Leon
    25
Everything posted by Leon
  1. Sweet man, I haven't been at Yoshi's in a little while. I need to get this Z put back together...
  2. Hey Josel, I'm not sure how long the pins are since Dave put them in. I'm giving him the benefit of the doubt that they aren't too long. Your car's looking pretty good, looking forward to seeing it sometime.
  3. As promised, here are some shots of the pinned intake manifold:
  4. It's essentially two socket head cap screws threaded into the head, with holes cut accordingly in the manifold. I can take some photos tonight.
  5. Thanks for the cam gear tip, Mark! I'd guess there won't be much power difference between 40mm and 41mm venturis as I believe the restriction at the butterfly is effectively a 40mm venturi. Would definitely be interesting to see the results!
  6. I don't think caster settings will inherently throw off static corner weights by much. It's more the jacking effect from camber changes that causes that. Time to put some corner scales on the to-buy list!
  7. Any race-alignment shops around you? Are your tire pressures even L/R? You can eliminate any tire/wheel issues pretty quickly by swapping left-to-right and going on a test drive. I've had unevenly worn tires do this, although it seems like you have the same issues with both sets of tires you've tried...
  8. Picked up the goods this morning. Rebello re-cut the seats, installed new valves+guides+seals, and did a street port. Dave mentioned that this casting was better than most so minimal intake port cleanup was necessary. Intake valves are Supertech, with an undercut valve stem for slightly less restriction. The exhaust ports, on the other hand, were pretty worked over... Dave also hogged the crap out of the TWM manifold which he said didn't line up very well with the ports. I had carb-matched it previously but he finished the job! The manifold is pinned to the head for alignment, you can barely tell where the manifold ends and the port starts. The cut-out for the injectors kind-of gives it away. Hoping to find time after work next week to piece it together!
  9. Very ingenuitive! I'll think about doing something like that, thanks.
  10. Long-story-short, the head is finally done and I will be picking it up on Saturday. Dave also port-matched the intake and pinned it to the head. He doesn't use gaskets on pinned manifolds so I'm considering what I'd like to do here. I can goop it and slap on the manifolds but that would suck to clean up upon the next removal (seems to happen more often than I'd like). Otherwise, I can port-match the gasket, drill holes for the pins, and use the gasket. Hoping to begin reassembly this weekend!
  11. Is the ECU throwing any DTCs?
  12. Ha, Damian Harty is my coworker.
  13. The "fellow" you spoke with was probably Ron Iskenderian. I run that same cam in my flat-top L28 (Isky L6 grind). I took measurements and documented them in my build thread: http://forums.hybridz.org/topic/111062-leons-other-260z/
  14. Use lots of heat, it'll do the trick.
  15. I'd look into your engine mounts and crossmember mounting points.
  16. I was about to recommend them as well.
  17. If you need it perfect, reseal the carbs, that's your issue. Nice job finding it. Your gut feeling is correct, venturi size doesn't affect the idle circuit.
  18. Probably but if it's street driven, you'll spend a lot of time below 1/3 throttle. If it drives fine, don't worry about it.
  19. I set mine more-or-less equal. Seems like your carbs have seen better days and maybe have a seal going out or a bent throttle shaft. It'll make the engine a bit more finicky at idle and low-load, depends on how concerned you are with performance under those conditions. I take it these are older DCOEs without the air bypass screws?
