tube80z
Super Moderators
    30
Everything posted by tube80z
  1. Don't forget even though the rate is low there is significant preload on the stock springs. Cary
  2. I wonder if putting an X in the core support would work. I've seen that on a few rally cars. I also wonder if a car setup this way is doing this because the front and rear roll angles are vastly different, causing the chassis to take more of the load. Cary
  3. Cool dude. So we'll we see it out this year? Cary
  4. For a street mod car I'm not sure you can do much with the rack. I guess you could eliminate the bushings and move the rack and possibly pour in some new ones but I'm not sure how much, if anything that would gain. I had thought SM allowed liberal creativity on the outside, as in tubular control arms, custom fabricated strut housings, etc. I would think you could take some advantage with the steering arms and if you used a two piece strut you should be able to set the pin lead on the strut. This would let you experiment with much larger caster angles. I don't know if this will work with low profile street radials or not. Cary
  5. Coleman lists them in their catalog. I believe they are set for the some of the basic chasis that might be bought. So some custom fab would beed to be done for a datsun version. Cary
  6. The mount you have above is basically what I've done to my nissan rack. I welded a mount to the rack tube and use that to attach. Very similar in the end. I only chose this route because I had the rack and I'm cheap. For your ackerman adjustment why not build it maxed and then put spacers under it as needed. You'll have to watch the clearance to the oil pan but this should work fine. If you try and lower the car a lot you may have interference issues if you raise the crossmember/inner pickups too much. I still like the idea of doing something like this and have spacers that would allow one to move the crossmember to adjust the roll center. You'd need adjustment like Jon has on for the TC rods but it seems like it would work. For racks you might also take a look at a number of the sand rail companies. They have some low cost options that might work as well. Cary
  7. The basics are that you want it adjusted so that the bar is straight across when load is applied. When they are not loaded you may see the bar skewed at an angle. Ideally the monoball should be very close to the center for optimum use and safety in the event of a failure of one of the circuits. A properly built system will not let the monoball shift as the car experiences side loads. This is a good think to check as you'd have different brake balance corner to corner if this happens. Cary
  8. For drag I think a simple coast down test would be sufficient. SAE has some info about these tests. Your idea for measuing lift and the distribution should work fine. It's commonly used to create aeromaps for cars. You will need to keep accurate records of the atmospheric conditions, properly setup the car, and make specific changes for this to work. You will need a datalogger but you don't necessarily need linear pots. I've had some success using plain old rotary pots and some linkage from RC cars. Good penny-giles pots will set you back about $250 a piece. If you have access to a motec system it will surely work. But you can do this with just about any data system and some low cost sensors if you use a little ingenuity. Cary
  9. As it was explained to me ackerman is a function of the tire construction. In the case of the FA tires you are using they like ackerman. The swift uses 100% ackerman and I know a few teams have added more when they run on teh slower street courses. So I'd put on as much as you can get. I intended to build a new set of steering arms but never made it that far. I bent the stockers out a little and moved the rack closer to the crossmember. I don't have any detailed notes anymore but I seem to recall getting near 70% ackerman with this setup. I thought it worked better. I don't think you'll be able to get a lot more than than this simply because of the packaging. The only way I think you could get it to work would be to convert to rear steer. I've made a few tie rod using swedged steel tubing (for 5/8) on the outer end for the rod end. On the inside I cut a slot in the swedged piece using my mill and then cut off the threaded section of the stock tie rod and welded this in. I saw this done at a hotrod shop I hang out at. The only trick was to preheat all the parts and then let cool in sand. Cary
  10. Your guess would be as good as mine. I think the issue is that with no balance bar you'd need to have the same travel of both brak rods for this setup to have a chance of working. I seriously doubt that will ever happen. Best bet, as mentioned above, put a balance bar between the masters. Cary
  11. I think if you run a longer bolt and a spacer in the middle you'll make it a lot stiffer when you have the rod end on the outside or inside. Cary
  12. I used turnbuckles and cables from the hardware store. The only reason I did this was thinking about it while I was working out on my blowflex, which has a lot of cables and associated hardware. The turnbuckles allowed me to accurately set droop/preload on the springs. I think both Jegs and Summit sell a kit for drag cars that would work. I attached the top to the strut tower wtih a metal strap that had holes and bolt that was welded to it. This was then had the turnbuckle attached to it. The bottome had another bolt that had a clevis end welded to it and then cable down to a bracket on the TC rod. Other options would be a mechanical stop against the bottom of the swaybar. I thought about this for some time and chose the cables because I wasn't sure any of this would work when I first did it. Now that I know it works I could see investing more time in a better solution. Cary
