NewZed
    71
Everything posted by NewZed
  1. That is the right ECU number for 1976. What is the number for your current AFM? It might not be mismatched for the ECU. For example, Nissan changed the part number for 1978 AFMs to show no fuel pump contact switch but but some of them still have the parts. 1978 has the same ECU number, but a different AFM number. What problem are you trying to solve?
  2. What is it that "goes away" when you shut the car off, after letting it run for a while? I saw your other post, which is more descriptive since you say that you have spark. If you have spark, and the engine turns over, and it ran just a few seconds earlier, then fuel would be the place to look. Do you have fuel pressure on the second try, and are the injectors firing?
  3. PCV system connected (crankcase to intake) or blocked off? Taking the oil fill cap off opens up the PCV system to atmosphere. No response when you remove the cap implies that it's already open.
  4. Page FE-4 in the FSM has a pretty good diagram.
  5. There's not that much stuff in the transmission tunnel. You could follow it out and see where the other end is.
  6. Most of the auto parts stores have loaner tools. Pay a deposit, use it, return it, get your money back. I've seen the brake line flaring kits at O'Reillys.
  7. Sounds just like dirty battery terminals. They get enough corrosion between the battery and the connector to either heat up and break the connection or not. Easy to clean and check.
  8. The answers to most of your questions are in these forums somewhere. The Search function is free. This site is popular and one of the originals for the V8 swap - http://www.jagsthatrun.com/
  9. The original poster's question doesn't match the title of his thread. He asked about everything, but only titled about control arms. 1975 is a 280Z. 1972 is a 240Z. There is quite a bit of difference for most of the components. Read #6 in this thread for a short summary - http://forums.hybridz.org/index.php/topic/101070-easy-r200-clsd-question-about-axles/page__pid__947746#entry947746
  10. What happens at 3,000 RPM that stops it from revving higher?
  11. You said you read so if you go down to #4 and look for LONGNOSE R200 on the first post, you should see the list of parts. From what I read though (same paragraph), the VLSD Longnose R200 only came in the 1988 SS model. http://forums.hybridz.org/index.php/topic/49194-differential-cv-lsd-hp-torque-r160-r180-r200-r230-diff-mount/
  12. It's there to keep voltage spikes out of your wring harness and away from electric components. Kind of like insurance for your ECU (or whatever they call it on the 79 ZX). The wire is actually the positive (hot) lead, the body of the capacitor is the ground. You can find them in the junk yard. A lot of Fords have them, easily accessible, if you can't find a ZX. Or an alternator condenser/capacitor from an auto parts store will work.
  13. NewZed
    Rear trans leak
    Nasty looking. My mistake on replaceablity of the tail section, if you consider half of the whole transmission housing as the "tail shaft". You'll probably need to buy a whole transmission to get the piece you need. Good drawings available in the FSM, with instructions.
  14. Did you look at the pictures in beerman's attachment? If you pushed the clutch fork forward, you might have pushed it off the pivot ball, you should have pushed it backwards and made sure it was seated on the pivot ball correctly. It should hang there. It's supposed to be held on to the ball with a retaining spring. Look at pictures #1 and #11. #11 shows the spring clip. If the retaining spring isn't holding the fork it might be dropping below the pivot ball and jamming. You might be able to lift it up while you install the slave cylinder to get it to work, if your spring is screwed up.
  15. I'm not positive, because I don't have one, but I think that the JTR swap manual covers all of your questions. I have read many comments suggesting it's well worth the money. I think that it is available here - http://www.jagsthatrun.com/OrderingBooks.html
  16. Apparently there is little benefit. I only proposed it as an alternative way to get an R200 with u-joint half-shafts in to a 240Z, without having any binding problems. I'm just trying to understand why the distance between the wheel-side companion flanges on a 240Z appears to be less than that between the companion flanges on a 280Z, since both body styles have the same track width.
  17. oakland240, I hope you don't mind me jumping in to your thread. I have read up on the R200 swap in to the 240Zs and am not 100% sure why the R200 with u-joint half-shafts fits fine in the 280Z but leads to binding in the 240Z. JMortensen, are the 240Z wheel-side stub axle and companion flange combination wider/thicker (from wheel mount surface to companion flange surface) on the 240Z? Is that where the lost width comes from? From what I can find the 240Z and 280Z have the same track width. If this is true, then one option to allow using an R200 in a 240Z would be to install the rear suspension and hubs from a 280z in to the 240Z to get the thinner stub axle/companion flange assembly, with more space from wheel-side companion flange to wheel-side companion flange. This should give all of the dimensions from a 280Z. Of course, springs, ride height and brake components would have to be considered to make everything work together.
  18. Looks interesting but my computer locked up on the third picture I tried to view. They are way too big. Here is a good thread to read - http://forums.hybridz.org/index.php/topic/98611-posting-pictures-please-read/
  19. The Body Electrical section of the FSM has some good small wiring diagrams, that show connectors with color codes. You should be able to at least isolate your short to a smaller area. Pretty sure that the connections all run next to the passenger seat, under the carpet. Have you tried removing the bulbs and turning the tail lights on to be sure you don't have a short a cross a bulb socket? Get things to where you can turn the combination switch on without blowing the fuse, then reconnect things until it blows.
  20. Related problem by tach behavior only - I recently put a Z31 coil on my 76 and found that the tach would just bounce around between 500 and 1000 RPM indicated, no matter what the engine RPM. I guessed that the circuit from coil negative was getting extra noise so I put a condenser/capacitor on the coil negative and the problem went away. I assume that the tach circuit never saw the zero part of the square wave (my understanding of how the later tachs work - could be off) so couldn't count right. Just one possibility, and an extra condenser/capacitor won't hurt anything. It might be a band-aid fix though, if the electrical noise is coming from an ignition module about to die.
  21. NewZed
    Rear trans leak
    You should post a picture. But it sounds like your transmission housing is broken. The tail piece is not replaceable, it's part of the housing. If the remaining pieces will hold the seal, you might be able to get by with sealant between the new seal and the chipped housing. That might be what the RTV you found was there for. Post a picture for audience enjoyment, and maybe some advice.
  22. He just ran a bigger wire to the positive post, see Post #14 - http://www.zcar.com/70-83_tech_discussion_forum/dyno_day..._advice_899360.msg2716588.html#msg2716588
  23. The switches don't have anything to do with the trans going in to gear. I know that the early 240Zs had to have the shifter opening enlarged, but don't know about the later years or the 260Z. Are you sure that the shift lever is not hitting the edge of the opening? I've only heard of three switches on the 5 speeds, so three on a 4 speed would be new knowledge, for me anyway.
  24. Is that clear filter rated for 36 psi? Someone on this forum just reported on a car fire but didn't really say how it happened. Looks like you have an L28 in a 240Z so you probably have the "on when the key's On" fuel pump wiring. Smokey Bear
