tube80z
Super Moderators-
31
Everything posted by tube80z
I don't think $2500 a shock is all that expensive for a custom made piece of high-end race equipment. You have a record breaking car so I'm not sure why you think any one part of it would be inexpensive. The only "lower" cost DA insert I know of is either Koni or the Ground Control AD shocks, which I don't think they make anymore. There may be some options if you're willing to get creative and fab up some parts. Perhaps one of the Koni drag struts for a different model (Mustang/Camaro) but it sound like Koni isn't really up to snuff for this? Perhaps you could run a coilover shock outside of the strut housing. Years ago this was done in IMSA and other orgs as long as the rules allow it. It opens all manner of possibilities. You could even use the varishocks you have on the rear of the car at the front. You did start out by telling us that you were interested in Penske shocks or something similar and that you're a serious racer. So it sounded like you already knew this wasn't going to be a cheap request. It's not hard at all to get ballpark costs from the internet. So I'm not really sure where all the price sensitivity came from. It's called racing and the joke's always been you make a small fortune from a big one doing it. What it sounds like is you're trying to convince us Stance are the best DA shock for you and get us all to agree (fat chance). There are as many opinions on this forum as there are members. You did the research and have talked to them. If that's what you want then go with them. It's that easy if you have all the data points you need. It's your car, your money. You don't need to convince us. Get some great results and help stance in the drag market. I'm sure it would help a lot of people to see that they have a quality product you set records with.
First impression of Formula Atlantic slicks
tube80z replied to 74_5.0L_Z's topic in Brakes, Wheels, Suspension and Chassis
For the bias ply tires I'd probably start in the 18 to 20 range. You may need to run lower. They are more squirmy than the A6 you had and take more slip angle to work. When you turn you're going to need to do it quickly and a little more lock to compensate. Camber will be in the 1 to 1.5 range unless you have a lot of roll. If you're running front droop limiters you may need 1 degree or less. My old car settled on 0.5 to 0.75 degrees depending on the course. Even used these should amaze you. If you decide on new tires or Berget can get GY 15 inch atlantic fronts try them. Only in R160 compound. 10x23x15. Reports of them doing 160 runs still fairly well. Tighter than Avons but overall grip may be just a little lower. May seem expensive but should be cheaper than the A6s. Similar size but will last much longer. R160 compound requires a little heat but you should be golden in Florida. These are generally considered a good match for the Avons. GY used to make a slightly softer compound that was even faster but we can't get them anymore. We have a 240Z and an RX-7 (2nd gen) running those tires. They work well on both cars but since they are soft you can kill them easily of you don't stay on top of pressure and wear patterns (if you're not measuring tread temp). -
I have the $30 cheaper knock off and it looks just the same as the eastwood tool. I'd bet made by the same people but sprayed with cheap paint.
You're going to run an LS3 aren't you? You should be able to run those 6500 stock I guess that's only roughly 20k or so, which may not be worth the extra wear and tear. Keeping the revs down with help with oil issues too. Cary
The advantage of this system is you can build it so one bolt holds it on. Then a quick disconnect on the fan motor and the entire unit can be removed. Cary
Roll Bar/Chassis Bracing Tubing
tube80z replied to ls240z's topic in Brakes, Wheels, Suspension and Chassis
My personal thought is you'd be better off moving the cockpit front side of the cage to the firewall for you design. Or another idea would be to add tubing that mimics the bracing of modern cars in the engine bay. This would be similar to your cross tube in the cockpit. Then you can connect the strut towers to this similar to most cage setups that go all the way to the towers. And I'd add an inverted V that connected at the center of this bar and then went down to the engine bay frame rails. you'd lose about an inch doing this of space behind the engine but I think it would be helpful. You could also add doublers in the cowl that were either welded or structurally riveted. For a car with nice paint using rivets and modern structural epoxies might be an option. More expensive than welding but probably less so than having to touch up the paint. The plus would be not heating the metal enough to worry about oxidation starting. -
Not knowing much about circuit autos I'm interested. Do you still have the converter or is this a straight drive like a circle track setup? Also curious about weight. I'm currently setup to use a dog ring 4-speed but could see swapping if this looks better. Cary
Suspension configuration help...
