Miles
    37
Everything posted by Miles
  1. Looks like you have it sorted out. Hope the following will be helpful: If doing a V8 swap buy the Jags that Run (JTR) book and read it at least ten times. Book is useful for any engine swap. Buy books/manuals for the engine and transmission you want to use. Download a Factory Service Manual (FSM) and buy a Haynes repair manual for your specific car. Download electrical schematics for your car. PDFs are easier to read than those found in books. Some are in color. Buy the book How to Restore Your Datsun Z Car by Wick Humble. It will save you hours of searching for "how to" info. Focus on searching Hybridz as 99% of questions have already been addressed. Make a detailed plan with parts list including cost before starting a project. Plan every system of the car. Start bookmarking Z car parts suppliers - there are many! Remember these are 40 year old cars and will need restoration to be safe and drivable. Join ClassicZCars.com website and search there as well. Become well informed about modifications before asking questions. People will be more inclined to answer informed questions. Have some money. I stopped counting after $12k. Read the new member FAQs. The engine swap is the easy part. It is understanding the details like brake fittings, adapters, drive shaft angles, brake system, automotive electronics, wheels, suspension and etc. that makes or breaks a build project. Recommend that you buy a running Z car and drive it stock for a awhile. Do basic maintenance brakes, suspension, electrical etc. so you have a ready to drive platform when you finish the engine swap. Useful Links: http://zhome.com/ http://www.atlanticz.ca/ http://www.classiczc...com/index.html/ http://www.zcarparts.com/ http://www.blackdrag.../zZxCatalog.htm http://www.arizonazcar.com/ http://www.jagsthatrun.com/index.html
  2. Here is a rear bearing replacement tutorial posted at http://atlanticz.ca/zclub/techtips/rearwheelbearings/index.html I prefer using a press instead of hammering the bearing in place as shown in the tutorial. John is correct. Be sure the seal is seated all the way into the hub. Even when the seal is seated it still drags on the companion flange some, but there should be no binding or force needed to turn the stub axle.
  3. KidandhisCar Something changed after you did the brake upgrade. Sort out what changed.
  4. If you find some used stub axles, also check the runout on the wheel mounting flange of the stub axle. The flanges are soft and can be bent just hitting a curb. Not much of a problem with drum brakes, but with disk brakes the warped flanges can cause the the brake pads to rub on the rotors. The flanges can be machined if they are not bent or warped too much. Caused me a major headache with rear disk brakes overheating. After checking the runout of the flanges I replaced the stub axles with these: http://www.chequeredflagracing.net/Datsun.html See pictures for typical stub axle failure points.
  5. Trust but verify always. I reused the distance piece with the new axles I got from Modern Motorsports (Chequered Flag) and had no problem. They probably assume that the buyer knows to reassemble the axle using the original spacer.
  6. You may need to disassemble the stub axle and make sure the bearings are seated or that you didn't leave out the spacer. Note that the spacers are matched to the hub. See attached pictures from the FSM.
  7. Welcome. The answers to your questions will be found in the various forums. Suggestions: If doing a V8 swap buy the Jags that Run (JTR) book and read it at least ten times. Book is useful for any engine swap. Buy books/manuals for the engine and transmission you want to use. Download a Factory Service Manual (FSM) and buy a Haynes repair manual for your specific car. Download electrical schematics for your car. PDFs are easier to read than those found in books. Some are in color. Buy the book How to Restore Your Datsun Z Car by Wick Humble. It will save you hours of searching for "how to" info. Focus on searching Hybridz as 99% of questions have already been addressed. Make a detailed plan with parts list including cost before starting a project. Plan every system of the car. Start bookmarking Z car parts suppliers - there are many! Remember these are 40 year old cars and will need restoration to be safe and drivable. Join ClassicZCars.com website and search there as well. Become well informed about modifications before asking questions. People will be more inclined to answer informed questions. Search the forums. Have some money. I stopped counting after $12k. Read the new member FAQs. The engine swap is the easy part. It is understanding the details like brake fittings, adapters, drive shaft angles, brake system, automotive electronics, wheels, suspension and etc. that makes or breaks a build project. Recommend that you buy a running Z car and drive it stock for awhile. Do basic maintenance: brakes, suspension, electrical etc. so you have a ready to drive platform when you finish the engine swap. You will learn a lot about auto mechanics and how the Z car functions as well. Useful Links: http://zhome.com/ http://www.atlanticz.ca/ http://www.classiczc...com/index.html/ http://www.zcarparts.com/ http://www.blackdrag.../zZxCatalog.htm http://www.arizonazcar.com/ http://www.jagsthatrun.com/index.html
  8. I wonder if Dave would be willing to say who his supplier was for the AZ "heavy duty" spring set. I have used them on two street V8 240Z cars and liked the stock height and the spring rates.
