mark
    4
Everything posted by mark
  1. Another innovative part from modern motorsports. One of a kind and I'm sure the quality will be top notch as always. Nice work Ross.
  2. Hey Mike, Would you be interested in making me a set of those mounts? If so just let me know the cost. Thanks, Mark
  3. Great looking wheels. Awesome brakes, what set up is that? Is that Arizona Z control arms on the rear? Where did you get those CNC control arm mounts and would it be possible to make a few more? Thanks, Mark
  4. should be the new Z. Looks great
  5. For a street car I have always heard that the iron drums are better. They last longer and dont' flex like the aluminum ones will under hard braking. No personal experience here just passing along what I have heard over the years. Mark
  6. I'm using the R-230, from a Q 45, yes for sure it is an r-230. I have had it apart and compared it to the R-200 that came out of the car and the ring and pinion dwarf the r-200 ring and pinion.
  7. Input flange is different, mounting points are different, custom half shafts, custom front diff mount, modified mustache bar. That's it.
  8. He would not let me by on the straight, thought he was going to walk off from me. He let me by next time and I left him in the twistys.
  9. It does not matter where on the shock piston the bump stop is. It will keep the strut from bottoming out as long as it is inbetween the top isolater and the strut housing. Mark
  10. Engine and tranny 5k, wheels and tires 3k, being able to stay on the bumper of a Viper on the back straight of VIR, Priceless. Mark
  11. Ask around aboput that one. Several guys here have tried it and not had good things to say about the fit. Try here great parts great service. http://www.datsunzparts.com/
  12. Try this guy, Charlie. I don't think he make the parts but if they are out there he will know. Great guy to deal with, highly recommend him. http://www.datsunzparts.com/start.htm
  13. courtsey nissan. They were high, don't remember how much but I was sure I was getting the right part and great quality. Mark
  14. Sounds like what I want to run on my car so I would love to see a pic when you get the soft ware back together. Tried JB weld?
  15. Mike, Thanks for the confirmation. I decided to use John's mounts and hack up the drivers side mount. Should work out OK. Not having to remove as much material as I thought and I'll replace the removed parts with different shaped steel to restore structure and allow the steering colum to fit. Mark
  16. Sure this will work. I have several running around my town now. I liked the part about getting you pistons and cylinders ceramic coated ASAP. Sure no problem. One born every day or was it hour or minute. Seems like one per second around my neck of the woods. Mark
  17. I have the engine in the car and test fit the alternator. Alt. has a black plastic cover on the back that interfers with the datsun engine mount tower. Any one else had this problem? Anyone know the answer? I can trim the cover but have not seen this mentioned before and I searched. Thanks, Mark
  18. Dale, I taked to speartech last week. You covered more than I thought to ask. I would call them and read you letter and see if they can offer any input. I'll be sending my harness to them soon. They were very helpful on the phone for what it's worth. Mark
  19. After 30 years or so these cars just aren't square any more. If you have adjustable suspension on the car I would bet you will be fine. Did the car drive OK before? Had you had the car aligned before, was it OK?
  20. John, Sorry to hear that. I was hoping to follow your lead on this. Keep me posted. Mark
  21. John, I would appreciate any info you can get me. Thanks
  22. I've got the 210 and it is a breeze to use. 210 does not have digital controls. I've used the spool gun for aluminum with argon gas. Not as nice as tig but I can grind it smooth and it looks OK. Smooth wire feed on both the spool gun and wire feed unit. It never gets hot and shuts down. Best of all it makes me look like I can weld. Mark
  23. I bought a hat and some T's. Both good quality and I would be in for a few more t's. Mark
