primaz
8
Everything posted by primaz
2+2 Chassis Reinforcement
primaz replied to Twisted46's topic in Brakes, Wheels, Suspension and Chassis
My cousin used those on his caged Maverick, they work great. You just push it down and it disengages the bar so you can slide it out and when they are put back in place they just pock up and locks. They are plenty strong. -
I would recommend options like this, if you must have door bars, as these will allow the bar to swing out and are spring loaded making it easier than pins, etc. http://www.1962to1965mopar.ornocar.com/mmo102002.html I would also try not to go crazy on the bars as you can try to limit bars around the passenger area. There are also retractable 3 point and 4 point seat belts or just do 5 point harness on the drivers seat. Believe me most women do not like seats with 5 point seat belts nor do they like any bars near them as they are worried about being hit by them, etc. You also should consider more comfortable racing seats like the Recaro and look at their Comfort series or Dynamic which is more race but still reclines; spend more on seats that are leather, recline, adjustable and comfortable. There are a few brands that can do that and have handle a 5 point belt but not many. -
The V12 will be a head turner. One thought on the cage as it really is for safety as you can get the stiffness with frame rails and strut bars; you can have the door bars swing out and there are spring activated locks for roll bars. My cousin did this on his hot rod so you have the side protection but still enables easier access. People forget that yes they are ok with climbing over bars but most others are not -
Are you talking about that Race Cast LSV12? I think it has that cool factor being a V12 and does use LS engine mounts, but that I believe is a cast iron block, so why not get an aluminum block LS instead as you get the same horsepower & lighter with much more options in parts, etc.? I am all for cages but the reason why I mentioned what I did on my mild street Z's is that to me it gets the chassis stiffness without the need for a cage which is good for a more street car. Your significant other will typically not like being in a car with bars all over and if they have to climb in or over bars that car will only be driven with you in it and sometimes that causes people to sell the car unless it is for the track and they have the funds to have a lot of cars. To me for the street you really only need a cage if you want to track it and the rules require that or if you are going to the extreme and the car could roll, etc. due to crazy speeds or extreme racing. I do have one street car that does have a semi-cage because the goal is over 200 mph on the street yet I did not go all the way as I did not want to go over the line and make the car impractical for the street, which is easy to do. You car sounds like a cool build but be careful not to go over the line as it sounds like your car is like my cars primarily street. -
Twisted, One other bit of information that I wanted to share as I know many people are using the Bad Dog parts but what I did was have Ken at Dando's Automotive in Fremont, CA whom did their own versions which I feel is way better than the Bad Dog which is not fully boxed. Their first version was done on my RedZ 240 where they mated two heavy gauge steel U shaped pieces that are just a bit wider but not by much more than the stock Z rails and by welding an inside and and underside piece they form a fully boxed rail that appears stock if you are not a Z freak. On my wife's orange 240Z they used their new design which is a fully boxed heavy gauge steel rail that is welded just on the underside. Either way that creates a fully boxed frame and that I believe creates a stiffer setup than the Bad Dog non boxed rail. -
1976 280Z RB30/25 (R.I.P.S.)
primaz replied to artishard116's topic in S30 Series - 240z, 260z, 280z
Great build and would love to know all of the tweaks, etc. to get the RB engine in there! I plan on having RIP's build me an RB30 turbo for my 240Z Primadonna Z. Very curious to see how the intercooler and the turbo piping will be installed. Please continue to post pictures when you are doing the rest of the build FYI, on another restomod 4 door that I installed a mild LS1 that I have completed, you might consider using the Heatshield Products, https://www.heatshieldproducts.com/lava-shield and line the entire tunnel and under all of the exhaust pipes. I wished I had done that on my other restomod but I did not think of that before I installed the engine so I did the best I could be adding it afterwards but not as good to do as it would be to do on yours now before too many parts get installed. -
Twisted, I agree that a cage is needed for safety for a track car. What I do think is that for a street car the frame rail upgrades can achieve a lot of chassis stiffness that is better than many mild cages but not as much as a more extreme cage. For the street it is good to me as you get more stiffness than just a simple hoop cage and strut bars and more than a cage with a hoop and even a diagonal bar. I have another 240Z with a 9 point cage but not a full cage, it has a hoop that is welded also to the strut tower, a welded bar between the strut towers, welded bars behind the strut tower to the back of the car, a diagonal bar going to the passenger floor area near the tunnel, bars from the front towers to the center of the firewall and my other two 240Z's with the frame rails to me are about the same and possibly a little more as I can jack the car and have three wheels off the ground. I was very impressed with what the frame rails can do without a cage but do plan on adding them to my caged car which is also a street car. There are lot of people that do a more simple cage for the street and then you have more hassle for using the car on the street and the frame rails can do the same or more for chassis stiffness but they do not protect against a roll over or other types of crashes, although it did save me from the rear end accident thank god.... -
The do make great products and I am upgrading one of my 240's to their upgraded front/rear A-arms, tubular crossmember, inner/outer tie rods, and steering knuckles. One of the shops Dando's Automotive in Fremont, I use is in early stages of installing the Track Attack package. They are waiting on parts from Apex to finish the install. I did look at where they are on the install and it looks cool. What I have heard is that the kit so far is well made and installs with no issues other than Apex really should provide a good written installation instructions, thankfully Dando's is very skilled at fabrication and Z's so they figured out the install but probably wasted 2-3 hours due to the lack of instructions not provided. You do have to mod the rear spare tire well so I do not believe you will be able to put a spare tire in there unless it is 100% flat with no air? but who cares I too am eager to see how it works and right now I do plan on using the Track Attack kit for my Primadonna Z in the future when I have time/energy to get back to that build.
