Miles
    37
Everything posted by Miles
  1. Use vice grips to grab the fitting tightly
  2. You can use vise grips on rounded off brake fittings to remove the brake hard line.
  3. For the flex lines you can use a coat hanger to estimate the length. Always move the suspension and steering through full motion to verify the flex lines are not being stretched or rubbing or kinking etc. Someone here recently forgot to do that and his SS flex line abbrated a brake hard line until it cut through the line - no brakes.
  4. Suggestions - brake booster: leave the firewall nuts loose (few turns of nuts) until you have the pedal connected. - I use a soft alloy brake line because it is easier to bend and flares well. - The Z uses an inverted flare. Buy the best flaring tool you can afford. - You can bend the lines by hand, but small radius bends are better done with a proper bending tool. I use use two bending tools: one for large bends and one that looks like pliers for very small bends. - I bought the bending tools at Harbor Freight and the brake line stock at Summit Racing. - I suggest that you search the Brake forum for brake line flaring and proper tools. I use use a bench mounted flaring tool that makes perfect flares. - As far as measuring brake lines you can remove the line and use a tape measure or use rope to follow the bends and then measure the rope or you could measure using a coat hanger. - Most autoparts stores sell Japanese style brake lines with the correct fittings and flare. Lengths are typically 12in to 36in.
  5. Many who do the rear disc "upgrade" discover that it is not an upgrade at all considering stopping performance. Recommend that you study the brake FAQ and the brake forum before installing one of the popular upgrades. Most of these upgrades result in an unbalanced brake system. Also, when you change one component of a brake system it has a domino effect on other components such as the master cylinder and front/rear brakes. Think about it.
  6. What percent of the time will your Z be a daily driver?
  7. post pictures of the booster and the areas you are having trouble with.
  8. I prefer the FSM also, but the Haynes Datsun 240Z, 260Z, and 280Z Manual does contain some answers to his questions such as how to adjust the MC push rod. There are many many write ups in the brake forum that explain or answer most of his questions.
  9. answers are in the brake forum and the FSM or Haynes manual for your car. Also, you may want to take the car to a brake shop.
  10. Follow the hydraulic line. You can't miss it. Clutch master/slave bleeding...... I prefer to use the gravity drip method. Fill the MC with fluid. Place a drip pan under the slave cylinder once you find it. Open the bleeder on the slave cylinder. Let fluid flow out of the slave bleed screw Let it drip for about 5 to 10 minutes. Do not allow the MC to empty out. Keep it topped of until you close the bleed screw on the slave cylinder. After you close the bleed screw on the slave cylinder. Pump the clutch pedal once or twice and you should have a firm pedal. If the pedal is not firm, repeat the gravity drip steps above. If you can not get a firm pedal after several tries then either, or both, cylinders are leaking internally.
  11. Lots of T5s here in sacramento. In 2001 I bought a T5 at a wrecking yard for $600. In 2009 I bought a rebuilt T5 for $800. Do places like Summit sell Camaro T5s?
  12. I recommend that you buy the Jags that run 240Z V8 conversion manual as it answers all of your issues in detail. Search the drivetrain section for T5 installs.
  13. As long as you leave some free play in pedal movement it doesn't matter. That is, you do not want to pre-load the MC. Adjust it so there is free play and so the pedal still has full engagement.
  14. I wouldn't count on getting pictures. I would start with downloading the factory service manual (FSM). They are available here and you can google search for them. Search for electrical schematics. Many members have made color schematics in pdf format that you can download.
  15. Before you took the car apart, did you number each wire and make a wire list? Did you take pictures of the wire harnesses and the connections?
  16. See this thread: http://forums.hybridz.org/topic/29786-painless-harness-to-z-column-harness-headlight-combo-switch/
  17. The Painless wiring harness install has been documented here for some time including a complete tutorial on how to install it. You can wire the entire car with it. Search: "painless"
  18. 0.875 Clutch Master Cylinder : used both of these…… http://www.summitracing.com/parts/wil-260-10374 http://www.summitracing.com/parts/til-75-875 Camero clutch slave Napa NCF 73110 Clutch kit http://www.summitracing.com/parts/ZZZ-HP1675-1A Flywheel http://www.summitracing.com/parts/ZZZ-50-6516 Clutch slave hose adaptor http://www.summitracing.com/parts/RUS-640281 Hitachi Gear Reduction Starter Hitachi starter gear reduction PSL100
  19. I have used 1990 Camaro World Class T5 transmissions in two 240Z SBC 350 builds. Both cars were built as daily drivers (son's college car, my work car). The five speed is highly appreciated on freeways and road trips. The T5 is tilted towards the driver's side, but poses no problem for installation. Use the Camaro bell housing so that the rear trans mount is horizontal. Only a small amount of trimming is required on the left side of the trans hump where the shift tower comes up through the floor. I have pictures if you need them.