  9. You could join your local Z club(s) and ask for help. Z clubs = parts
  10. Suggestions: If doing a V8 swap buy the Jags that Run (JTR) book and read it at least ten times. Book is useful for any engine swap. Buy books/manuals for the engine and transmission you want to use. Download a Factory Service Manual (FSM) and buy a Haynes repair manual for your specific car. Download electrical schematics for your car. PDFs are easier to read than those found in books. Some are in color. Buy the book How to Restore Your Datsun Z Car by Wick Humble. It will save you hours of searching for "how to" info. Focus on searching Hybridz as 99% of questions have already been addressed. Make a detailed plan with parts list including cost before starting a project. Plan every system of the car. Start bookmarking Z car parts suppliers - there are many! Remember these are 40 year old cars and will need restoration to be safe and drivable. Join ClassicZCars.com website and search there as well. Become well informed about modifications before asking questions. People will be more inclined to answer informed questions. Have some money. I stopped counting after $12k. Read the new member FAQs. The engine swap is the easy part. It is understanding the details like brake fittings, adapters, drive shaft angles, brake system, automotive electronics, wheels, suspension and etc. that makes or breaks a build project. Recommend that you buy a running Z car and drive it stock for a awhile. Do basic maintenance brakes, suspension, electrical etc. so you have a ready to drive platform when you finish the engine swap. You will learn a lot about auto mechanics and how the Z car functions as well. Useful Links: http://zhome.com/ http://www.atlanticz.ca/ http://www.classiczc...com/index.html/ http://www.zcarparts.com/ http://www.blackdrag.../zZxCatalog.htm http://www.arizonazcar.com/ http://www.jagsthatrun.com/index.html
  11. BTW have you looked at seat swap threads in the interior forum? Lots of seat info there.
  12. MSA SELLS A "RETRO" seatbelt that bolts in the stock location.
  13. To be clear, the Z belts attach to large bolts behind the seats. The body is reinforced where the bolts are located. The seats are bolted to sheet metal suports.
  14. Are you aware that the Z seats are only fastened to the body with four small bolts through sheet metal? The seat would simply rip out of its' attachment points in an accident. Note that the Z seat belts are attached to the body with large bolts. What ever seats and seat belts you decide on, use the stock attachment points.
  15. Hope you will find this helpful: If doing a V8 swap buy the Jags that Run (JTR) book and read it at least 5 times. Book is useful for any engine swap. Buy books/manuals for the engine and transmission you want to use. Download a 240z Factory Service Manual (FSM) and buy a Haynes repair manual for your specific car. Download electrical schematics for your car. PDFs are easier to read than those found in books. Some are in color. Buy the book How to Restore Your Datsun Z Car by Wick Humble. It will save you hours of searching for "how to" info. Make a detailed plan with parts list including cost before starting a project. Plan every system of the car. Start bookmarking Z car parts suppliers - there are many! Join ClassicZCars.com website and search there as well. Useful Links: http://zhome.com/ http://www.atlanticz.ca/ http://www.classiczcars.com/ http://www.zcarparts.com/ http://www.blackdrag.../zZxCatalog.htm http://www.arizonazcar.com/ http://www.jagsthatrun.com/index.html
  16. I installed higher wattage bulbs and removed the green filters in the gauges. Bright white now.
  17. Seattlejester: Too much caffeine this morning? Watch John Belushi https://video.yahoo.com/weekend-john-belushi-march-000000303.html
  18. There seems to be a good inventory of Z cars in the in Francisco Bay area. Purchased two 240Zs there.
  19. No way that car is worth $6000. You can get an unmolested 240Z for about $3000 that runs and drives. Don't make an offer. Walk away.
  20. Pictures of typical stub axle failure points.
  21. Access to a heat treat oven where the temperature could be controlled would be ideal. Opinion: personally, I wouldn't use heat unless you absolutely can't get the cover to seal.
  22. Ditto RebkahsZ. Bent stub axles can cause problems. I found that slightly bent stub axle flanges on my 240Z with 240SX rear calipers caused the pads to drag. Didn't catch it until I checked the run out on each stub axle flange. I had the flanges machined, but they were too far out. I ended up buying the Chequered Flag stub axles and all has been well since. Remember the 240Z stub axles were designed to work with drum brakes so flange run out wasn't much of a problem.
  23. You may want to consider these stub axles: http://www.chequeredflagracing.net/Datsun.html
  24. Could just be that the bearings need to be replaced. Also, check the runout on the wheel mounting flange. The flange is soft and can be bent hitting a curb. A bent mounting flange would cause the wheel to wobble. Of course, check all of the rotating assemblies such as the drive shaft, half-shafts etc.