I do not see rolling the fenders on a 240z affecting the value in my opinion. If you roll the fender the car looks stock and if you use the tool jhm mentioned you can get a custom offset wheel. I have two (2) 240Z's no flares but both have rolled fenders running 16x8.5" rims running 245 40 tires on all four corners which fills up the well very nicely and looks very clean. The extra width makes big improvement in handling... I have seen others even put wider tires than I have with no flares either just squeezing it to the max. I wanted to keep all four the same so I can rotate the wheels to get the maximum use of the tires. If you do not lower the car as much you can run the same tires as I have. The Red Z is pretty low, around 4" off the ground and the orange one is higher.
jhm is right you should look at Tire Rack and see what tires are available. You do know that you can get custom white lettering stickers to stick on any tire, with that you might widen your options going to a 15, 16, or even 17" as a 240Z with coil overs can typically take an 8.5" wide rim and if you roll the fenders you can easily put 245 or even a bit wider on all four corners. The smaller diameter tires are being phased out so your options are limited...
What I have found is that by upgrading the factory frame rail sections from the rear all the way to the front it works better than a cage which is great for using the car for street and track. I had this done by Dando's Automotive in Fremont, CA. Their first versions were using heavy gauge "u" shaped rails under and inside the car which mimicked the stock which was hard to even see it was modified. The second Z we did there they found a boxed steel that was just welded underneath and that worked almost as clean without needing to weld inside. FYI, I have a third Z with a 9 point cage and these other more stock street machine Z cars have a chassis in my opinion is as stiff if not stiffer without using a cage! Also as proof my RedZ was on the freeway stopped in traffic and a Prius hit me at over 55 mph and the car was not totaled nor was the chassis bend bad at all and I survived, which I might not have if I did not do this frame rail work. That is why I did it to my wife's Z, just purely for safety not for performance for her Z. I included two pictures of the car after getting hit and one after fixing it. If any 240Z got rear ended this hard without the frame rails it would be totaled and me the driver probably might not have survived or would be injured for sure. The crushing of the rear stopped due to the rear frame rails being so strong. I got pushed into the next car and was so pissed off but so glad for the frame rails as it saved my life and my car's life! -
curious to know what are the best L Series Transmission options now?
