clarkspeed
    36
Everything posted by clarkspeed
  1. Awesome update. I traded off my "street/track" Z for a race prep Z many years ago, got my license, and never looked back. Most fun you can have with your pants on and very addictive. No real allegiance to the Z car, just happen to have a lot of parts lying around and know how to work on them blindfolded. We had a little Toyota sports racer around for awhile and that was a blast too. I can attest it is much much much easier and cheaper to purchase a race car than to build one.
  2. Lots of info on this forum on the doggone support. On other cars I have tied it into a bushing on the mustache bar studs. I WAS planning to run my R200 diff raised slightly to get level halfshafts after lowering and keep the u-joints. Another cheap, light, reliable, and effective solution. But now I am considering the Ford 8.8. I saw Tube80 post this control arm years ago and could not resist copying. Such a simple solution, but just a little heavier that stock. Something lighter than that formed steel stock arm that includes adjustment would be an accomplishment.
  3. Here is my rear control arm design I lifted from this forum. Using the original arms saves much weight. You can also see where I raised the cross beam clearance and added support to the dog bone uprights.
  4. I have been using these Mazda throttle body flanges for brake cooling ducts. I found them on amazon super cheap. They are cast aluminum and I just drill them to fit the holes for the OEM backing plates.
  5. Wow I missed out on posts for the last couple days. Some interesting techniques I need to try out. I tend to use very thin sheet to fill body panels, sometimes even thinner than the Datsun panels. No gap, low heat, and typically a "pearl necklace" finish like you mentioned. Although I would never use that phrase. I always check the back side for overall good pen, but not every mm, grind to finish, and then thin bondo along with a backside coating. I rarely hammer the welds or shrink metal, just smallest negative profile I can attain (less than 1/8"). Small pinholes everywhere. But keep in mind, I build race cars, not show cars, so I'm not to concerned about getting an all metal flat finish like the guys do on TV. As long as I can duplicate the contour, no one will ever check it with a magnet. Race cars always stay indoors, and tend to be repainted often. I've never had a bondo crack or rust break through, without direct contact of course ,
  6. And here is the driver's door. Car came with the door fully cut out and it was floppy. I have seen these wrinkle up on other race cars and God forbid if someone accidentally leans on it. Anyway the cage sits very close to the skin, so I got creative with a some bent sheet metal and 3/16 rod. It is as rigid as a complete door now. The upper hinge was milled out, but I ended up blasting out the lower hinge with my $400 plasma cutter. I added a 3D printed inside door handle. I can sell these if anyone is interested.
  7. Maybe this gives a little sample of just how rusty this tub was. These are some of my repairs along with patches over previous repairs. Please don't comment on some of the poor welding. Many of the welds were not clean on the backside and these are not structural. If you notice, I cut out the entire storage box area. I have the weight savings written down somewhere if I can find it.
  8. I measured my Sweet steering shaft. It looks like 28 collapsed and 34 extended. And that includes the steering wheel QD spline on the end. Like I mentioned, it is just a little on the long side . I would say 25 to 26 collapsed would be optimum. I also use a flat steering wheel. If you use a dished or deep dish steering wheel, take that into account.
  9. Great job on developing this! I am considering for a road race build. But have a couple questions. Strength is not a concern for me since I can make it fine with an R180 and u-joint axles. But I like this option due to cheap parts availability and virtually unlimited ratios. Weight is a concern. A R180 is a little over 60lbs and an R200 is just over 70 dry. Best I can tell the Ford 8.8 is 65 in aluminum and 85 in iron. Does that sound right? If so that is a pretty simple trade off. Do you know how much your cradle and uprights weigh? The cradle is a weight adder, but it looks like the uprights could be a reduction. Thanks for your attention.
  10. Not sure on the length, I can measure it next time I am at the shop. It is a little on the long side because I need to collapse it quite a bit when installed so it only leaves a couple inches of "crush" zone. I will also try to get an estimate of the weight. It is a solid steel rod. Greg's EP car is refined to a point. He spent probably 20 years developing it. He doesn't make any more major changes to it and uses a similar formula to build other cars for himself and customers. However it is surprising how much OEM stuff he uses and simple common off the shelf parts.
  11. The car is mostly cage, it has very little rigidity left in the tub. Between the rust and everything I have already cut out, I am more worried about panels wrinkling up than providing any structure. That is one of the reasons I have not cut it out yet. The front pillars are already tied to the cage, and it is connected to the rear main hoop above the side window. Vibration is not normally an issue on a car car. You tend to rev right through it.
  12. I am pushing the CG down as low as I can go. Exhaust exits side so no problem there. Flat bottom floor all the way. I think it will work ok. I have been staring at that damn cross member for months. Started to cut it out couple weeks ago and declined. Do you think it weighs enough to make a difference? Looking closely at it, it didnt look like that much metal. I am also staring at the drip rails.
  13. Next up is the floor and interior structure. I never noticed before until I started building this thing that the floor bottom on a 240Z is actually lower than the rocker panels. This car only came with rocker panels, nothing more. When I got ready to try and locate driver stuff I quickly realized that I couldn't just run a flat panel across the bottom. Turns out I needed to drop the floor roughly 1-1/2". Again all measured to the FSM datum points. So that meant building a frame around the tub. I used fairly thin square tubing since I already had plenty of structure above it. Again you can see the square tubing running fore and aft that represents where the bottom of the floor should be in relation to the chassis points.
