tube80z
Super Moderators-
31
Everything posted by tube80z
Jon found on off the shelf spacer for the 280 spindle. It' this one if memory serves it's the legends one, http://www.drpperformance.com/resources/bearing-spacers-kits-and-tools-mini-catalog/ Cary
I tested 240 parts and found they would move a lot more than expected. 280 struts will be better but you can create a sheet metal gusset from the tube to the spindle housing. Jon did this on his car and I can dig up some pics I have buried somewhere if you need. You have to figure you are putting a lot of stress on your parts with bigger sticky tires, a lot more HP and torque, and now aero. Here's an image of a Ground Control modified strut. Note the gusset used to stiffen the spindle The next step is to build a custom housing but when you get there it's probably time to start seriously looking at an a-arm retrofit. I have been playing around with a simple design that uses Nascar and dirt track pieces. I can't decide if a 7 inch upper is long enough (allows for 3 inches of suspension travel) or a longer upper is needed. At 7 inches I don't think you have to put holes into the engine compartment for mounts. Cary
Reverse mount starter bellhousing, anyone running one?
tube80z replied to 1969honda's topic in Drivetrain
The bellhousing will fit based on my LS version that has a rear mount starter. You will need to cut into the tunnel to make clearance. My bellhousing took some hammer work to get the top to fit and the aforementioned starter clearance hole. For your clutch look at using a rally version (cerametallic that's thicker). Those are still severe but can be slipped a little. Cary -
Relocating LCA inner pivot point
tube80z replied to socorob's topic in Brakes, Wheels, Suspension and Chassis
It was part of a lot of changes. Part of that was to reduce bumpsteer and have the arms closer to level when operating since the car was lowered. None of this was tested a single item at a time so take that into account for the lap time difference. The car was around a second faster on a 48 second lap (now 47). The bigger difference, as Jon mentions, is you could do that repeatedly and it wasn't so hard to drive. Cary -
Megan S13 coilover review after 7 years of use
tube80z replied to 240zdan's topic in Brakes, Wheels, Suspension and Chassis
I've always had good and luck with Bilsteins. It sounds like Megan simply took a shock and inverted it to act like a strut and that is the root of the problem. There are people mixing and matching parts between bilstein and stance that might be an option too. If you don't need the adjusters I'd probably go for the bilsteins. I had a set that's been in three to four cars over the years with over 30K in kilometres on them. Hope that helps, Cary -
Please help me buy my garage lifts
tube80z replied to RebekahsZ's topic in Brakes, Wheels, Suspension and Chassis
My only feedback is you might ask about lift speed. A friend of mine has a bendpack 9K lift and it is much slower than my 7K 2 post lift. I know this sounds silly but it is amazing how long it takes to lift the car off the ground. Perhaps not an issue on the 4 post lifts. Cary -
Funny thing, I have that crossmember in my shop right now and it's only raised 7/8s of an inch, not the indicated amount. Cary -
Not trying to get too off topic but I've had a fusion in my lumbar area and I can tell you that it only should be a last resort. I ended up eventually having many side effects and now live with chronic pain and all the fun that entails. Seriously, only as a last resort. Feel free to reach out.
Stiffer springs vs bumpstops
True, but much of that can be overcome by how we add the airdam, floor, and diffuser. They don't need to attached level with the car. Perhaps too into the weeds. -
Great rear diffuser article
tube80z replied to JMortensen's topic in Windtunnel Test Results and Analysis
It's worth reading many more of Willem's posts at https://www.linkedin.com/today/author/187006218. While he has worked in F1 for many years he's also an avid hillclimber and has talked about his own car on many of the technical discussions. His post about power and control is quite good as are almost all the posts he shares. Highly recommended. Cary -
Actually I'd argue you don't want rake, perhaps the opposite. Primarily because you're standing the windscreen up, which will add drag. Get the car low but perhaps run the tail down or at least try level and then nose down. Cary -
I personally would use shocks with a lot of rebound to pull the car down, just like NASCAR. That will allow less air under the car and help with lowering the drag number. The bumpstops I talked to Keith about were actually linear bump springs. The idea being he could run softer main springs at a higher ride height but when running this event lower the car and use packers to engage the bump spring. This would raise the rate similar to running a higher rate main spring but you don't have the rougher ride when using on the street at normal ride heights. These springs can stack solid or be used in combination with other rubber or poly bumpstops when maxed out from aero load. Cary -
I think it's cool they picked a Z. I'm disappointed that with all the professionals involved they didn't really do more. It would have been awesome to see this used to create some really cool one off parts that added more function than the flares. At least that was what I was expecting for SEMA. Cary
240Z LS swap : Anyone using the batwing pan?