tube80z replied to New-to-240z's topic in Brakes, Wheels, Suspension and Chassis
I'm not sure if this would work but for a no cost fix try swapping springs front to rear. Your setup if definitely front stiff so it doesn't surprise me that it understeers. On a Z you need to control roll at all costs so I don't think I'd do a softer front bar. -
My Dream LS7GTZ.......project underway
tube80z replied to cobramatt's topic in S30 Series - 240z, 260z, 280z
How much weight did you drop? -
Just guessing since it has a new front clip the wheels are moved forward. Easy to add fender behind them. Cary -
Seeking air compressor recommendations
tube80z replied to RebekahsZ's topic in Fabrication / Welding
A blast cabinet goes through a lot of air. I wouldn't use that as the main planning priority personally. The one thing I didn't mention is that I have a special connection that is before the main regulator (I usually run around 100 PSI in the main line), which is connected to the tank. It shuts off at 155 PSI. I use that one every now and then when I need some extra oomph. Nice option to have if you have a few tools or tanks that need the extra pressure. I have a tire tank that can hold 175 PSI if needed. I've used propane tanks converted to do this too. Cary -
My only advice it mount the compressor up high if you can. Then you can have the floor space for something else. Mine is in a loft in my shop and out of the way. I looped my main air line and all drops come off the top. Main lines are all angled down to one corner and I have drains at all corners. I have a special filter for my plasma cutter (looks like it uses toilet paper) and a desiccant system for the main shop. Probably not as good as an air dryer but then again this is non-commercial. The compressor is an old 7.5 HP Costco 2-stage cast iron compressor. Oil is synthetic and it's been in three shops now and is about 16 years old. Having the compressor raised makes it easy to drain the tank via a remote line I have running from the bottom. I use a contactor as a remote switch to turn the compressor on and off. Nothing fancy has worked for years. My blast cabinet is the only thing that makes it run continuously. The tank size is 80 gallons. If you want more air volume you can use a propane tank I got an old 150 gallon propane tank I was going to add but decided I already had enough capacity for the moment. Hope this helps, Cary -
Sounds like a great idea. I was looking to do the same thing. Converting to servo operation and using modern controls from a 350Z. Cary
jmortensen's "while I'm at it" roadrace/autox project
tube80z replied to JMortensen's topic in S30 Series - 240z, 260z, 280z
Love how the camera shakes when it revs. You beat me to startup -- great job. Cary -
Interesting, I never would have thought to use pistons for an ATV/MC on a car. You can download the Penske manuals and see diagrams of each and the curves they generate, which is maybe what he did. Unless the missing bit is missing was how he figured out how many shims to stack on these to get them to work. I also thought the comment about nitrogen pressure changing the dynamic roll center was interesting. Props to being willing to do this yourself. That's a lot of work with some odd components to figure out. Not a path I would have ever taken. Cary
Woodward also makes some nice pieces. Often can be found on ebay from ex NASCAR at bargain prices. Or you can add in the OEM collapsible pieces somewhere in the column. Cary
It's not cheating when allowed in the rules But I do think there's a legal way this can be done with the spacers. If they had an angle to them you'd move the steering arm. I can find no spot in the SCCA rules that defines how the spacer must be made. You also have the steering rack bushings that can be made different thicknesses to change the position of the rack.
You have been given you a lot of good advice. A lot of what will make you faster depends on you and how you do things. Are you the feeling type or the analytical type. Do you need to find things out on your own or do you do well with coaching. If you know those things it can help you find the resources you need. That aside one thing that is often overlooked is a good notebook and set of notes. You should have everything in these. From car setup to all lap times and printouts from the AIM. I keep detailed notes of what the weather was and what the track and air temp was when I was running. This might seem like overkill but as you have more time later in the week you can look over your notes and think about what you did and how the car was working. Many times you may find something you didn't think about when you are pressed for time. And when at the track you have a reference you can use for what to do, which is assuming that you are making setup changes. Even things as simple as what starting tire pressures to run. And what is the best hot pressure I should be at. With the gopro you can get a cheap little program (race render) that lets you overlay data onto the video. And if you have a couple of cameras (one that can see what you do and another for where you are on the track) you can see areas from the data where you can improve. To answer your question about the investment to map the chassis for building a suspension model it probably won't make you any faster at first. But if you know what to do with the data or where to ask the right questions (wonder where that could be!?) it can help make you a lot more consistent and help you with what to do next. Each car is just different enough there's no one size fits all approach. But as Clark mentioned you want the arms close to flat or pointing down when looking at the tire just a little. And if you have actual suspension model you can see what each end of the car has for various suspension curves and map this back against track data. This would be used to try and set the cars alignment and ride height in the best spot for the track. This sometimes will make you faster but generally it makes you more consistent and leads to better tire life.