  14. In the tube car I am running a used Sweet column I got off eBay. I'm not sure it is that much lighter than stock. But it is adjustable and mounted with sphericals. Do the fit checks with the actual seat you will use. Usually end up as far back and as far to the center as possible. Then it's a matter of getting the rake to your liking. You can drop the steering wheel down but taller drivers will then bitch. But be careful of blocking yourself from getting in and out of car. One thing I did after moving the seat to the right was add some spacers under the flange at the bulkhead and slot the u-bolt more to kick the steering wheel toward the right. That always felt better to me than not having it centered.
  15. Thanks for the offer. Yes I plan on getting a small lathe maybe later this year. I am forever needing a special bushing or spacer. I just got my home built CNC mill running and it seems to cut 6061 aluminum very well. This thing is so cool and opens up another world for me. I will cut these top hats as one of my first projects on it. Check out The MPCNC website from V1 Engineering.
  16. I sketched it up last night. This hat will ride in the radius "cup" shown previous so it becomes a hat on a hat. My hat has a generous hole to clearance the rod and I can cut down the outer diameter of the upper GC hat if I choose to make it look better. Picture shown is upside down. Now I just need to figure out how to cut it on my homemade mill.
  17. And on to steering. All of my OEM rack and pinions on the shelf had a dead spot and I thought this would be a good area to upgrade. I chose a Coleman Racing square rack in a ratio just slightly quicker than stock. But to use a circle track rack, I would need to widen the tie rod mounts to get the correct length, which should be equal to the control arm mounts. I search around the internet and found an adapter bracket design that I decided to copy. I designed a welded assembly made from waterjet cut mild steel that had the correct length and the slotted adjustment. Most rack manufacturers will tell you not to do this, but they like to make custom length racks also. I like the design because it will make eliminating bump steer very easy. As you can see, I had to do some surgery on the cross member to get access to the rack spline.
  18. Well the fact that you are serious and seem to be a decent fabricator, most others will be generous with help. The dual MC's are only require slightly more pedal effort. And they are much easier to modulate. Clark
  19. Jon, I took another look at my camber plates tonight. I seem to remember previous versions of my GC camber plates did incorporate some sort of spring adjustment. Anyway, after reviewing the plates and the Mustang plates, I will add a "floating" spring perch to fit with the GC plates to compensate for spring alignment.
  20. If you can get a solid pedal box, I can show you how to convert it to a bias bar adjustable dual MC setup using the stock pedal. A fabricators "special". Tilton (or other) is also a good option if you dont mind fabbing a way to mount it. Greg is THE source for EP builds. Many of my earlier quotes are based on my experiences crewing for him. EP is a very specific class and very difficult to run at national level.
  21. The Winters style IRS is really trick, but not an inexpensive option. It is something I have considered. Too bad there are not a ton of used ones floating around like the 4 speed Jericho's. Mine has a super close ratio so first gear is useable and tops out at like 70mph. Should be a lot of fun driving around the pits! The cool thing about Daytona is all of the turns are around 50-55 mph min speed so if you have the right final drive, it works. I want to run the 24hr vintage race there to get that off my bucket list. You really have your pick of slicks with the 18's. Everyone makes those and wheels are fairly plentiful also. Do you know what your tire/wheel combination weighs?
  22. [Holly Shiiittte. I have dreamed of this many times and realize your difficulties. On gear ratio, I am facing a similar problem. I have a Jerico 4 speed in the car I am building which is always 1:1 in 4th for those in the know. I am looking at multiple tire diameters but limited to 16 or smaller on rim. Smaller the better for weight. But Daytona is one of the tracks I must build for, and that is max speed whatever your car will do. So unless I can move to a 3.3 or lower gear or I will need to increase tire diameter. So I am thinking about a 26-27 tall 15" tire (think Nascar) or swapping a Ford IRS rear. Of course money is always an influencer. I have 3.5 and 3.9 R200's loaded with Quafe's ready to roll. So gear ratio becomes an issue for just 1 track. I am trying to find a way to run from 50 mph to 160 mph with the same tranny. That is really an accomplishment running 18" in competition. Looks like you adapted to the dog box very well in the video. I can accommodate most any tire size with my current suspension like you I may have some physical interference I need to watch for. I am most impressed with you recent changes. As I mentioned in a previous post, I am lucky to know some REALLY fast Z cars intamately. And your build is definitely pushing the envelope.
  23. Yes, already done, but never too late to rework. 😀 That is one of the reasons I started this thread, to get input on things done, and help with some future decisions. I ended up reworking the strut tops twice. I will show in a later thread. Instead of Z car camber plates, I ended up with a set of GC universal camber plates in front. They do have caster slotting similar to the Mustang plates you reference, but I chose not to use it for now. I can do some more slotting if needed. As far as spring support, that has not been designed yet. I only have the basic camber plates, so I will need to use a top hat and thrust washer of my own design.
  24. I am not sure I am following all your issues, but yes it is common to add a spacer under the strut cartridge to get the proper fit at the gland nut. I usually cut down some 3/4 pipe. And the tubes should be longer in the rear, hince a longer spacer used there. I thought the GC stuff was set up for 10" springs, but I have not used their coil over kit in awhile. Either way, the ultimate goal is to have the strut rod sitting at mid distance when static loaded. So if the Koni's have 5.5" travel, the rod is compressed 2.75" with static loading and you have max travel available in both directions. The GC directions are an approximation to get you close (hopefully enough). There are some good write ups in this forum from John C.
