mario_82_ZXT
Everything posted by mario_82_ZXT
  1. Considering the prices of the chinese bar and plate intercoolers, why would you bother with this? Seriously, intercoolers that flow much better then this run for less then $150 shipped. Sorry I come off a little angry but I'm stuck with my NPR now... curse you cheap labor!!! lol... Mario
  2. Yep I believe the only different crossmember (well, different enough that it interference with things) is the Nissan BW T5 one. If you use a none T5 crossmember with the T5, it will put a lot of strain on the motor mounts and actually push them forward. Mario
  3. I got the impression that that's how it was. It seems you had to hold the + or - button to get it to open/close fully. It looks way too restrictive fully closed though. They said it passes 3 times in the outer casing before it exits, and that inlet and outlet holes look tiny! Mario
  4. Have fluids mixed? I think your headgasket went, hence the white smoke (coolant burning). Check for oily coolant or chocolaty oil. Mario
  5. I have a similar to the MSA setup in the front with relocated front suspension pivot points, allowing me to run -3 to -1.5deg camber. I like them for my budget. Mario
  6. How I wish someone had an HD version of it... Mario
  7. Few things sound sweeter then an inline 6 spinning over 8k RPMs. Even though you seem deadset on either one, I'd say the RB, and when you get tired of it's lack of torque, build an RB24. Mario
  8. Did you torque the head down as per the FSM? Mario
  9. Depends on the model. Some come with just the POT type TPS (only a pigtail), and others come with a connector on the TPS itself just like the original Z one and also a pigtail for the POT one. I heard you can adapt the original Z one as well, or that it's atleast easier to do then going from KA TPS to Z TB. Mario
  10. When my mom get's sick of her Miata I'm so making a monster Miata. There's a member here who make LSx powered Miatas. The "Monster Miatas" are Ford v8 powered I believe... Mario
  11. Sounds nice, but it looks like it's way recessed in there, are you putting a tip on it? Mario
  12. I was running a stainless bullet muffler right off the second bend in the downpipe and dumping right under the trans. The only things that I can think of other then fumes is noise, sure it sounds awesome, but I started getting sick of it, so now I have a 3 in pipe all the way to the back. Sounds almost the same (from outside) but much quieter inside. I thought from a performance standpoint you would want no back pressure after the turbo. Mario
  13. Wow! I vert g-nose! Cool car! Mario PS my friend used a railroad crossing sign as the sheet to cover the well.
  14. Your ZX is one of the cleanest and most modern looking ones I have ever seen! It looks amazing! But... I think you should add clear headlight covers Mario
  15. Thats exactly what happened to mine at the drags except it was the #1 cylinder and I spent a week chasing an exhaust leak Mario
  16. You need the manual flywheel, the auto has a pressure plate and won't work unless you get a 10k RPM clutch setup. The driveshaft is iffy. On my ZXT I used an NA 5 speed and had to have a custom driveshaft made (NA trans output shaft to ZX Turbo diff) or you can swap the pinion flange on the differential. Not many people mention this so I guess it's all the luck of the draw. 300zx input shaft and bellhousing is different according to what I've read online, but I've never tried it. Any L series transmission from 70-83 bolts up. For the KA tranny, you need an L series bellhousing and you have to get it machined to accept certain parts (I think some bearings and shafts). The write up is on here, as well as a few people that offer that service. I've got an extra 4 speed, and I might have a 5 speed soon but the 2nd gear synchros are going out. Mario
  17. Ok, so high impedance, are you using PWM control or resistors for the injectors? Mario
  18. High or low impedance injectors? Mario
  19. Did you bench bleed the master cylinder before installing it? Mario
  20. Sounds, looks, and is BEAUTIFUL!!! What's powering this gorgeous creation? Mario
  21. And it's for a love compatibility calculator Mario
  22. I regularly check Hybridz at school and some of the older lab computers don't have pop-up blockers and I have yet to get pop-ups from this site. What are you using to scan for adware? Also, it was my understanding that this site uses Google Adsense, which is content sensitive. If the ads contain porn then that's usually a sign of adware/spyware. Mario
