36
Everything posted by Miles
Brakes dragging after 30 minutes of driving
Miles replied to ditto64's topic in S30 Series - 240z, 260z, 280z
Most likely the MC push rod is adjusted too far out which will block the return port in the MC. With the return port blocked pressure will build up with each application of the brakes until they drag/lockup. Test: Open the bleeder ports on the MC when the brakes drag. This will release the pressure and unlock the brakes demonstrating that the push rod is adjusted too long. You can adjust the push rod without removing the MC. Remove the retaining nuts on the MC and push it aside to access the push rod. Make small incremental adjustments followed by road test each time. Carry a wrench that fits the bleeders on each road test in case you lockup the brakes. If you back off the push rod too far your brake pedal travel will be long and grab. All you need is about 1mm clearance between the push rod and the MC piston. Research the brake section as this problem has been discussed many many times. -
WTB: V8 Temperature sender adapter fitting for 1988 and earlier SBC
Miles replied to tomb77v8's topic in Parts Wanted
MSA/JTR not cheap. http://www.jagsthatrun.com/Pages/Parts_DATZ_Wat-Temp-Send.html -
You may be able to get a new sending unit from an auto parts store and the adapter from Lowes etc. That is how I did mine. Wrapped the threads with teflon tape. No leaks in 10 years. Black Dragon is going out of business, but they may have the sending unit if your local auto parts store doesn't have one. -
MSA sells the sensor and fitting. This is what the fitting looks like: http://www.thezstore.com/page/TZS/PROD/10-1878 -
For the mustache bar bushings burn out the old rubber bushing and leave the sleeve.
240z dies when choke is fully open
Miles replied to 5 Star Rising's topic in S30 Series - 240z, 260z, 280z
This is just sad. -
anyone know what happened to www.atlanticz.ca/zclub/techtips
Miles replied to Kamaka Z's topic in Miscellaneous Tech
Here is some info I got at ClassicZcar.com....................... Per Blue: Web site was hacked.... it is being rebuilt. Stand-by. http://www.classiczcars.com/forums/topic/55987-blues-tech-tips/ -
http://forums.hybridz.org/topic/4960-hood-latch/?hl=%2Bhood+%2Brelease+%2Bbroke http://forums.hybridz.org/topic/107117-howto-release-a-240z-hood-when-cable-broken/
Brake trouble shooting with pressure gauge
Miles replied to RebekahsZ's topic in Brakes, Wheels, Suspension and Chassis
So did you solve the brake problem? -
1. Pulling to one side suggests a stuck/leaking caliper. 2. Hot front brakes on both sides suggests: Brakes dragging due to improperly adjusted master cylinder push rod. Are the rear brakes hot too? If yes check the push rod. Unbalanced or undersized brakes: Rear brakes undersized. Improper rear brake PV adjustment (to much front bias). Brake pad selection. Drive the car around 4 - 5 miles in a safe area staying off the brakes as much as possible and pull off road and check front and rear temperature of the calipers/wheels. If both front and rear brakes are hot then they are dragging possibly due to the push rod issue. If the front brakes are hotter relative to the rear brakes then there may be a front bias issue due to undersized rear brakes, PV adjustment or brake pad selection. If the fronts are pulling then inspect them. A weak/sticking caliper will cause the opposite caliper to grab and pull. If you find a bad caliper replace both sides. Let us know what the road test shows. -
Just curious if anyone has used Professional Products Powerflow piston-style fuel pumps. https://www.summitracing.com/parts/pfs-10731
^^^^^^ what LLAVE said above. Can you be more specific? Do you notice any other issues such as back firing when you open the throttle? You have to provide details about your build such as which engine, modifications to engine, how was the engine installed (MSA, JTR etc), which carb did you install, what type of headers were used etc
Go on line to Naps or Black Dragon and see what they have.
Seems like we all went over this with you a while back. You have the push rod adjusted too long such that fluid pressure is building up each time you push the brake pedal causing the brakes to lock. Open the bleeders on the MC to relieve the pressure and readjust the push rod as outlined in the FSM or search in the brake forum. Search the brake forum for "push rod adjustment".
POST DELETED -
Fuel pump safety switch: See post 2 in link below http://forums.hybridz.org/topic/125512-fuel-injection-cut-off-switch-inertia-safety-switch/
http://www.ztrix.com/hoods/hood-with-cooling-vents.html
Why not take it apart so it drys out and you can clean out the silt/mud. A friend once drove his 57 Pontiac into Lake Folsom where it sat for day. We dried it out. Getting the silt out took some time. If it were me I would: Pull the engine and remove the heads, oil pan etc to determine if corrosion has set in. Blow out all of the ports etc. Pull Transmission and clutch. Pull the cover off of the differential to get all of the water out Remove all of the interior to allow air to get to the openings, compartments and the wiring harnesses. Remove the gas tank to wash out the silt. Blow out the fuel lines. etc
This is the fuel pump I use with a SBC 350. Installed it seven years ago. No problems. Output pressure is adjustable. Not much noise. Be sure to install a fuel pressure gauge. https://www.summitracing.com/parts/edl-1791 ":The JTR manual says to mount near the gas tank" Correct. Fuel pumps push better than they suck. Be sure to search the fuel forum for more information about which fuel pump to use as the topic has been discussed many many times.
sebaskir: Bolt Sizes for front differential cross member go here and page down to a picture/ table showing bolt sizes: http://community.ratsun.net/topic/26238-my-swiss-1972-s30-240z-rebuild-project/page-22 And: https://zcardepot.com/suspension/rear-suspension/rear-control-arm-transverse-bolt-kit-240z-260z-280z.html From my notes: Diff Cross Member - 4 each 10 x 1.25 30mm long 30mm thread length (i.e., not a shoulder bolt) As with all information on the web - trust but verify
Or you could use a 280Z hood that has the cut outs. Plus the holes in the 280Z hood are recessed for the louvers.
That switch also controls the brake light circuit. The brake light gets cut out of the circuit in the R/L turn position. Brake lights still function ok? Do you have specs on the switch?
- 21 replies
- Indicator
- turn signal
(and 2 more)
Tagged with:
Nice! We need a section in the Electrical forum that centralizes all of the information on combo switch repair. Like the section recently set up for Cooling Systems. https://fiddlingwithzcars.wordpress.com/2012/12/04/turn-signal-repair/
- 21 replies
- Indicator
- turn signal
(and 2 more)
Tagged with:
