tube80z
Super Moderators
    31
Everything posted by tube80z
  1. I don't think you need to go that large. I'd use the same tube as you would for a strut bar for the purely torsion stressed members unless you already have the material. It will just weigh a little more in the end. I think you have a couple options. You can do it in tube similar to what you have or was used on BJHines car. The other is to make a larger torsion box out of sheet in similar thickness as the rest of the car. Look at the convertible torque box mod for Ford mid-to-late 60s Mustangs and Falcons. They have a very similar unibody design to the Z. In those they build a box that goes straight down from the firewall and then back into the floor. This connects to the engine bay side. Here's a couple of links to give you the general idea https://ironhydroxide.blogspot.com/2017/04/boxes-of-torque.html and https://ironhydroxide.blogspot.com/2017/05/boxes-of-torque-part-dos.html. I've also seen this extended down to the level of the outer rocker lip and boxed into the inner rail. Many of the IMSA Zs boxed in the outer section from the upper rail to A pillar down to the rocker. This makes that more of a torque box out of that section and can tie in nicely with something similar to the convertible Mustang mods. Getting across the tranny tunnel is going to require a brace under the bellhousing area or you add internal rails that go from the front frame rail up and over the tranny tunnel and down to the next side. If you look at newer cars you'll see they have integrated a 8 to 12 point cage into the unibody design. They just do it with folded metal rather than DOM tube. For a street car that may do some track work I think meshing the torque boxes with the tubes in the image above would be a good way to go. The new Mazda RX8 is a very stiff unibody compared to all their previous cars. If you look at images of it and compare to older models all these little details start to pop out. However you go I really like what you've done. I need to get some projects out of the way so I can get back to cars myself and put this year behind me. Hope that helps, Cary
  2. I love the level of work you're doing. The crash comment is one I've thought a lot about too. About 20+ years ago (vague) I witnessed the aftermath of a Ford Falcon leaving the road at not much speed and hit a tree. This was well below normal racing speeds (hillclimb event) as the road was wet. The driver suffered a broken leg, pelvis, and now walks with a limp. Why I bring this up is that the underside of a Ford Falcon is very similar to the Z cars. His car had a good cage and a racing seat. How he got hurt was the car rolled off the door bars when he went sideways into the tree and floor deformed as it was the weak element. And while he was held in his seat the car deformed and like a large lever broke his leg at the edge of the seat. To this day I can vividly recall his screams as the emergency crew removed him from the car. Making the floor stiffer is a good thing in my book. There are still a couple of areas to think about depending on how you intend to use your car (some could be handled by a cage). The main one I've seen where there's a problem is the engine compartment to passenger area. While you have the Bad Dog rail help there's no lateral protection in the front. I've heard that a few big crashes in Z cars have resulted in broken ankles as this area can fold in on your feet in a wreck. If you look at new cars they have structure that goes from the inner rail to the outer and this can be triangulated to the TC and upper strut mounts. Here's a picture of what I'm talking about. I have more ideas on fixing the firewall too based on newer cars.
  3. I'm planning on using the BMW DCT in a street car build. I weighed the costs of it against a T56 and the heavy duty 5 speeds transmissions and it was comparable. With the right ECU you can automate downshifts with throttle blip and all. Amazing what parts are becoming available for our cars. Really cool to see a Z banging around Bathurst with GT3 and V8 Supercars in the mix. Go team Z! Cary
  4. What are you planning for heater/defrost vents and will you use the Z heating assembly or the miata unit? Very curious for my street car project. Cary
  5. The one advantage is that you know the parts are now solid and not relying on 40 to 50 year old spot welds. And if you do ever bend it you can pull it straight. With just the spot welds they often shear and you can't pull the complete part. I learned this from talking to a number of unibody racers and seeing first hand when they did pit repairs. Cary
  6. One thing I've played with is using some of the late model car epoxy bonding. If the parts have good fit this seems to work, ideally probably needs some rivets too, which might be another problem that interferes with the sound deadening. Cary
  7. As others have stated it's probably too low but it also somewhat depends. What are the diameter of your tires? And if your suspension arms point up towards the wheels then you are too low and will be in the nether regions of the suspension geometry.
