I've got my engine repaired, and I am now setting it up for a MegaSquirt 3 install to control fuel and spark. I will use this post as my "build thread", and will update with questions and pictures as I progress. But for now I just want to make sure I am getting the right stuff as I need to control costs as much as possible.
The engine: L28ET with cam, new damper, turbo distributor, 7MGTE injectors (low Z), stock ignition. Plan to run batch fuel injection and distributed spark (for now). I am also planning on speed density control using Zmanco's baseline tune ported from MS 2, I think the fuel and ignition maps will copy in, we'll see.
I will be using GM air and coolant temperature sensors. I have adapted and installed a Hyundai TPS on my Weber 60mm throttle body. My boost controller will not change, it's a Greddy ProfecB that works with the stock wastegate. I also plan to get a wideband O2 controller, probably the LC-1.
Initial questions:
I am looking to get just this MS 3 kit from DIY. I am good with electrical assembly and soldering.
http://www.diyautotune.com/catalog/megasquirtiii-wpcb-v30-unassembled-kit-with-black-case-p-419.html
Will it do what I need? I don't plan to go distributorless or sequential injection, but I do want it to control my electric radiator fan, fuel pump, and LC-1 wideband. I also do not plan to do anything with active startup and idle control other than factory equipment (it's a track car). I am having trouble finding out the details on exactly what the kit includes.
Is there any advantage to getting the trigger wheel for the turbo distributor? I do have a Z31 wheel in it right now.
I plan to build my own relay board where the old factory relays lived, in front of the battery, so I think I can run a single harness from the MS 3, and split it out in the engine compartment.
Any input is appreciated, please let me know what your experiences and mistakes have been.
