I have one, with modified boots to accept the larger bore and maintain all the factory ports. $80 shipped for the TB with linkage modded, adapter, and the short piece of tube that will allow mounting to the afm without loosing any vacuum ports.
Why is the question either down pipe only, or 3'' all the way out back to a muffler. There is all kinds of middle ground in between. Keep the muffler but do side exit fore rear wheel is one example, this way you have the sound elimination, but don't have to add the weight (and bends) to carry it around the axles and out the rear. I have seen guys run a turn down just in front of the rear suspension. My car is currently on jack stands receiving 3" dp in SS carrying into the tunnel, then v band to 3" aluminum splitting into a y pipe and dual 2.5" exiting at about 45* in front of the rear wheel. The incentive for this system came when my 2.5" dp to 3" all the way out back to a magnaflow straight through came in at something like 38lbs iirc, new system is less than ten
You are going too fast/or need an overdrive. With o/d and everything tuned and sorted 27-28 should be no problem. Go through all the tune up stuff, filters, plugs, gaps, fluids, everything, then pump your tires up.
My friend removed 67lbs of sound deadening material from the rear of his e30. -This got me to scraping, 7lbs removed so far, that was from the shock towers.
Serious dyno time.. what like $2500 to extract what? 30-35hp more. I'd rather put 2500 in head and cam, then with typical $350-400 dyno time make 200hp more. But that is if it were my money.
IIRC Garret did 460 atw with stock head/A grind cam. Bored to 89mm with custom intake mani, 70mm tb, big ole mismatched turbo and lots of boost. I would say that is probably as close to a record you're going to get. After all we have Datsun's, not evo's.
The law states that tire manufacturers may advertise a lower treadwear rating than they actually score (makes them appear stickier to performance tire market); however, they may NOT advertise a higher treadwear rating than they score. It is pretty common practice of performance tire manufacturers to advertise a lower rating than they actually have and no one says they can't change said rating any time they want.
Stock vg30et was rated at 250, in theory another atmosphere should get 250 more. Given some supporting mods many guys get + 70-80% adding 1 atmosphere in the real world. This is not universal and I haven't done it on a VG but I've seen it on everything from Datsun l6's (sohc) to small block v8's (ohv) to VW i4 (both 16v and 20v).
And they would be correct, this (style) too shall pass. We'll just keep on removing weight, adding power, and striving for traction the way gearheads always have. I'm just an s130 junkie who knows guys that have raced.. ahem RACED... s13's since the 90's and I know how they feel about current styles. I guess I thought my beloved chassis was insulated from such riff raff; however, threads such as this have provided that their truly is nothing holy. Now I am no purist, but this is "Hybridz" and we used to be renowned for our discussions on performance and on the huge amount of intellect and experience that was on tap here. Guess those were the good ole days.
I really like the splitter design. Do you plan on venting the box behind the wheel out the fender or routing it out the side skirt? My zx has fender vents, but they are much higher on the body.
Not sure what part of this thread gave you such confidence. My 15x10's where effectively -25 with the spacer, and they barely fit the rear with a very short 23" tire.