  13. Can you turn one of the rod ends 90 degrees. Maybe the top one on the end of a slider adjustment? I personally think you have way too much droop. Look at late model bimmers and porsches. They have a lot less. Cary
  14. What happens if you put the channel on top of the TC mount? Does that gain you anything? And for droop, how much do you have? If you're springs come unseated you can limit to that with no real change in how the car works. Cary
  15. For what it's worth the swift manual I have recommends 28 PSI when running these tires on an oval using max downforce (3450 lbs) on a ten inch rim. Cary
  16. I think a lot of it depends on tire construction. The FA tires I use on my car seem to work best for me at 18 PSI HOT. I generally start in the 16.5 to 17 range with them cold. I've never had a tire come off the bead but a few of the hoosiers had issues with not holding air. Well after that fact I heard they may have had a construction problem. A lot of this depends on how much your car weighs, etc. If you want to get real tricky you can play a couple of games with your tires. You can paint them with latex and put them on paper to look at how the contact patch changes with pressure, camber, etc. This is best done by using a modified press. Or if you need to see an actual pressure distribution you can use Fuji prescale pressure sensitive paper. Cary
  17. IR guns aren't very useful for tires. The surface temps drop too quickly and they have a tendency to even out before you see the real trends. They are very useful in taking track temp measurements. You really need a good probe pyrometer. Just remember for autox you'll never see the core temps that road racers speak about. If a hoosier R25A slick will show you core temps in the 100 to 125 range when it is working good. When you get over that you'll find they are getting greasy. When taking tire temps remember to take 5 tire readings. What I mean by this is start with one tire (always the same one and usually a front), work your way around the car, and then take the temp of the tire you started with. This will let you see how much temps are dropping as you go. You can use this to guage if a tire that you took the temp of later is actually hotter. In general, once I have established that I don't have an outside edge hotter than the middle or inner I will usually only look at the middle and inner for what needs to change. Remember toe-out heats the inside and toe-in heats the outside. This can mask how the tire is used. For autox pressure rise is a better indicator of how the tires are being used, IMHO. Work to get the front and rears to come up the same amount. You'll also have a target hot pressure that you'll find that works best. You'll need to adjust the starting temp based on ambient temp. Always use the driest air you can in tires. Any water that is condensed and turns to vapor will cause an abnormal amount of pressure rise. Adjust pressure in 20% increments to figure out what works best. That will quickly let you see what you need to do. Cary
  18. It would appear I lost most of my pics when I lost a hard drive last year. I do have some from when I started my experiments that would give you an idea of what I did. The u-shaped piece seen in the photo below had a top, which is in the second photo. Unfortunately I don't have anything close up or of the holes I put in the engine compartment. All I did there was put 3 inch holes in the inner fender in front of the strut (3 on each side) and flanged teh edges. Cary
  19. I just got a new book from Simon Mcbeath called competition car aerodynamics. You may want to get a copy before going too far. They did a number of CFD studies on a generic shape that's close to a Z on the front. It shows airdam, airdam with belly pan, splitter, and splitter with diffuser. They all work a little differently and change the flow around/under the car. Simon writes the aerobytes column in racecar engineering. This book is basically those columns expanded. I'm pretty sure all the Z's had a splash pan. I put holes in my inner fenders to help vent the engine compartment when I ran a belly pan. I then used gurneys on the front of the fenders to help create more of an extraction, which helped to lower the engine temp. I also created a simple diffuser in front of the radiator. That's another thing you can try to make things more efficient and make the entire openning smaller in the front. Cary
  20. I'm not really sure what you're talking about on F1 cars. They all use torsion bars these days and you can't change the rate of those unless you change the bars. That said most can be pulled out in about 15 to 20 seconds and a new one installed. I'd be curious to see the pic if you can find it. Cary
  21. A few years back there was system that Eibach was using on a F3 car that allowed for adjustment by stacking to coils and usiing a special cylinder that put preload on one of the coils. Because the springs were stacked this is how the rate could be varied and it allowed it to be varied over a range if needed through having one of the coils stack solid. It's an intersting idea but I think it has some problems. From the drawing it looks like it is designed to screw up and down a spring. This will limit it to a certain rate as most springs have different pitches and diameter if wire. My second concern would be that this may cause the spring to put more side load on the shock since it isn't using the regular closed end. If you want to see what a coilspring does head over to hyperco and look at the video of their hydraulic spring seat in action. I think you may find it interesting to see how much the spring roates (it's basically a torsion bar). Cary
  22. Looks good to me. Just think even with a little boo boo it's much better than most of the bars people have on their cars. You saw how easy it is for a lot of this stuff to bind and you've taken the time to fix that. Cary
