tube80z
Super Moderators
    31
Everything posted by tube80z
  1. If you play with Kevlar you'll need carbide scissors. They will probably cut up the blanket. I really don't think you have anything to worry about. But your idea of bonding kevlar to the tunnel or the bellhousing should work. You can get a bellhousing that's rated to contain the flywheel clutch for your setup. It's very heavy. Cary
  2. The QA-1s are called a slot bearing. They are a 2 piece design and not designed for the amount of vibration you'll see on the rear suspension. We used these first as they are low cost and they lasted one event and the liners pounded out. Then AM Auroras in 5/8 and they pounded out and then 3/4 X/Ms (not sure but their top lines) and they worked fine. I've done CMs on a street car and those seem to be working fine but it hasn't done a ton of mileage. It's your money but I don't think you need to spend $200 a rod end to get some that work. Hope this helps. Cary
  3. I had one on an L6 mounted similar and never had a problem. They are really good pumps and the controller worked very well to warm the engine as well as cool. I'm thinking about adding one to my LS too. Cary
  4. Tube adapters can be had in any size for most thicknesses in the 0.065 to 0.120 range. I'd agree with John that 0.095 would be good here. Very successfully used on a 2600 pound car with 474 WHP and huge slicks at hillclimbs, track days, and many autocrosses. To use the tie rod end you have to build a mount that is thick enough to have the taper needed. Then the rod end is inserted into this. Take a look at BMW lower control arms inner joint to get an idea. In the case of the Z it would be a bracket bolted to the strut housing. Myself, I would opt for using rod ends. Aurora, NHBB, FAG as John mentions all make quality products. The Auroras that died were the top of their line and their engineering department was sent the rod end. All I got back as that the surface area of the ball must have have been two small for the load, which is ludicrous if you look at what's listed as acceptable loads in their catalogs. All I know is the larger size worked fine for a long time. It may seem like these are a waste of time to build but changing from polly bushings to rod ends and the extra floating link helped the car put power down better. And not just in rough areas. All I figure is that a lot of friction was reduced. It also made changing the strut out very easy. One thought on the arms I forgot to mention is that using left right in 5/8 or 3/4 threads changes the toe very quickly. It might be better to use the same handedness and 3/4 on one end and 5/8 on the other. This would allow for smaller increments of change per turn. Hope this helps, Cary
  5. Flex plate is just for starter. The shiny metal bit on the flexplate is the new friction surface. They are sandwiched together with the clutch bolted to that.
  6. I personally wouldn't use the tubing thicker than (0.95). My reasons are that I'd prefer the arm to bend rather than the frame to get bent. Same argument for CroMo tube. The 5/8 rod ends that wore out were Auroras. The liner was pounded out of the fixed end of the lower control arm. Stepping up to 3/4 ball/race cured that. For a street car it would be interesting to try and use ball joint style ends. One of the local hot rodders uses Ford tie-rod ends for all his axle linkages. He said they were cheaper than rod ends and last about 5X longer. Only downside if you need to change the mounts. Rod ends are much nicer in that regard and you don't lose any alignment when taking it apart. Hope that helps, Cary
  7. If you do decide to rebuild I would look very hard to modern cars and how they have reinforced the tire well near the driver's feet. If your welding in tubing it wouldn't take a whole lot more to strengthen that area. It is one of those things you never want to find and when you have an attachment to a car it doesn't help. If you can overcome that and objectively look at what you have and different options you'll be money ahead in the long run. Good luck, Cary
  8. T3 plate or CrMo plate or stock TC rod modified. You should be able to get small samples if not there are online metal dealers. To fix the offset shear issue you can do double shear with a solid rod end. That was the planned next step if the single stick didn't cut it. But we never had a problem on a car that can break at 1.4gs so figured we were good.
  9. Ceramic can use lighter weight oil versus grease for lubrication. There is some info around wide 5 conversions for circle track racing. For the money they are probably not a good trade off unless you can't use a larger bearing and are losing a steel bearing during a race due to load or heat issues. I doubt that would be many of us. REM finishing and good grease along with the spacers would be a large improvement. When I checked on ceramic prices one bearing was the cost of doing all 4 corners.
