Leon
    25
Everything posted by Leon
  1. It would be far easier to convert your head to solid than finding someone willing to trade.
  2. Go to Sidedraft Central and read (and absorb) as much as you can. Rest. Read some more. Otherwise you'll be chasing your tail, or as TJ shows above, herding cats...
  3. Diff came in on Thursday! I finally had some time to unpack it and put it up on the bench after doing some cleaning this morning. I got a tip from a local racer as far as diff shops go. Apparently, the place to go is SF Differential in South City, so I may be paying John a visit.
  4. Like Jim said, the steering rack bushings will be totally incorrect plus there won't be any bushings for your rear anti-roll bar.
  5. Nice Jim, looks awesome especially with the silver paintjob! Just last weekend I picked up some spray paint from the local auto parts store, it's some sort of dark grey. I forgot what they called it but I believe it's a trim color for Nissans. It looked close enough to me when I was looking through the paint section. I figured if I don't like the color, I can just repaint! Powdercoating sounds like it might be a nice option that I hadn't thought about, so thanks Jim.
  6. Not quite, but suit yourself. Current GL-5 oils may not corrode the brass, but they will wear it out at an excessive rate. Read this before commenting: http://www.widman.biz/uploads/Transaxle_oil.pdf
  7. It's been a while... I found a machine shop for the engine rebuild, turns out every Z owner I've met recently take there engines there (Baca's Machine Shop)! I've also sent the tail-light bezels off to be re-plated about 3 weeks ago, should be another 2-3 weeks until those are back. In the meantime, I'll be painting the tail light panels and stock mirror to close-to factory color. They were painted satin black by the PO. Today I paid for a Datsun Comp 3.9 R180 CLSD after searching for STi R180s for a little while. Hopefully I'll see it in my driveway within a week. Should make for a nice, classic street combo: L28 with triple 45s, late ZX 5-speed, and 3.9 CLSD.
  8. I've got the whole front set, pics are in my FS ad. Not sure what ash tray part you're looking for though. I'm in San Bruno.
  9. Put GL-4 fluid in your transmission. GL-5 will slowly kill your syncros.
  10. MY GOD, that is awesome Ron! No wonder we've seen less of you and BRAAP lately...
  11. As in bearings, seals, and clutch disks/plates? Anyone familiar with a good diff shop in the SF Bay Area? BTW, thanks for the reply John, I was thinking of just PM'ing you but wanted to consult with the HBZ populace as well.
  12. Hey guys, I've been on the lookout for a 3.9 R180 LSD and have been mostly shopping for STi ones. However, I found an original Datsun Comp unit meaning I won't have to buy the accompanying side-axles, but there's a catch: it's from the '70s and the clutches are worn out, as described by the owner. He said the diff "slips" and doesn't work as well as it used to. Does anybody have info on whether new clutch disks are available from Nissan or anywhere else for that matter? I found an old catalog here: http://www.nissanusa.com/nismo-web/Nismo-Motorsports-Catalog-2010.pdf And cross-referenced the part number to Courtesy which shows the disks as available and apparently shared by many other models: http://www.courtesyparts.com/kb_search_result.php?chassis_id=0&keywords=38433-RS610&Submit_Button=Go&cat=1 Can anyone confirm? I'm thinking I should be more worried about the overall condition of the diff (bearings, seals) than the clutch pack anyway... Thanks!
  13. Excellent feedback, thanks!
  14. By new keys do you mean you shimmed them or just bought new ones? Any difference in shift effort?
  15. There's a guy on Craigslist in Santa Clara that has a new set, I think. They look to be the side-by-side ones and not stacked from the box art, not sure what style you're looking for.
  16. Sweet! You're making me want to rebuild one of my ZX trannies...
  17. "Damage was limited to the ego and underpants."
  18. Yes, regulate pressure down to 3psi or so. Whoever told you that is ignorant of how these carbs work. Must be used to small blocks and 4-barrels...
  19. 6psi of pressure at the carbs will overpower the floats. Set pressure to 3-3.5psi.
