37
Everything posted by Miles
Could just be that the bearings need to be replaced. Also, check the runout on the wheel mounting flange. The flange is soft and can be bent hitting a curb. A bent mounting flange would cause the wheel to wobble. Of course, check all of the rotating assemblies such as the drive shaft, half-shafts etc.
Save yourself a bunch of problems and just rebuild the stock brakes and keep them well maintained.
Undoing aluminum valve cover warpage
Miles replied to seattlejester's topic in Fabrication / Welding
^^^^^^ what Z240 said. Return them. -
Note he said: I want to say it looked like maybe 1/4 or 3/8 of an inch in the middle with the two covers being held flange to flange. Holding the valve covers flange to flange does not give a true picture of how much the cover is actually warped. He needs to place the covers on a flat surface and measure how much the flange deviates from the table. -
You might try Permatex Right Stuff gasket maker in addition to whatever gasket you choose. I use this to seal the front and rear gaps on SBC intakes. http://www.oreillyauto.com/site/c/detail/PER3/25229/N2362.oap?ck=Search_N2362_-1_-1&pt=N2362&ppt=C1984 -
If you lay the covers on a flat surface how big is the gap between the surface and the cover? 1/16", 1/8", 1/4" ?? Pictures? -
I had a the same problem and used a thicker gasket. A Felpro as I recall. And a set of valve cover clamps like these: http://www.summitracing.com/parts/mrg-9817 -
Perhaps the Nissan engineers wanted the pads to ride closer to the rotors for better brake feel??? Are the 240Z and 280ZX calipers of low drag design (piston retracts further into the cylinder)? That might explain the residual pressure valves in a master cylinder used for disk brakes. GM came out with low drag calipers in 1980 where the piston retracts further into the cylinder. This requires an extra squirt of fluid to get the piston moving towards the rotor. So they had to design a "fast fill" master cylinder to provide the extra fluid volume. Google "fast fill master cylinder" and "low drag caliper." Some of the hot rod guys using fast fill GM calipers resolve their "low brake pedal" problems by installing 10psi check valves in the brake system.
http://www.zcar.com/forum/10-70-83-tech-discussion-forum/115265-removing-interior-trim.html
I have talked with Wilwood engineers in the past. They were very responsive helpful. Give Wilwood a call. It would be interesting to see if they stopped including the residual pressure valves for some reason. When I did the Wilwood 1 inch install a few years ago I ran the the car with the valves in place for a month and then without the valves for a month and there was no difference. At the same time I looked at some old 280ZX MCs and there were residual pressure valves in the front and rear outlets.
Check out Zcarnut's Wilwood thread as it shows removal of the residual pressure valves. They block returning brake fluid through the action of a spring and rubber stopper when the returning fluid pressure drops to a preset level (e.g., 2lbs psi). http://forums.hybridz.org/topic/102754-a-one-inch-diameter-brake-master-cylinder-for-the-s30-z-cars/
Brake switch. Brake switch adjustment. Short in the wiring. A broken turn signal switch (brake light wires run through the switch). Check the simple things first such as the brake switch adjustment and the brake switch. The brake pedal in the up position pushes the brake switch open (no power flowing). When the brake pedal moves forward the brake switch springs to the closed position turning on the brake lights.
The 72 240Z has the PV in the back (see picture). If you have installed a PV in the back then the stock PV should be eliminated or gutted out. The device under the MC is a hydraulic differential pressure switch. It is not a PV. It also serves as a distribution block. If there is loss of pressure in the front or rear brake circuits a shuttle valve inside moves to the low pressure side blocking loss of fluid and at the same time grounding the wire that turns on the red brake light inside the car. The switch is NLA and there are no replacement parts for it. Every one of these I have opened up the shuttle was frozen in the neutral (middle) position. Don't mess with it. See pictures. Push rod adjustment: The push rod should be almost touching the bottom of the cup at the end of the MC piston. For a starting point see attached picture. Too far out and your pedal will be long and grab when engaged. Too long your brakes will lock up. As a starting point, you have to measure from the tip of the push rod to the face of the diamond shaped spacer 0.53" or 13.5mm. Mine usually ended up somewhere between 14mm to 15mm after several adjustments and road tests. When adjusting the push rod be careful not to drop the reaction disk inside the booster.
The residual check valves hold some pressure to keep the brake shoes close to the drum. Not needed in disk brakes. However, every 280ZX and Wilwood MC I have bought had the residual check valves in the front and rear outlets of the MC.
1. Tell us what year Z you have as there are differences in the hydraulic systems. 2. There are residual pressure valves in the outlets of the master cylinder. They look like a piece of rubber with a spring. Remove them. 3. You should not have two proportioning valves (PV). Having two PVs can cause problems other than what you have mentioned here. If you have for example, a 72 240Z, and you have installed a PV in the rear then the stock PV should be removed. On later model Z cars you need to understand what the PV does before removing or modifying it. 4. The other question is why do you need a PV in the rear? 240SX rear calipers are typically undersized relative to most so called "front brake upgrades". So unless you are experimenting with high friction rear pads to fix front - rear balance issues a rear PV is not required with 240SX rear calipers. 5. You can relieve pressure to the front or rear brake circuits by opening the respective bleeder on the MC if you need to limp home with dragging brakes. 6. In my experience, the front brakes will lock up after a few stops if the booster push rod is too long. It doesn't take much as the return port in the MC is small. The push rod can be adjusted without removing the MC from the car. Just unbolt it and push it to the side. 7. So remove the residual pressure valves, recheck the brake booster push rod length, and road test the car.
-3 TO 10mm x 1.0mm inverted flare adapter is required. See picture. Summit Racing: http://www.summitracing.com/parts/ear-592032erl http://www.summitracing.com/parts/rus-641431
The Toyota caliper was not machined for a banjo fitting. Consequently, the fitting will leak where it is attached to the caliper. Options: There are several companies that sell stainless steel braided brake lines of the correct length and with the correct Datsun - Toyota fittings. Try Silvermine Motors in the Vendors section. You can use A/N brake lines and an A/N-to-Toyota adapter to connect the Toyota calipers. This was my choice because I didn't want to rely on the availability of custom brake lines. There are several discussions about Toyota brake lines in the Brake Forum. Recommend that you spend some time researching the Brake Forum before doing the swap. Are you aware that you may have to go to a larger bore master cylinder with the S12W caliper swap? Stock well maintained brakes are fine for a street car. Stay away from so called "street performance" brake pads as they don't work well cold. If your car is going to be a street or daily driver you want a pad with good cold bite. Cold bite is what you need when a kid runs out in front of you. Quality stock brake pads work fine. See the Brake Forum for details on brake pads and brake swap balance issues.
ebay radiator: 1.250" diameter inlet/outlet... issue?
Miles replied to scartail's topic in Cooling Systems
If the inlet/outlet is too small, and the hose inner diameter too large, you can buy hose reducer bushings at any auto parts store. If you want to spend the time you can find hoses that have different diameters at each end. Or you can buy a universal hose kit and make a Frankenstein hose. No it won't effect performance and don't use hose clamps to make a hose fit on a smaller diameter inlet/outlet. Do it right. -
advice before making 1975 280z purchase?? ty
Miles replied to thrice's topic in S30 Series - 240z, 260z, 280z
Keep looking. -
- 7 replies
- 4 barrel
- holley 390
(and 3 more)
Tagged with:
