BluDestiny
    10
  1. Good, just got the Gnose on it, And now I'm in the process of making a better channel for the "mouth" to the radiator, and also a front pan to keep air from getting up and causing turbulence. edit: I'm a bit more pumped about my 260z though since I just put the carbs back on from being "rebuilt" by Top End performance (at the cost of an arm and a leg)
  2. You freaking scored. You could part that out for double what you paid for it easy. Why does the head have injector bungs?
  3. Courtesy of speedhunters: http://speedhunters.com/archive/2008/09/02/car-builder-gt-gt-rauh-welt.aspx
  4. I think that's the plate in between the engine/tranny or something. Also double check the started is lined up. Might want to take it off and check the teeth on the flywheel. I'm assuming the timing was not changed at all when you swapped the motor.
  5. Sho-Z, is this engine in Arizona or Alaska?
  6. Are you really considering putting on $16 springs onto what holds up your car?
  7. You will feel more kick based on the cam from the E88 than what you are driving now.
  8. It's only going to $6000. That's wierd
  9. I trashed my 280zx turbo parts car in the same condition as your's and got $160. It was back in November though.
  10. http://www.zcar.com/70-83_tech_discussion_forum/how_much_do_280z_bumpers_weigh_688245.0.html
  11. Go with megasquirt, get used to it, learn how to tune and diagnose it, Then down the road you will be able to swap any engine into your car with minimal effort to the wiring. I bought a complete unused megasquirt system for $400. It's still sitting on my shelf.
  12. I hear a lot of good things about this kit. And I met the guy at a meet. http://silverminemotors.com/Stage-4-Rear-Big-Brake-Kit-Stage-4-Rear-Big-Brake-Kit.htm
  13. Yes it will. Use a turbo flywheel as well. read the fifth section in this link http://datsunzgarage.com/engine/
  14. I'll sell you my old helmet. $220 shipped to you. I don't know what size your head is though. My helmet is practically new, only worn a few times when practicing on my roommates bike. http://losangeles.craigslist.org/sfv/pts/2375777939.html
  15. Happy Birthday. I actually have a L28et long block sitting in my garage in "storage" I took most of the other parts with me (Shaved N42 intake, Exhaust mani, used fuel rail and 550cc RC injectors with me to cali) Also have a holset H1C and "everything you will need"(from the guy I bought it from, but I verified it and if should be everything) to hook it all up. If you want the long block I can give it to you for $100. Plan was to drive out with it, but didn't have enough space. It does have a blown headgasket, but it only had 96k miles. PM me if you want to work something out. I'm not going to be using it anytime soon. And I can throw in the engine stand for $30 more.
  16. Looks like a pretty good deal, how's the interior? hopefully it shouldn't take much to get it running.
  17. I have a sparco Fighter seat and the shoulder boltering is 23.4" wide IIRC. It's about an inch or two too wide. I want a set of Sparco Tec seats since they have less shoulder bolstering.
  18. http://lmgtfy.com/?q=jet+coating Jet coating is basically a ceramic thermal coating that keeps heat from penetrating into the metal. It is on the outside and inside, which is the important part. Wrapping any set of headers will "trap" heat within the wrapping, which could lead to cracking if you buy some crappy made headers. I was quoted by a local muffler/welder shop that coating my 6-1 headers was $100. Since I got them with my car it would be cheaper than buying MSA's coated headers at $250. I didn't know that a pair of headers for a V8 is that cheap. In my opinion jet coating would be a more permanent solution, if you plan on keeping the car for a long time. You can polish the coating and make them look better and I don't like getting fiberglass all over me (wear protective gear if you wrap headers) because it itches like hell
  19. I don't think you should dead head your fuel line like that. Use this tool: http://www.thezstore.com/page/TZS/PROD/TE/60-9976
  20. Get them jetcoated. About $100 per header, depending on size.
  21. Why wouldn't you do both? You might run into issues with piston clearance if you use stock pistons, which is why people use different pistons (KA24) when stroking the L28. I wouldn't know with an RB though. I feel like you could sell that motor to a S13 fanboy and use that to getting a real RB25.
  22. Location, how much you think it goes for, what have you done to it, milage etc....
  23. http://www.hammondsplains.com/s30upgrades/maxifuse/index.htm
  24. Movie was very action packed. I enjoyed it, in a corny way. Best character is The Rocks (Dwayne Johnson for everyone who never watched WWF/WWE)
