is it backfiring through both carbs or just one? Backfiring through the carbs can be caused by a lean running condition, if you have a white plug then it would suggest you are running lean on that particular cylinder for some reason. Perhaps the manifold gasket isn't sealing properly and is letting excess air in to that cylinder?
Might be worth checking the back of the fuse box itself to see if there is a problem there.
Worn hinge pins perhaps?
Floor replacement questions. Which way is best?
morbias replied to robotbbq's topic in Fabrication / Welding
The floor is supposed to move the driver/passenger away from a side impact, so I would have done full welds on the sides and spot welds along the front and rear to best mirror the original design. Agree with above though, that welding job does not look the best - also, the beads holding the frame rails on seem to be few and far between. -
The factory mustache bar is supposed to have that twist in it. Are you sure you have the correct T3 bar because they make 2 'stock' versions, one for the r180 and one for the r200? Also, have you tried bolting the original diff in with the T3 mustache bar, that will tell you right there if the bar is the problem.
- 28 replies
- differential
- rear suspension
(and 4 more)
Tagged with:
ST front sway bar clearance question
morbias replied to madkaw's topic in Brakes, Wheels, Suspension and Chassis
The amount of droop is determined by the length of the shocks at full extension and if you are using roll center adjusters that will also increase the angle of the anti-roll bar towards the sump. Also, using stock strut mount insulators instead of aftermarket top mounts with spherical bearings will also position the control arm lower. -
It sounds like you have an early style rail, if you search google for pictures of 240z floors you'll see why it's a different shape.
What you need to do is check how bent the chassis is and which direction, there are measurements in the 'underbody alignment' section in the fsm. Doing what you're doing now (trying to correct symptoms of the problem rather than addressing the root cause) might actually make any eventual repair process more difficult.
Mysterious spacers for front suspension
morbias replied to ReeNerf's topic in Brakes, Wheels, Suspension and Chassis
Shock packing washer? Or a shock valve plate perhaps? -
New to me '74 260z has a very bumpy ride...
morbias replied to ZMONSTR's topic in Brakes, Wheels, Suspension and Chassis
If the car is running standard length shocks and un-sectioned strut tubes then it's definitely hitting the bumpstops - you can pretty much tell this purely by looking at the angles of the control arms in the photos. -
Short to ground somewhere?
In that case they probably wouldn't be ruining it with an ugly body kit
This might be helpful for figuring out which needles you should go with: http://www.mintylamb.co.uk/suneedle/ KL, BAR and BDL needles are good starting points for L24-28 engines
Brakes have me lost...
morbias replied to Volition77's topic in Brakes, Wheels, Suspension and Chassis
Going back to your original post you say "...have got it to stop leaking for the most part" Maybe this is the problem, the brake hydraulics have to be a completely closed system; any small leak will suck in air so there's not really any point doing anything else until you've fixed the leak properly. -
I saw your last video on YouTube, it sounds (and looks) beastly!
