25
Everything posted by Leon
Disappointing conversation with CustomPlenumCreations
Leon replied to Brad-ManQ45's topic in Nissan L6 Forum
Agreed 100%. Good for him that he has the ability to turn down work that he doesn't WANT to do. I'd do the same if I were running a business. -
Good to hear.
My 2mm shaved P90 gave me nearly 11:1 compression on a .020" over L28 with stock head gasket.
I'm with Steve. This is nothing a shaved P79/P90 couldn't handle. The list is a very basic L-series setup, nothing that hasn't been done before. If we're talking a 400hp, 9000RPM, 14:1 compression motor then it's a different story. And in that case, if you gotta ask...
I think the problem lies in the premise: WHY exactly are you looking to weld the chambers up?
Austin, Works Motorsports does UpRev/Osiris tuning, FYI. You can get a modified harness and flashed ECU as TJ mentions and then bring it to Works for a final tune once the car is ready.
Great job, looking forward to seeing some photos and video! Very cool and unique swap.
The 260Z center valence has different mounting tabs and does not bolt onto a 240Z. I believe the side valence pieces do cross over.
Stumbling under acceleration
Leon replied to endofzworld's topic in Trouble Shooting / General Engine
Sounds like a tune issue, that pump should be plenty. -
Good find! Let us know how it goes once the rest of the bits are calibrated.
Check to make sure you haven't accidentally swapped the thermotime and coolant temp switch connectors. That will cause a rich condition.
SuperDan just posted his: http://forums.hybridz.org/topic/125690-77-280z-shell-very-solid/ He runs this site and happens to be in SD...
When I was at WORKS Motorsports, we developed the only CARB-legal BRZ/FRS turbo kit on the market. FYI... The car is a blast to drive all kitted out (or bone stock). The WORKS shop car has a Flex-Fuel Stage 2 kit, Ohlins, STI brakes, etc etc. I've driven it on track from stock to modified and it's an absolute beast.
I had a similar failure on reground rockers, also on the trailing side of the pad. I think the trailing side sees more wear because as the cam lobe sweeps across the rocker pad, the lever ratio over the valve spring is increased. This puts more stress on the lobe/rocker interface the closer the lobe gets to the rocker pivot. Mine failed using a "good" oil, Brad Penn. Once I replaced the REGROUND rockers with new (combo of aftermarket and Nissan) they've been wearing in really nicely. Only have about 500 miles on them though... I didn't do an engine teardown, just changed the oil.
That doesn't look too good. I'm not a fan of Royal Purple, can't explain it scientifically but they don't have a great reputation. Try switching oils to whatever your cam grinder recommends (I run Brad Penn based on Ron Isky's rec), maybe consider replacing the rockers with new ones. Were they resurfaced or new?
Coilover Leveling Issues
Leon replied to ~KnuckleDuster~'s topic in Brakes, Wheels, Suspension and Chassis
You need to take it to a frame shop and have them measure it. -
I'd take it to a frame shop. -
Did you double-check that you have the springs in the correct locations? A left-right spring rate mismatch will cause weird side-effects. Who built the coilovers? Are the collars located identically left-right? -
I bet Dinan would have some great insight if they like to talk about projects like this. http://www.dinancars.com/
Just because wires are going to the right places does not necessarily mean that the ECU has all the proper inputs to make it happy. I'd get together with somebody that has a lot of knowledge regarding the ECU for that car, i.e. an old-school BMW tech. Maybe there are good explanations online, although I'm sure you've done a lot of that research already.
Man, the wife and daughter are a tough crowd! Glad you're enjoying everything, it's sounding like a great trip.
Love the car and setup, thanks for the feedback!
- 12 replies
I used an L24 head gasket on an L28 bottom end! I admitted it to Dave and he showed me an easy way to visually tell between the two: the OEM L24 HG oil feed hole is round and L28 HG oil feed hole is oval. Another one of those mistakes that I definitely won't repeat again! Not sure what size the E31 chambers are but will definitely stick to the P90 at this point. Not that I have a knock sensor in the block but surprisingly I didn't hear much in the way of knock in the 1500mi that I put on the engine. Dave indicated that with the right build and tuning, 11:1 comp can be okay to run on pump gas. I was using an OEM head gasket which compresses TO roughly 1mm. I'd like to repeat the test that I screwed up when first assembling the motor: with a dial indicator mounted to the block, measure head height with no gasket installed vs a compressed head gasket. That will give me a more-or-less exact figure of the true compressed gasket thickness. I plan to use an OEM L28 head gasket because this motor isn't that special in the sense that the pistons are stock replacements and pop out of the deck as much as a stock piston would, i.e. as Nissan designed it. I ran it by Dave and he says he uses OEM head gaskets in many of his builds, although he is not fully on board with how much Nissan designed the pistons to pop out of the deck. Looking back at the previous measurements, my piston-to-head clearance is 0.017". I did not see any signs of the pistons hitting the head, although I don't think I ever spun it to 7000RPM. I'll be able to re-measure that once I get a compressed gasket thickness, as I know the pistons are 0.021" proud of the deck. Time for some more learn-by-doing...
