A trick to put the bolts back in the motor mount is to loosen the motor mount from the block some and put the bolts in to the holes. Then go back and tighten the bolts to the block
Make sure the motor mount is on the right side. It took us 3 hours to figure out why my motor was standing straight up and not going in real smooth. Just a pointer
I got it in though. Hoohoo
Well, because I just had a bottom end problem (bearing going out.) So kind of panaroid. I'm just hoping for 80psi but in the summer day here, I'm sure I won't get that high. Anyway, shimming is easy, you just take out the spring and add shims.
I got that Craftsman 6HP oil free (I can't remember the tank size but pretty big) and pretty happy with it except the loudness of oil free pump. It keeps up with my die grinder that's about much load as it can get I think.
I just got my oil hose today. I went from where the oil pressure sender was to 1/8 stub, 3 way t block, 1/4 inch braided hose. The best part was I got a 4ft of braided hose with fittings for free.
I got mine done, 2 1/2 inch I.D. pipe into 3 inch 45 deg bends with split joints. I came out pretty sweet. I'll post some pic when I get some pictures.
I've heard the leaking problem with Aeromotive unit but I don't know, I'm running SX performance which seems to be same thing and it doesn't leak ebay is one good place to look too. I paid $85 for mine
4:1-12:1 is fuel pressure:boost ratio. so on 12:1, 12psi raise fuel pressure per 1 pound of boost. Too big IMO. I say 4:1 is plainty but I don't know how your car is set up so I can't tell you.
I've not seen it on Z yet(I've seen the cartech unit before)but I just saw one on Vtec SI with drag 3 kit. he had it mounted on the firewall.
9 sec SOHC supercharged 1.5L?... Not. in 1/8mi
BTW there is a guy with delsol with 1.8L Vtec DOHC swap here. he traps 3 digits (like 104) on all motor and runs 13's. No NOS, turbo, SC, or stickers. Sleeper.
www.forcedperformance.com
They might be able to help on Mitu stuff. or search on google "DSM"
BTW, Mitu turbo are sweet for a small displacement engine.