  10. I have used those for a few years and I liked certain aspects but they are not a good street shock. They are digressive shocks and probably too harsh for street use unless you really want a canyon carver weekend toy. They work best on a race car with very light unsprung weight. They require yearly rebuilds as the seals seem to die and lose oil. The cost of the rebuild last time (a few years back) was $175 a corner. I had them rebuilt in the winter and they leaked most of the oil out before they were used in that summer all while sitting on a shelf. When I called GC they said they'd need another rebuild at the same cost. I don't think GC makes them anymore but will service what is out there. I wouldn't recommend them even if you can find a set. I can post pics of my insert and measurements it that would help. They are very short compared to most inserts you'll find. Cary
  11. I've done a few sets like that and used Subaru inner rack ends. They are metric but look very similar. I've seen some Triumph or MG products that were similar but probably standard threads. Keith, the clivice is a standard part you can order from speedway or summit. For the plate I'd recommend a higher grade steel than mild. My local steel supplier has a plate they call formaloy 4040 or something very similar that is a lot stronger than mild steel but will still bend rather than brake. For any 0.25 inch brackets I like to use it. One option for these is to make the hockey stick out of an old TC rod. You will need to grind for clearance to make it work with a 5/8 clevis. Your next step up is 3/4 and a thicker hockey stick and it may not bend. But that means something else might. Cary
  12. Another option is you can have bearings REM finished and cryo treated. Some places will do it for Timken bearings but many times you need to take them apart. I never knew you could do that until a friend took some apart, cleaned them, changed to a lower drag seal, and put in better grease. Ceramic would be the best option but are very expensive. Cary
  13. For the springs I'd run the rear either the same or perhaps 50 pounds lower in rate than the front. The higher rate will help keeping the chassis from moving so much and if the suspension is compressing from downforce it will about half of what you're seeing now. I'd agree on as much caster as you can do, which will also increase the wheelbase and help with stability. In looking at the picture of your car from the side it looks like you need to lower the rear. That would reduce the angle of the windshield and might get you a few more tenths. Any reason no rear spoiler? That should help reduce drag and make the car more stable at the speeds you're running. A friend has an EP car and it routinely hits 158 on the straight at PIR and when braking the car is moving a lot from the in car footage. He said when he ran the GT-2 Z it was much better in this regard. One difference was the rear spoiler. Hope this helps, Cary
  14. You also need a lot more spring (450 to 550). A friend ran a splitter a little larger than that and grounded it from 4 inches doing 160 on the straight at Thunderhill. This would allow you to lower to keep more air from going under. Cary
  15. Another thing to look at is the liner when you start getting weird results. If you bend the torch a lot it wears quicker. Drive rolls lasted much longer than liners when I had my hobart handler. When you're welding it should make a sizzle noise almost like bacon cooking. If you don't have that you're moving too fast, wire speed too high, or not voltage is wrong. That was my key indicator when using the handler was to adjust the voltage to get that noise and it worked much better.
  16. It sounds reasonable. If you weighed your parts then you could do some frequency calculations and know where you start for sure. I'd probably start where you propose knowing it's a little soft but should give some scope for tuning. While I wouldn't use them while driving on the street the use of droop limiters will help to control roll and pitch. When setting up A S30 chassis roll is something you try very hard to avoid. The limiters let you run softer rates for the amount of body roll that you'd normally see. Cary
  17. Yes, just need to remove this extra degree of freedom. Braking level was 1 G or so. Wheel hopped so bad it broke the rod end. If you have the strut off and just the steering arm on and you move through rotation and it suddenly flops from front to back that's a sure sign you'll have an issue. At lower load never a problem. The other issue I see in this is that you're going to see higher tie-rod loads. So on a car where those are older or marginal you might have a problem. It's an easy fix if you do run into the problem. Simple sub in a solid rod and and declare victory. Cary
  18. Years ago we did something like that and found using the double rod ends didn't work. Under hard braking the wheels hopped. If you replaced the rod end on the control arm it was fine. I don't see how these would solve that problem unless I'm missing something fundamental. Cary
  19. On your pic I had a similar failure but for a very different reason. I had the front sprocket break a chunk of cam and slip and that broke a rocker similar to what you have along with bending some valves. What I wonder is it possible something got into the cylinder and caused enough of a jolt to break the rocker? Have you been able to look into the cylinder at all? It sucks when stuff like this happens but when you've done it for long enough it happens to us all. Not that we enjoy it any more than you are. Worry, hope the the luck improves! Cary
  20. I second the raybestos pads. Those are the only thing that live on a friends EP car. Supercooled rotors do live longer but are not always to come by. Cary
  21. If this is a race car then one option is to remove the stock hinges and place a plate with holes where they go. Then on the hatch you make a 1/4 to 3/8 pin that goes into these. Very easy to pull off but holds the car. Normal hood pins or aerocatch can be used on the rear end. Cary
  22. Really sorry to hear/see this. You were well on your way to getting a really competitive car. Cary
  23. It looks like if you modified the stock 240SX cradle this would be easier to do. I'm guessing there's an opportunity for an enterprising individual. Cary
  24. The QA-1 struts are in their new catalog you can download. It doesn't show any info about parts that fit. I'm guessing it uses the same parts as the other 46 mm double-adjustable shocks. They look like a decent option assuming there are valving options available.
