S30 SPL
Everything posted by S30 SPL
  1. I have a pair in good condition, removed to do my 5 lug swap. I have all the brake parts to go with them too.
  2. I have a set, complete strut housings with brakes and everything too if you're still in need.
  3. Couldn't you cut it out from generic flat stock? But I think a lot of people don't want to use that stuff since it's like a sponge for moisture.
  4. I have an entire R200 swap but its a 3.545, you want a 280ZX or 300ZX one I think.
  5. What car does that come out of?
  6. I think the cylinders are different between different years no?
  7. I have what you are looking for. PM me.
  8. So you got all your glass? I have quarter windows with the frames.
  9. Greddy diff cover is pretty darn strong... I have a spare diff if you are interested in building it up and then be able to swap.
  10. I have one as well.. and the entire R200 swap set too.
  11. Sent you a message. I have some coilovers and Tokico adjustables that are right in your budget.
  12. That's gonna be something custom. 13" wide is wide...
  13. Just to give you an idea of how much flare and cutting you need to do. I think there's another pic of the car with the zg wide flares attached.
  14. It's a nut that goes into the spherical bearing a little bit to support it. And the bottom portion where the main piston contacts the bottom of the bearing is about 20mm.
  15. I have the 3 bolt ones, they don't give as much adjustment as the 4 bolt as I understand. I don't know about the install of the 4 bolts. The 3 bolt ones are stock replacements. In order to fit the nut and bearing, you need a shaft that has 12mm thread engagement area.
  16. How wide? What lug pattern?
  17. I have a set of 240 hubs. Southern California , La/oc area. Let me know if you still need.
  18. I have a rear 72 bumper, cheap in LA. Decent shape.
  19. Where are you located? I have a 72 you can come look at and cut what you need.
  20. Still looking? I have one from a 72
  21. I have a 72 with an entire dash. You just need the little brackets?
  22. You still looking? I have a car in LA you can look at and cut as much as you want. It's a 72.