primaz replied to primaz's topic in Drivetrain
Wow that is cool, I did not realize you are on this forum; you designed the kit at Godzilla! That new kit you are developing using the TL70 sounds like a great transmission option, when do you think that will be available and where will it be sold? Hopefully this will help people understand my goals. For the two (2) 240's I mentioned at the start of this post, they are street cars mainly with weekend racing in the mountains. One is more mild with a Datsun Spirt 2.8 stage 2 and the other is a Datsun Spirit 3.0 with my head that DL Potter ported. Both are sporting coil over suspensions with 245's on all four corners & Arizona Z car Wilwood brake upgrade, one is more mild for my wife and the other has every APEX Engineering option to upgrade the stock suspension. They are fine right now both with Nissan Competition 5 speeds but my question was since it seems like nobody has parts and I am not sure if I can ever get them rebuilt, is why I wanted to know what the options are if one of those failed. The intent is just reliable Z cars to street race and have fun with. Neither car is focused for the quarter mile but rather spirited driving on the street. I like how the Nissan Competition tranny can provide good acceleration thru the gears with the ability to control the car in the mountains leaving it 2nd and third in hard cornering and ability to downshift even to first gear in a 15 MPH corner. We both like the feel of stick shift and want the Z's to be great general purpose sports cars to punch off the line but mainly drive thru the mountains curves. I have a more extreme 240z that I am building and that will have a RIPS RB34. I am too far away from finishing that so I have not looked into what other RB owners are using for transmissions. When I finish that car it will be a street car like our other Z's but intended to race other exotic sports cars on the street in the mountains and freeways; it will be putting down 700-800 HP and that car is the famous Primadonna Z car with massive 345's and 285's or possibily 315's in the front, but that is a couple years away... -
I think that is why that full kit for $4750 is more of a true cost as it includes the 6 speed tranny but you still need to factor another $200-$500 for shipping so it is really more like $5350 most likely. I think any good tranny will be around $5K when you are all done but will it be easily serviced in the future? That G-force T5 could be a good option if that company stays in business so that the internals can always be rebuilt? I love the Nissan Competition 5 speeds, my only worry is I am not sure what or where to go if I break it? They shift so nice and really increase the response of the Z but are so rare nowadays... -
so you mean a Borg Warner T5 transmission used in Fords will bolt right up to our Nissan L-series engines? and then use G-Force Transmissions to build up their internal gear set https://www.gforcetransmissions.com/tran_gt-5.asp ? Am I understanding you correctly? and what do you mean by DS? -
I read that Hoke Performance is no longer making his kit to adapt the 350Z 6 speed transmissions to the L series engines. I have two (2) 240Z's with 2.8 and 3.0 liter engines both with the rare Nissan Competition 5 Speed close synchro 5 speeds but not even sure if there are places that and rebuild those anymore if anything every happens to them? I think Les Collins Racing all the way down in Australia may still work on the Nissan competition race boxes but not sure if anyone in the USA does? What are the options now for an L-series engines as far as transmissions? I am just curious as both of my trannies are in good shape but curious as to what you guys are doing now if you have a performance L-series engine? I saw this kit for the CD00A 6 speed for $4,750 but that requires a GPS speedo as there are no provisions for a manual speedo and you need to cut the stock transmission tunnel (not sure how much hacking that means? Also gear train noise prevalent with these trannies, not sure how loud or annoying that is? I used SPEC 1 clutch on my Nissan Comp 5 speeds and really like how they work for a street car, wondering how those work with the CD00A as they say the noise is different with different clutches? ). https://www.godzillaraceworks.com/drivetrain/complete-cd00a-6-speed-swap-for-l-series-engines What other transmission options are there for an L-series now?
I thought the idea of the SubtleZ kit was to give you 1.5" extra width without looking like it was flared, so why add any lip flares to it? A stock body 240z with rolled fenders can easily handle a 245 in the front and a 245 to 275 in the rear with the right offset so with 1.5" extra you should be able to add some healthy rubber on the ground... I am going to build a RIPS RB34 for my Primadonna Z; love his engines!
Electric power steering, use complete donor column?
primaz replied to 280Z-LS3's topic in S30 Series - 240z, 260z, 280z
That was where we installed in her car, here is a picture from their website. In person you really have to look from below to really see the motor. When you sit in the car you never see the motor and it is not in the way at all. I think the picture makes you think it is low but, you really cannot see it easily as I had to crouch down put the camera below the seat and angle the camera up to take the picture. I think this is a nice power steering setup for the early Z cars. -
