Evan Purple240zt
Everything posted by Evan Purple240zt
  1. Or you could have the driveshaft shop do it for 30 bucks... lol
  2. I blew through in a hurry, but you should have signal at center pin of the o2 sensor plug and power one one outside leg with ground on the other. Those are the heater wires. It would not shock me if you don't have your ground or power on the heater which screws everything up too. As for the leaky TB, its shot if thats the case. There is no cure unfortunately. If its minor enough, I say tune it out and be done with it. Evan
  3. It boggles my mind how fast you get swaps running... lol
  4. Mark, you have the bolt set? Sweet. Sounds like a great deal. PM sent. Grumpy, that vice is sweet.. I think between these two things I am golden. Thanks guys!
  5. I had trouble with a 30 gal craftsman when I painted a car at one point. Not enough flow. Panel painting would have been fine, but thats not the right way to do a whole car. It will look like it has been panel painted most likely.
  6. Well, I did end up getting that motor-less drill press. I also got a motor off of craigslist. So for the paltry sum of 85 bucks plus gas... I have a big upright press. I have the slotted table that looks like you can slide the head of a bolt underneath to clamp things tight. That seems like a pita. Do you guys use any type of clamp that you like? I had my first piece try to get away from me yesterday *yikes*. I don't have any holes that go completely through the table. Evan
  7. Hey dude, if you run across a deal in Madison let me know. Ill be happy to help you complete a deal here. There are alot of welding shops here too. Let me know. Evan
  8. Phil, Ill call the sx trans marginally stronger (at your power level). Evan
  9. Considering I smack intercoolers on crap all the time, the cheapies are awesome. As much as a higher end piece would be nice its just not gonna be as tolerable to smash them into things.
  10. Wow, thats a nice looking setup. I just missed a pair of those seats
  11. Do either one of you hooligans have access to a hood release cable for that car? I want to attempt to put it in my 240sx. I need a longer hood cable and can't think of a better candidate! Email me if you can hook me up! Evan
  12. Your not going to find anything cheap and in those sizes, thats for sure! Pretty extreme fitment!
  13. Thats exactly your problem then, if your goal are those power levels you need a 14psi spring. A 7psi spring was dropping boost at about 17psi for me. Evan
  14. Deal fell through, they were VW seats. My first set was from a bmw, which there are some bmw recaro kits on ebay.
  15. Tony, if the car is making 7psi anyway run a 7psi spring. I had a helluva time with my car running a 7psi spring and trying to run over 18psi. It just wouldn't do it. Wastegate kept blowing open. I have had great luck since swapping to a one bar spring. Wouldn't surprise me if you gained a bit of boost response moving to a 7psi spring. Seems that it won't change your minimum boost anyway. Its likely the case that w/g won't flow enough to allow you to run 3psi (and why would you want to). Best of luck! Evan
  16. The turbo should spool faster with a larger downpipe. If your gate isn't able to allow you to run 3psi, either the routing of the exhaust is not flowing enough or the gate isn't big enough to allow you to run 3psi. Sounds like its not normally a problem, but during cold weather it becomes one. You might have the gain set too high on the controller as well, which will allow it to overshoot boost by opening the w/g too late. Evan BTW, don't you have that tial 38 piped off of an internal wastegate hole? I had that setup a couple years ago and boost was all but uncontrollable. Moving it to the exhaust manifold made everything more consistent!
  17. Dennis, I am in the process of getting a similar pair of seats and have not yet found an upholstery kit for them!
  18. 650 for a pair of seats is a very good deal IMO. Evan BTW; Nobody is going to do a worthwhile job for 300/pr of seats. That damn near eats up all the materials costs.
  19. I had a crane box just crap out on me. Switch to MSD if its a huge concern! Evan
  20. You have a 3psi spring and make 7psi anyway? Yeah sounds like a dead/dying solenoid to me as well.
  21. Pretty common actually, alot of guys stretch tires like that when the bead won't seat. Evan
  22. Bummer dude, sorry to hear of these tribulations!!