  8. There's a better way to do this but what you have will work too. If you mount the rod ends on the crossmember and then have the brackets on the control arm. This way you can change alignment but not cause changes to your camber curve or roll center. The third option is to let the inner end of the trailing arm float (no connection) and use a lateral locator behind the diff. I'll see if I can dig up some old pics and attach to this thready. Cary
  9. Do keep in mind that the way the crossmember is bolted in is considered a safety feature. It's designed to shear in case of a heavy frontal impact and allow the engine to go under the car rather than through the firewall. The downside to all this as you mention is there isn't a lot of stiffness available for the strut tower or the front suspension points. When you look at newer cars it's interesting to see just how much additional structure they have put in place in these locations. Cary
  10. It depends on what size chokes you plan to run. 45s with small chokes (aux venturis) flow less than 40s with similar size chokes. If I recall from memory that 33 mms is about the cutoff point where you'll find this difference. This will be an expensive and you want to think about what are future plans for your car. The other option would be EFI throttle bodies rather than carbs. This will be more expensive but probably offer better driveability.
  11. Thanks for pointing this out. I removed the spam. I'll let Dan know there seems to be a reporting error.
  12. As jobill stated you need deeper retainers. Nissan Comp used to sell ranges that had to be used for specific depth lash pads. A quick google search turned up many companies that seem to have the parts. You also need to make sure these don't alter the installed height of your springs or you may end up in coil bind or not have the correct seat pressure and then have valve float issues. Sorry to say that the wrong parts were used when you're engine was built. At least you didn't have the rocker fall off and get in their sideways and royally screw up the cam, which happened to me when I learned you couldn't mix and match parts. Hope that helps, Cary
  13. The really nice thing about switching to aftermarket calipers is you can get almost any pad in any compound. I've had good luck with Performance Friction. They no longer sell the same material I used but it was a medium torque, good initial bite, great release, and long wearing while easy on the rotors. This was the 01 compound. They now have a new compound that is supposed to be even better, the 11 is what I'd try. Keep in mind when they say medium torque they are looking at braking in the 1.5g to low 2g range. Stay away from the high bite stuff unless you're packing a lot of downforce. Or it will be skid city.
  14. I use a higher temp race pad on mine. You need to do some preheating to grid or warm things up some other way. It can make the first run rather dicey if you can't get heat into the brakes and pads. But having consistent braking with the rotors glowing red is really nice. Now only if the car was back together sometime this decade.
  15. I think the biggest reason for replacing the harness is its age. All those wires and connections are getting very old and who knows what you have for corrosion and any work hardening of the wire. It's a huge PIA to rewire a street car but you can use the existing harness as a guide and remove/add what you do or don't need and go from there. On modern cars you have a much higher amperage in the charging circuits so all that wiring, fusible links, fuse block need to go. And you're already pitching the engine harness for your Holley ECU so there's little left in the front. You'll most likely replace all the gauges so much of the dash wiring will be changed. And you can see it's not that much of a stretch to just replace it all. In the end you'll probably have a more reliable car and in the event something is wrong you'll know where all the skeletons are buried. If it's any consolation that's my plan on my street car project that I hope to start working on in the next year. Painless seem very proud of their products and I think you can find competitors that are less expensive and feature similar materials and workmanship. Hope this helps, Cary
  16. Guys let's try and keep this on topic, which was thoughts about the subframe. If you want to discuss business practices that should probably a different thread. I'm not saying you can't do this but this is the drivetrain subtopic. For what it's worth this is nothing new. I have seen/had this problem with all vendors not just Datsun specific parts. Any catalog that has the statement bolts-in is usually code words for if you can fab and have the tools to make it fit. Thanks, Cary
