67
Every single off the shelf airdam will leave the front of the tire exposed with ZGs, and they won't line up right where the fender meets the valance meets the flare. You're going to have to DIY it if you want that section to be perfect. You can start with an off the shelf fiberglass one, or take any of them and Jerry rig something if you don't want to make a whole airdam. It's a good idea aerodynamically to cover the front of the tire. Seen many people add a strip of aluminum to the back of the airdam to do this and bridge the gap to the flare at the same time. This is also a bit clunky looking but it is more functional. Dug around in my pics for a few minutes but couldn't find an example. I believe username Heavy85 (first name Cameron, can't remember his last name though) had something like this on his hillclimb 280Z if you want to dig some more. He crashed it maybe 10-12 years ago so there won't be current pics.
JMortensen replied to FastFloridian's topic in S30 Series - 240z, 260z, 280z
Agreed, for the weight I think I could have done something more effective. -
I took the OEM ones off and welded the Bad Dogs on. I suppose it depends on the condition of yours, but mine were pretty bent up and there was rust inside the frame rail. -
'77 280Z Track Car Father & Son Project
JMortensen replied to RCVTR's topic in S30 Series - 240z, 260z, 280z
Looks good! My favorite rotisserie moment was sitting on the edge of the windshield hole, fixing rust in the cowl. Just bizarre. -
Looks like something I would do.
Spindle Pin Set Screw - Needed or not?
JMortensen replied to calZ's topic in Brakes, Wheels, Suspension and Chassis
The stock rubber bushings will impart a pretty significant twisting force on the pin. Rod ends or a similarly smooth pivoting mechanism don't need to worry about torque on the spindle pin (or bolt), so no need for a hold down. It's a 5/8" bolt, so torque it to 100 ft/lbs or similar and it's not going anywhere. If you're really worried could put witness marks on the pin and housing to make sure it doesn't rotate, but it ain't gonna rotate. -
Sounds like a good time, and with all of the suspension figured out might not be that much of a time suck getting it up and running. Some of us took a decade or more to get our shit together. For a Ford powered car, look up username 74_5.0L_Z Dan is a good guy, runs a 347 stroker IIRC.
Looks like I'm late to the party. From Richard Holdener's videos I learned that any cam is a turbo cam. Since the stock Z cams are PUNY, I'd suggest you go with a healthy cam and get some benefit from it. I ran a .490/280 with SUs and Mikunis, that worked great and didn't lose low end power. I'd suggest something around there, and skip all this A and C cam stuff. ALL of the stock cams are way too small. Go bigger. Ditch stock springs and retainers, get lash pads and shorter stem seals. You won't be sorry.
IMSA GTU vintage racer build
JMortensen replied to clarkspeed's topic in S30 Series - 240z, 260z, 280z
I don't remember the source, but I was pretty convinced by it that the goal is to get the front wheels equal. More important than getting cross weights perfect. -
What struts to use in 2024?
JMortensen replied to 74_5.0L_Z's topic in Brakes, Wheels, Suspension and Chassis
What Dan is describing is a known issue with Zs that are raced. The forces on the stub axle stretch out the bearing pocket in the strut housing. Had a guy on FB DM me about the same thing just a couple days ago. Now that has me thinking about putting a reinforcement ring around where the bearing is located. I bet that would be pretty easy to do, too... -
One avenue I thought seemed promising but haven't pursued is to use the adapters that people sell to screw in a cheap Chinese coilover (AZC, T3, Apex) and find a really high quality strut that fits, like a Penske or Ohlins or something. I think this is essentially the route the Coffey went to get those 46mm Bilsteins in that rally car that went across Asia, but John had the adapters machined because he was way ahead of the curve on that idea, IIRC. FWIW, that guy ended up swapping those Bilsteins out for something he thought was better. Bilsteins are supposed to be pretty tunable, but you have to have someone who can do it, which is a whole nuther can of worms... I think the easy button is to fork out big bucks for the KW or similar high quality stuff. -
ZX rack is mounted behind the crossmember.
