10
Everything posted by socorob
I would like to hook my purge valve up on my LS1 to my original Datsun vapor canister. I know the GM PCM looked at a lot of things to determine when to open it to purge the canister. I was thinking to do it in a sort of old school way, having the valve open up at startup for a set amount of time. I would just hook up a timed relay to open up for X amount of seconds on start. My questions I've been searching around here for the last hour or so are: 1. Is the solenoid 12 volts (I'm assuming it is). 2. How many seconds should it open when the engine starts, to purge the canister? 3. Is there another way that people usually hook these up? I also asked this on LS1 tech.
Think the sleep learning place in the classifieds still in business?
Universal Anti Roll Sway Hollow Bar Kit
socorob replied to 260DET's topic in Brakes, Wheels, Suspension, and Chassis
TTT makes a hollow rear one for the Z. -
Hope you got it fixed. I saw a post of facebook from the JY in Walker I think. It had a whole section of hot rods and sports cars that went under, there was a Pantera, several Vettes and Mustangs, etc. Apparently you can't get them retitled. I guess they could be good for race cars.
Electric power steering. $100 > $1500
socorob replied to sectumsempra's topic in S30 Series - 240z, 260z, 280z
That one doesn't pivot. I just got the bruno controllers in the mail on Saturday. I have been too busy to work on this lately, but hopefully will be able to make some progress in the next week or so. There's a bearing in the bottom of the Z column that the Saturn shaft almost fits through. I may attempt to bore it out, probably needs to open up 1/16. Then I could use the stock bottom plate, as long as it lets it slide enough to collapse still.- 74 replies
- power steering
- electric power steering
(and 1 more)
Tagged with:
The Woodward u joint fits the datsun rack, and has a DD on the other side of the joint. That means you can use the lower Saturn shaft as is. You will just have to separate it to pass through a bearing with a 1 1/8 ID at the firewall. A 3/4 DD steering g rod fits in both the Woodward u joint and Saturn u joint. We need to try to find a bearing with set screws to attach to a pipe welded to a plate on the firewall for the sa turn steering shaft to pass through. Anyone know where I can get a bearing that's 2 1/8 OD, 1 1/8 ID WITH set screws to be able to hold it in place?- 74 replies
- power steering
(and 1 more)
Tagged with:
If you pull the Saturn wiring all the way out, it comes with a fuse inline, I think 80 amp. I will try to reuse that wiring if possible. I am going to remote the control box. http://forums.vintage-mustang.com/mod-custom-forum/787114-best-200-mod-ever-eps-70.html This is where I got a lot of info from. One guy was talking about running the power feed through a relay in case something ever were to malfunction, he could switch it off.- 74 replies
- power steering
(and 1 more)
Tagged with:
You have to take the bolt entirely out of the DD fitting where it connects to the saturn steering and it slides right off. That looks like the vue column.- 74 replies
- power steering
(and 1 more)
Tagged with:
Techno Toy Tuning Tie Rod
socorob replied to Keepn it OG's topic in Brakes, Wheels, Suspension and Chassis
I ordered mine a little longer than stock so I could get some camber gain without running out of threads. -
After getting it in and mocked up, the plan is to use the lower shaft from the Vue which is collapsible. Will do like Z power steering and just put a bearing at the firewall for support. Just needs a DD male fitting to Female Datsun spline to replace the round steering coupler. The motor will be supporter by the upper column, plus a small L bracket from one of the mounting holes of the steering unit to the column support. Should only have to drill 1 bolt hole in the column.- 74 replies
- power steering
(and 1 more)
Tagged with:
We had 2 78 280, one complete and 1 with bare interior. We did a few mockups, looks like motor may be able to go towards right with a small notch in column support and without factory AC. I have vintage air and my ac blower is in the way. To the left and up it will just fit with just about zero wiggle room. Either way looks very tight but doable.- 74 replies
- power steering
(and 1 more)
Tagged with:
This is the plan I came up with. I really want to keep the collspsibility, and don't want to take out the dash to weld bracing into the column support. I will attach the upper section of the Datsun column to the top of the motor with the 3 bolts it comes with.I will make a 1/16 or 1/8 plate to the pattern on the existing upper Saturn tube and put a collar on it the Datsun tube can slide into and weld to. Use the Saturn spline piece to make a connector to go from Saturn to Datsun. Make a plate to bolt to the 2 bolts on the lower side of the motor and weld a square tube to it that a 17mm couple for the Saturn spline can fit into. Slide another square tube either into it or over it and weld that to the firewall plate. Between the column support and firewall plate, that should keep it from twisting. Use a DD collapsible shaft from the 17mm Saturn spline down to a u joint that's DD on one side and Datsun steering rod spline on the other. Does anyone know where I can buy square tube and they will test to see if they fit snugly inside of each other?- 74 replies
- power steering
(and 1 more)
Tagged with:
113 is the Dastun Spline part number in the woodward catalog.- 74 replies
- power steering
(and 1 more)
Tagged with:
I took my Saturn and Datsun columns apart last night. On a 78 it looks like the motor will barely fit clocked at the 10-11 o'clock position. Does anyone know if removing the steering coupler like the ez power steering kit does will cause any issues? Woodward sells the Datsun u joints and splined connectors, so you could use a DD collapsible shaft on the saturn end and put a DD-Datsun spline shaft to connect to the steeering rod under the hood. http://woodwardsteering.com/PDF/3.%20Steering%20Universal%20Joints%20and%20Splined%20Couplers.pdf- 74 replies
- power steering
(and 1 more)
Tagged with:
Thanks for the picture.- 74 replies
- power steering
(and 1 more)
Tagged with:
I have a 78 also, could you take a picture of it under the dash? I put an aftermarket ac in mine and it encroaches into the drivers side some, so I am worried it will cause problems with the electric motor.- 74 replies
- power steering
(and 1 more)
Tagged with:
Front side marker lights as turn signals
socorob replied to dmoralesbello's topic in S30 Series - 240z, 260z, 280z
WhATS the part number of the socket? -
They look like NB Miata seats.
Is it a momentary switch?
- 21 replies
- Indicator
- turn signal
(and 2 more)
Tagged with:
Camber change after 1.5" drop?
socorob replied to mtnickel's topic in Brakes, Wheels, Suspension and Chassis
Do you need to weld some type of washer around the slot, or is the metal in the crossmember thick enough to not wallow out? -
TrackZpeeds CXRacing LS1 T56 240z
socorob replied to trackzpeed's topic in Gen III & IV Chevy V8Z Tech Board
Don't lean on the strut bar after running hard for awhile, that sucker gets hot! -
Either on their facebook or website I saw a picture and you could see the metal frame behind it.
fuel Injection cut off switch inertia safety switch
socorob replied to zgeezer's topic in Fuel Delivery
They're in the trunk of crown vics too.