  17. Did you weigh before the conversion?
  18. You definitely need to do this or you may have issues by bending on your rack and it might feel weirdly stickly. If you corner hard you put a lot of load in via the lower control arm. Cary
  19. One thing to add is if you push the wheel forward to gain more caster then that small difference will be closer to nil. Like Jon said if you try and remove via spot welds you better have a number of cutters available. I cheated and bought and air powered spot weld remover. It wasn't cheap but oh boy does it make this easier. Cary
  20. I can't speak directly about the 280ZX suspension in a Z but we once used that setup in a 510 for rear disks and CVs. It wasn't a bolt in by any stretch of the imagination. I did a lot of research into trailing arms and it seemed like one of the big problems is the toe and camber curves are reversed. If the arms are close to flat in side view when the car is running then a lot of this doesn't matter. Bit if you lower the car and the arms run at any angle pointing up or down then you get a lot of toe and camber change. Any alignment change (toe or camber) will move the suspension pickup points and that changes a lot of other things. Add a lot of power and the car squats getting you into these outer extremes. To get around this we made a custom crossmember that had about half the trailing arm angle (similar to what BMW uses) and fixed the pickup points on the crossmember. All adjustment for camber and toe was on the arms. This along with mounting the crossmember higher in the car allowed it to operate in the sweet spot and worked really well on this 510. Previous attempts with the stock suspension included ever stiffer rear springs, which helped as long as the surface wasn't too bumpy. On my own 510 I tried a Z bar for a while and that really helped with squat and lift. Here's a Sierra example and you can see the fab work to reduce the trailing arm angle. If I were to do it again I would have used the rules that allowed any axle locating device to create an extra arm that would run behind the diff and connect to the trailing arm to control lateral load. Then use the outside mount on the cross member and not hook up the inner mount. You end up with the equivalent of what Subaru uses on many of their cars. Here's an example below, which is from a thread where Richard is talking about what he's going to do on his Z31.
  21. Sorry no idea. I looked at the admin section and there's no mention. It's not hidden but I'll post a note in the admin section to see if anyone knows why it isn't there. Cary
  22. The strings are a box around the vehicle. You don't really need to be centered but you do need to be perpendicular to the front/rear, which often ends up referencing a body panel or a crossmember. This is a good example of the work involved, https://www.turnology.com/features/easy-accurate-inexpensive-do-it-yourself-vehicle-alignment/. It looks more complicated than it is to do. You can also do the same thing with jack stands and fishing line but that takes a little longer to get setup. There are a number of videos on youtube that show how to do it various ways.
  23. The easiest alignment system I've found are strings. If you take some time and make a simple jig the is centered on the car these are easy to setup and use. If you don't need to worry about the car being squared up toe plates where you use two tape measures are also a good choice. But whatever you do will require access to the adjusters. The trickest system I ever saw was from Riley & Scott on a world challenge touring car. They had rods they screwed into receptacles on the frame. The had a laser and a target on the same end and on the opposite end you'd mount a mirror to the their setup wheels, which in this case were a special set of tires that were never used mounted on modified wheels that allow attachment of the mirror. The laser would shoot down the side of the car parallel to the frame and bounce off the mirror and back to the target. Accuracy was claimed at one tenth of a degree according to one of the mechanics I chatted with. He even let me inside the pen for a closer look. I like to go to the pro races and watch the top teams when they do boring things like basic maintenance. Setup wheels are used a lot and often while sitting on scales. You have much better access to all the adjusters and can do easier brake maintenance, ride heights, and so on. For most of us this would be a shop only item to use.
  24. Mine all cracked in the bend. The bolts into the body were still tight and a cursory visual inspection missed it until I pulled the diff and it was plain as day. I mostly had problems with the right side. Another SCCA EP car a friend has had similar handling issues so we looked closely and his plates had been cracked too. Same spot also on the right side.
  25. Hi Luigi, it allows the strut another axis of movement that isn't putting bind on the strut insert. If you have stock rubber bushings those probably allow enough movement this doesn't matter. WHen you take apart the rear struts and try to line them back up to go on the upper mount you often see how small changes to the pickup points (toe/camber) make it really hard to get back where it needs to go. The stiffer you make the bushings (poly, rod ends, or sphericals) there's less give needed to follow the path laid out by the upper mounts. There's a lot of good info in the suspension section stickies that discusses in deeper detail. I'd recommend the brace for any V8 or higher powered street car. Years ago I was sitting in a friends V8 car and he tells me to watch the tire from the side mirror. He proceeds to power brake and I see the rear tires toe out and not a small amount. Even on a lower powered car if you corner really hard I'd expect this isn't helpful. The brace helps to reduce this.