cant figure out steering clunk/pop
JMortensen replied to kaibiagi's topic in Brakes, Wheels, Suspension and Chassis
Yeah, that needs replacing for sure. Think you probably found it! If you don't mind the vibrations, get a poly or plastic one. People have also drilled hockey pucks and used them, if you happen to have one. -
I just remembered a clunk I had, and turned out it was the big bolts that go through the steer knuckles and into the strut. Might check those and make sure they're tight while you're under there. -
You can just remove one sway bar end link and then it will flop along and not be doing anything and shouldn't make any noise outside of maybe bushings squeaking. Easier than removing the whole thing. If it stops and you think it's around the bar/frame mount, pull it all the way off and inspect the frame rails where it bolts on. Aftermarket bars tended to rip up the frame rails when these things were new and not rusty. How about the rag joint in the steering column? OG rubber, or did you upgrade that one too? Sorry, can't help with wiring part. -
240z SCCA vintage race car, restoration
JMortensen replied to AydinZ71's topic in S30 Series - 240z, 260z, 280z
I ran Buttonwillow and Streets of Willow but never Big Willow. I signed up but something came up and didn't go. Buttonwillow speeds are lower, there isn't shit out there to figure out braking markers so you end up looking for cracks in the pavement and stuff like that. Track is very hard on brakes especially if you run the hairpin, good place to stress test your build. Used to be pretty bumpy in the braking zones 20 years ago. I can't remember if you play Assetto Corsa or not, but you can download Buttonwillow and it comes with a bunch of configurations. Well worth the $6 or $7. https://www.simtraxx.net/shop/product/buttonwillow-raceway-usa-aerial-laserscanned-ac-ultimate-edition/ -
Yeah, lowered otherwise stock Z will have something like -3 in back and -.5 in front. Terrible. -
I'm in this same boat. I widened the LCAs an inch to prevent CV bottoming and the rear ended up at something like -3.5 with the camber plates flipped and maxxed out positive. I had the same idea about removing the tubes from the uprights. I actually have Mustang 36mm Bilsteins I am going to run. They are the same length as my sectioned front struts that I run now, so I'll need to run a spacer in the back. My thought was to make a mount and bolt the uprights to it to measure the strut angle, then bend the strut tube in say 4 degrees. The camber plate should handle about 2 degrees of adjustment (guesstimate) and so if I could get somewhere in the 0 to -2 or -1 to -3 range I think it would work. My other thoughts were to cut the top of the tower out, plate it and recut the hole for the camber plate (sounds like a lot of hassle), or to make a 1" thick offset plate to mount between the bottom and top of the camber plate and move everything outboard, but seems like that might be a lot of extra stress on the camber plate and strut tower. -
Should I fuel inject my 3L stroker?
JMortensen replied to zev's topic in S30 Series - 240z, 260z, 280z
I was under the impression that since you don't need airflow to atomize the fuel, you should go bigger on ITBs. -
They had a problem where their fabbed upright was flexing. Wasn't the arm. Maybe this one didn't get the update, or maybe the update wasn't good enough. I have similar arms (Apex modeled theirs on mine) and I don't have issues. Regardless, that doesn't look good at all.
Make sure that the suspension moves freely through the full range. Can remove springs and compress the strut with ratchet straps and make sure you don't feel any solid resistance.
The factory mounts are pretty tall. I think you're going to have to remove them with any seat you choose at that height. If you want to race might need to go 1x1 square frame and screw directly into the tubes. BTW, removing the mounts is a PITA too. 487 spot welds holding those bastards in.
I think tube80z shared that with me a few years ago. Made me regret that I had installed my fuel cell at a 7* angle because when I did it 7* was considered the max angle you could run without separation. He's talking 20* in there though. That's way outside of what I would have thought would work. I think when I do build one the focus will be on making it as long as possible and I may try to change the angle along the length. Been looking at AJ's gigantic one, and it appears that maximizing the angle in that particular space is the focus, rather than sticking to a particular angle. You can see it kinda steps up past the axle, then flattens out a bit under the gas tank, then steps up again at the end. https://ajhartmanaero.com/modular-diffusor/