Which one? I think there are three now that have died around oil related issues but I may be miss counting. We also lost an engine from counterfeit lifters that came apart. All were using a 3 qt or whatever the large one is. It was plumbed in the front of the block same place my dry sump will be. It cost $6 for a straight AN port to fit the plug removed. We used the manual valve and the electric valve but not the fancy EPC valve. I'm with Mike in that if you have a couple of oil events back to back I don't know if the accumulator is going to be of much help. I also had a chat with Kevin Johnson and he was telling me one of the issues that they ran across with accumulators was what happens when you push good non-aerated oil into the oil galley when the pump is pushing oil that has a lot of trapped air. The short version is that it doesn't always go the way you think it does. Can't say for sure in the LS. Many people use these systems and they work fine. But once you get to a certain performance level they won't work. That's when you start looking at a dry sump. A long time ago I thought they were overkill for what I did. But tires have gotten much better and dabbling in aero has pushed corner limits beyond what the wet sump can handle. You can do a dry sump for about $1500 to 1800 with some ebay shopping and perhaps less if you get a good used pump and some deals. If you use a 4 stage pump you'll also get a lot of vacuum in the crankcase so if you're looking at add a vaccum pump you won't need to bother. For an autox or hillclimb car I would recommend getting a water to air heat exchanger as it will get the oil up to temp quicker. I think for street tires at a track day the scraper, pan insert, and accumulator will probably be okay. If you add aero, higher rev, and/or slicks and the cornering is getting close to 2Gs then you're playing with fire if you don't upgrade. When you get close to 10K in a rebuild and it costs $1500 for a race weekend you don't want to be dealing with oil issues. And if my engine goes in the middle of a season I don't have budget to rebuild nor the time to get it fixed quickly. Hope this helps, Cary
I wouldn't do it so big. I'd only do a 2x2 or 2x3 size area. I don't think any larger will buy you anything extra. You also have the door side that can be boxed from the door post to the fender liner insert. Cary
A couple of options I could see. One is to change the tube you currently have from the rocker to rail (TC connection). Remove this and add back in so that it forms a triangle with the cross tube you have from the rocker to the rail. Option two is to add folded sheet metal on the firewall where it bends and bring this straight down and fold back to the floor. Connect to both frame rail and rocker. Then add in the tubing. The benefit to this option is you don't have to remove the existing tube from the rocker to the rail. This will be stronger for not a lot more weight. On the side of the car (not shown) where you have the tube going up you can fill in the area where the fill panel to the fender is. This is covered back to the door post making another box. That's about it for easy. You may want to look at seeing if you can add in a crosspiece between the frame rails that would connect with this new crosspiece/torque box. With the exhaust on the side it should be opened up just behind the flywheel area. If you need some pictures let me know. And to finish use the BMW example. Your K-member could connect to the TC box and back to the rocker rails. And you can can have a skid plate that connects the crossmember/k-member, TC boxes and across the back of the engine. The more complicated mods involve taking the rails apart and adding metal/tubing inside and working that in. Hope this helps, Cary
Yeah, I think we all love project Blinky. I have learned a lot from those two guys even though they act like they don't know what they are doing half the time. It's definitely an act. I have been doing CAD for some time though so that's nothing new. I do think you should sue BMW for using your K-member I think adding a skid plate underneath that connects to all the points would add a good bit and it's not a bad idea to have that under the car anyway. One thing to remember when you build any prepared car, or your V8 supercar, is that you don't build that cage and bracing in the car. Those bits are built and the car is added on around it. I used to do the former and got much smarter on my new car. I have taken major sections off by removing the spot welds and then make whatever I want underneath and then add back only the bare minimum. It's also given me a lot of ideas for how to make a street Z much stiffer. But that's about the only way the welds can be done on some of those cages. The main tubes are the required thickness for safety and all the rest are as light as needed by FEA. There are a few videos on youtube that show the triple 8 cars being built and you can see that the newer cars have even more cage bracing. And the most amazing rear live axle I have ever seen. When you first look at these designs they seem silly. But the stiffer you can make the car and still make weight the better. The reason as I understand it is since the chassis is a spring it requires you to raise the rates on springs and dampers to meet the targets you want for axle stiffness. The floppier a chassis the worse this is or you need to have a completely different method for determining the chassis setups. When the V8 guys went to the new COTF it caused them a lot of headache because it isn't as stiff as the old car. A number of drivers also complained about the feel of the car as the stiffer chassis is more responsive. A lot of the rules of thumb have changed. I have heard you need 5 times the spring stiffness for the torsion, also 10, and 20. It's really related to the constant learning in racing. I think Jon has some good shots of his exhaust. That's the one area I forgot to document on Dave's car. He did a 90 at the bottom of the headers and came out though/under the lower frame rail behind the TC box. It was mostly the thin lower section but he also had to notch the main rail a little and added back in some structure. I wasn't too worried since this was also tied to the cage. From there the pipes came out and around the front of the rails and down the side of the car. How close you can go depends on the mufflers you use. There are two downsides to this mod. The noise goes up and you need to be careful when getting in/out. But working under the car is much easier. Transmission and diff swaps are a lot easier and can be done on a car when it comes in off the track if needed. Hope this helps, Cary
