RB26powered74zcar
Super Moderators
    23
Everything posted by RB26powered74zcar
  1. Thanks Matt, I will use the largest dia. AN fitting that will fit. The only problem I have noticed so far is, that dam A/C comp bracket being in the way.... it's allways in the way of something... haha, but I GOT TO HAVE IT !! I will try to drill a hole thru the A/C bracket to allow access to the tapped oil passage on the new pump. In the pic below, it will be the hole on the driver side that I want to use for drawing oil from the pan. I will need to either tap and block off the pick up hole on the block, or better yet, I think, is to take the pump in to a machine shop and have a recess milled into the supply hole, slightly larger, and shallow, to where I can epoxy a flat washer into the recess to keep the pump from trying to draw oil from that area of the block, and instead draw it thru the removed tapped plug and thru the new pick up in the pan..... Whata ya think about that idea???
  2. Here is a set for sale at a lower price than I paid. These are worth this price for sure.... http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=7978571484&rd=1&sspagename=STRK%3AMEWA%3AIT&rd=1
  3. Look at the side vents, its a series 1 (unless he filled in the hole)...
  4. Matt, I have a good question for ya.... While James was over fri. and we were discussing what to do on a oil pan, we got to looking at the new oil pump I will be changing out from the new nissan pump I have on the motor now, and found that on the uprated pump, it comes with the oil passages tapped and plugged with alum hex head plugs, allowing for external access to the oiling system. I noticed that these passages have a freeze plug in the regular oem oil pumps, instead of hex head removable plugs.... Have you seen these before? We think this will make installing a alum pan, with a pick up made to lay on the bottom of the pan, with baffling of course, and a fitting to come out the side of the pan, to connect to the tapped fitting off the side of the oil pump, a peice of cake. I realize the matching hole in the block, that runs to the oem pick up tube will have to be blocked off now that the oil is being pulled from the new external line. Does this make any sense to you?? thanks- joel
  5. I will try and make it outside tomorrow for a pic Matt, I've been flat on my back for a while now, due to ilness, but I hope to poke around my newly returned rb26 transplant for a short while tomorrow.... I'm only 6' tall, so this should work for you Sparks j.
  6. If I remember right, of the four threaded studs on the seat rails that came on the seats, only one will line up with the oem holes in the floorboard. I think what I did was (on driver seat) use the foward right side threaded stud, toward the consol, and let that one fall in the oem hole in the floor raised rail, then I pushed downward HARD as I kinda used the other three threaded studs to scratch the paint off where they needed the new three holes drilled.... Once I removed the seat back out of the car, I drill three new holes, then put her back in the new holes, plus the one already drilled from the factory seats, and moved on to the other seat.... It was really too easy for me.... If you use the left foward oem hole (on driver seat) in the begining, it may put them to close to the door jam to shut. Thats how it looked to me, but I didn't try them that way... who knows, they may fit that way also. As far as adjustabilty, mine go all the way back, and close enough to the front where I think you will be ok with my way I chose to install them. good luck to ya... joel
  7. Nah on that ebay deal... Any R32 motor set that needs a quart of clearcoat sprayed on it to try and sell, I'll stay away from....
  8. That sounds about right for the oem ones. What I did was went online and ended up getting them form Advanced Auto Parts (if I remember right) for a lot less than oem price' date=' and they worked fine on my car... http://album.hybridz.org/showphoto.php?photo=1475&cat=500&page=1
  9. I think I'm the only one in that group buy that only had to send the part back to them only once for fixin.... After I got it back, everything fit fine and was used with great results in my book, until I sold the whole power train in favor of my rb26 swap.
  10. RB26powered74zcar
    dif. ?
    Thanks Rick.....
  11. In the first pic showing the six holes, those are the same 280zxt outers, with two different style end caps applied on them. I got ahold of both kinds myself from a axle guy once... same part, one uses a shorter return spring, thats all... As far as the inboard stubs, I will go with what was sugested in the post above (as I know one is longer on one side than the other on my R200 )
  12. RB26powered74zcar
    dif. ?
    What about the R&P size.... R-200, R-230 ?? I can't find that anywhere....
  13. Will do' date=' once I get them in... Here is what I got from them: PayPal Shopping Cart Contents Item Name: [img']http://images.paypal.com/en_US/i/scr/pixel.gif[/img] Single LED Item Options: Color: Red Lens: Oval Wide Angle Item Number: 194 Quantity: 12 Total: $29.88 USD
  14. Thanks for the link Mike, I just picked up 12 of the leds for my new AutuMeter gauges, just waiting to be installed into the Z...
  15. I'd slap that bitch, and spit in its face if I ever ran up across him. Sean put him in his place as far as he could on National TV..... What a girlyman
  16. Shweet..... J. I hope mine turns out that nice. James should be bringing it to me within the month (thanks James). I bet you can't wait to take her for a spin huh? It's going to fly....
  17. The 200zr oil pan, oil pickup and o-ring and the mounts are all available from http://www.nismoparts.com here are the part numbers for what you need: Oil Pan/Parts 11110-20P00 RB20DET Oil Pan (Rear Sump) 15050-20P03 RB20DET Oil Pickup 15059-V5001 RB20DET Oil Pickup O-Ring 11232-41L00 Z31 Right Hand Side Motor Mount 11233-41L00 Z31 Left Hand Side Motor Mount 11220-01L10 Motor Mount Insulators
  18. WOW.... $448,000 toy. Imagine how he felt after taking a lick like that..
  19. I put my money on it being a mis print. He prolly just goofed, and listed the n/a ratio, instead of the TT ratio... I saw that too. The same gears started turning in my head Jamie..... Thats what we need (if it were indeed avail)