tube80z replied to Ryan Merrill's topic in Gen III & IV Chevy V8Z Tech Board
A friend of mine had and LS with the JCI kit and we built a brace that turned the standard crossmember into a k-member. This was made from 1 inch 0.095 square tube and had 14 gauge sheet metal welded to it forming a skid plate for the pan. On more than one occasion it took a hit big enough that would have probably cracked or damaged the pan enough to ruin a weekend of racing. If you look closely on the attached picture you can see it. -
TC rod mount ideal location?
tube80z replied to heavy85's topic in Brakes, Wheels, Suspension and Chassis
What is the distance from the stock pivot? I'm hoping to finally get all the pieces in place this week to drop all this is susprog. Cary -
Dry Sumpin' it... What worked for you?
tube80z replied to Mikelly's topic in Gen III & IV Chevy V8Z Tech Board
All manufacturers of hose will have limits for their products. These will lbe temperature limits, working pressure, burst pressure, bend radii, and vacuum for each hose family. Some of the newer high tech hoses can handle vacuum fine (Starlite, BMRS, etc.). But best to check your master catalog to know. If you need to make a sharp turn from the pump to the pan is another issue. So if either of these are the case then you'll need what's called AN hose inner support springs. You can find these at Jegs, speedway, summit, etc. Each manufacturer will have a special version for their hose if needed. The problem is that the pump generates considerable suction and when the oil heats up the hose it gets very pliable. These springs will keep it from momentarily pinching off. If that happens you loose oil supply and bad things happen. It's not as big an issue on the scavenge side but you still don't want a hose getting pulled shut. It all comes down to the pump and the hose rating. It's not whether or not the hose is any good. General rule of thumb is on any of the new high tech hose solutions the non-metal braided hoses will not have enough vacuum resistance to be used in a dry sump system. I'm using BMRS progold plumbing for my dry sump and section 1.2 of their master catalog lists AN 12 hose as being capable of withstanding 28 inches of mercury of vacuum at a minimum bend radius of 2.5 inches between -57 to 400 degrees Fahrenheit. At diameters larger than AN 16 these ratings drop quite a bit. Hope that helps, Cary -
Techno Toy Tuning - GTX2 Control arm and T/C Rods
tube80z replied to ktm's topic in Brakes, Wheels, Suspension and Chassis
I think 10 or more years ago I took a racecar engineering class from ICP. It was two days in a shop for 12 to 13 hours each day. The topic of bumpsteer came up and the shop owner had one of the gauges above. Steve Lathrop said they were fine but there was a much cheaper setup that was faster to boot. His rig was a welded frame with two roller bearings that ride along the plate. He did warn it's best to measure near the actual radius of the tire so not to have error get out of hand. To use this setup you run the wheel up and down and watch the gap on the rollers. Make a change and note if things are better or worse. Repeat until the gap is very fine 1/16 of an inch was good enough for them. Done this way it should go much faster. I made an even cheaper version of this using 2x2s so I could get this done between races. This is more about process and less about tools. The longacre system is nice but unless you need to do this a lot I'd try a lower cost set up. Cary -
And they shouldn't. Carol Smith would not be happy. -
My guess would be they found it didn't work and went solid. Nice end they used. -
Nice find. Having taken apart Bilsteins and my Penskes you can see a very big difference between the quality of the pistons compared to the BC shocks. Penske have a lot of pistons available in 46 mm that are available as castoffs on ebay from NASCAR teams. Swapping the pistons would be a nice performance upgrade. Cary
Are you running vacuum springs in your scavenge hose? -
LS/T56/240z Project Mentor Wanted
tube80z replied to RebekahsZ's topic in S30 Series - 240z, 260z, 280z
A few thoughts. You could make some nifty rocker extensions like the front splitter to lower the car and keep air from rolling under the sides. You could even turn that into a nice flat bottom too. We need to have a discussion about bump stops/springs and packers. You can keep your softer ride for the street and have 500+ springs that can be engaged by pushing in some plastic packers on the shock shaft. This keeps the car off the ground and when the event is over you remove them and gave softer springs back. Think valve spring on the shock shaft that you can turn on or off. It's really great watching someone so passionate about their Z. You are definitely a true HybridZ person. Cary -
Love the pics but one thing I notice is that you have a lot of air going under the car. Can you run a rear spoiler? It's pretty amazing what you have accomplished with your car. Kudos Keith! Cary -
I'm going to guess 4 inches then. I can try lower or higher to see how that goes. Actually, I'm going to move a number of things around so everyone can see effects of moving pickup points. Cary -
One area to lose some weight is the clutch. Go to a 7.25 or 5.5 multi-plate clutch either use a flex plate with flywheel or integrated unit. That will get you 15 pounds or a tad more of rotating weight. These aren't as expensive as they used to be and you can find good used ones on ebay from the nascar cast offs. Lithium battery is another easy upgrade. Good luck getting the cars all on the same line. That would be very cool. Cary