I installed the Silvermines EPS kit with their GPS speed sensor setup on my wife's 240Z and I am really impressed with it! It works great, it is clean & looks like it was made for the car as it is hard to know it has been modified at all (I had to angle the camera up so you can see the electric PS, otherwise you would never see it in the two pictures below), and the car drives like a new car. You can parallel park the Z with one hand! and the response is very nice at higher speeds with the GPS sensor enabling it to track like any modern car, very smooth at any speed and obviously quicker when parking but almost too good as I am OG and now her car drives like a new Z car. I do not have any regrets for that car and do highly recommend it. This car has custom kick panels with separate tweeters and mid-bass speakers so we mounted the GPS up high around the firewall out of sight but still accessible if needed. Only thing was not clear is that they did not provide a install manual but after talking to them their pictures online show all of the connections, etc. labeled and highlighted, so their manual is just looking at the pictures online;; it was easy as it was well engineered so no mods needed at all. It goes in fast but it took a little time to find the place to mount the GPS sensor module. On my other mild 240Z with a 3.0 liter I am going with the Apex shorter steering arms as I just want to see how well I can go with stock as I personally like the more manual feel, but the Silverline EPS is a cool setup. https://www.silverminemotors.com/datsun/datsun-240z/power-steering-kit-electric/electric-power-steering-kit-for-240z-260z-280z-datsun-1970-1978-s30 -
Understanding offset with 17x8 and 17x9 wheels
primaz replied to daxbrook's topic in Brakes, Wheels, Suspension and Chassis
Really every Z will be slightly different depending on the suspension setup etc. Really the best way is to go a good tuner shop or tire/wheel company with your car as they will have the wheel tool to measure what is the maximum offset to fit the largest tire and wheel for your car especially since you have flares on the car. As an example on one of my 240Z's that is stock body but rolled fender lips & BC Racing coil overs, we are running 16 x 8" with +13 with a 5" backspace and the car is running 245 wide tires on all four corners. When you flare a car and done suspension mods you should easily be able to much wider than a 245 size tire. I have seen some people max out a 240Z with no flares and even get 275 in the rear. Thus with flares you should have cut out enough of the stock body to go way wider than limitations of stock body Z. Do not skimp on the cost of the wheels is what I recommend and thus go with a 3 piece wheel that you like the design and have a shop measure it for you to find the ideal offset, etc. and stuff the most tire and wheel you can. You can also rent that tool for around $50 to $75 dollars with a deposit of a few hundred dollars or so and measure it yourself. You will never find someone with the exact same setup as you, etc. so l recommend to do it right and measure it then buy... Also look at Tire Rack to see what is the available tires for that rim size as that might influence you to go to a different diameter wheel and tire. 16" sizes are getting harder compared to 17" and larger as newer cars dont use 16" anymore but there are an ok selection with 16" but ultra low profiles are harder to find. I find it laughable that people cut up a 240Z with flares only to put the same size tires I did with a stock body. I am all for flares but to me you should be gaining with wider tires not just doing it for looks... -
I agree 100%, Datsun Spirit in my opinion if the best Datsun L series engine builder and I would recommend them over Rebello. Eji take so much pride in his work from his more mild affordable engines to his more expensive 9000+ RPM engines. There is no cheap way out but remember a quality blueprinted engine from Eji will be reliable and well worth the investment. There is skill in a quality engine builder so I recommend to just go with a proven builder like Eji. If you want an engine at that level expect to pay $17K or more for his stage 5 engine but if you look at any modern performance car like a BMW, Porsche, etc. you can expect to pay the same for a new factory engine so for a Datsun L series you can get a incredible powerful, reliable engine that will last longer than those new modern engines and have low maintenance as L series engines are so easy to service compared to any modern sport car engine. If that price is out of your budget then get his Stage 4 for around $12K and that is a great engine that will rev to 8000 comfortably and put down 300 HP at the rear wheels. Even his stage 3 will rev nicely and put down 240 HP at the rear wheels for only around $6,800 and is a great setup for your ITB's if your budget will not allow for a Stage 4 or 5.
I would call and email them as they are generally pretty responsive and do have spare parts..
I think their new "Track Attack" front and rear suspension is the way to go if money is not an issue. I am planning getting that for my extreme 240Z build. https://www.apexengineered.com/store/p26/TRACK_ATTACK_-_Complete_Front_And_Rear_Kit.html
- 7 replies
- 280z
- technotoytuning
(and 4 more)
Tagged with:
Yes, I highly recommend Market Auto in San Jose, CA ask for Dave They are at 140 San Jose Ave, San Jose, CA 408 292-9888 They have done two of my 240z's Here is the one I finished recently for my wife. The car was stripped to bare metal, all rust repaired, seam sealed, undercarriage painted with POR-15, rear valance/fender seams weled, new rear inner fender wells, painted with Lambo Merci-lago three stage orange, 911 Porsche mirrors.
Also as far as brands I would highly recommend CCW they make quality, reasonably priced custom off set 3 piece wheels and are well respected in racing and performance street users...
- 5 replies
- light weight wheels
- 3 piece adjustable
(and 1 more)
Tagged with:
One thing to consider is that now most of the best tires are moving to 18" or 19" so when you go with a 16" or 17" you better look at the tire options and really make sure you want to stay with that diameter especially if it is a street car as the quality of tires can be very limited. I have two 240z's with no flared bodies with custom off sets and they are running 16x8.5 with 245 on all four tires but there are only a couple of decent tires and the prices is a little high. My more aggressive street 240Z has monster 345 and 285 15" but now I can not get tires for that size so I am going to go with a 19". One of the best street tires is the Michelin Pilot Super Sport and they only make one size in 17" but in 18" and 19" there are a great array of sizes, https://www.tirerack.com/tires/tires.jsp?tireMake=Michelin&tireModel=Pilot+Super+Sport&partnum=43YR9PSSXLV3&vehicleSearch=false&fromCompare1=yes I would first look at the tire options very carefully before you decide on the rim size...
- 5 replies
(and 1 more)
Tagged with:
