primaz Posted June 10, 2018 Share Posted June 10, 2018 I am thinking of upgrading an R200 from stock half shafts to CV's and have read a couple of long threads about issues of slippage from Fotofab CV's that seem to indicate that is a common issue, and have read the thread on DSS which sounds like in 2017 to early this year they had issues? and while that person sounded like he finally got a set that would fit, I am confused as to which CV kit really is a direct bolt in that has not slippage and will work well? For this application I would be doing it on 1 or possible 2 of my more street machine Z cars, one with a 3 liter Datsun Spirit engine and the other with a 2.8 Datsun Spirit engine. I have a much more extreme race/street Z that will likely need something more bullet proof, maybe the T3 kit which I heard now is available for newer more common Infinity Q50? Not sure if that will hold up to around 800 HP ? Quote Link to comment Share on other sites More sharing options...
rturbo 930 Posted June 10, 2018 Share Posted June 10, 2018 ZCarGarage just came out with a new bolt in CV kit that looks promising. http://www.zcarblog.com/2018/06/08/performance/parts-z-car-garage-cv-axles.html Not cheap though. Quote Link to comment Share on other sites More sharing options...
primaz Posted June 10, 2018 Author Share Posted June 10, 2018 14 minutes ago, rturbo 930 said: ZCarGarage just came out with a new bolt in CV kit that looks promising. http://www.zcarblog.com/2018/06/08/performance/parts-z-car-garage-cv-axles.html Not cheap though. Thanks, that kit looks really promising. Do you know anyone whom has used it? They do have some great case histories posted. It is a good chuck of change but cheaper than that one listed in one of the threads discussing the DSS issues one person had for $3400. I am about a month or two from doing the upgrade so this is great information as I do not want to make a mistake as I might end up doubling the error on two cars? "rturbo 930" both of these Z's already have R200's, what do you think of the T3: Drop Mount / Dogbone and their R200sn mustache bar? Is that more for looks or what? I am curious as the only issue I have encountered on these two street 240Z's is the typical clunk of the half shafts. Quote Link to comment Share on other sites More sharing options...
rturbo 930 Posted June 10, 2018 Share Posted June 10, 2018 50 minutes ago, primaz said: Thanks, that kit looks really promising. Do you know anyone whom has used it? They do have some great case histories posted. It is a good chuck of change but cheaper than that one listed in one of the threads discussing the DSS issues one person had for $3400. I am about a month or two from doing the upgrade so this is great information as I do not want to make a mistake as I might end up doubling the error on two cars? "rturbo 930" both of these Z's already have R200's, what do you think of the T3: Drop Mount / Dogbone and their R200sn mustache bar? Is that more for looks or what? I am curious as the only issue I have encountered on these two street 240Z's is the typical clunk of the half shafts. I believe it has been offered to the public as of only yesterday, so no, I certainly don't know anyone personally running one, it appears the only people running the kit at the moment are people who are close to ZCG. At a glance, I think it's a better kit than what Wolf Creek offers. Regarding the mustache bar, I don't know if there's a benefit to the aftermarket units available that I'm not aware of, perhaps there is, but it's not on my shopping list. Money better spent elsewhere IMO. Maybe you will expose a weakness of the stock mustache bar with 800hp, but I'm thinking you probably won't with 300 or less. I could be wrong, of course. Regarding the drop mounts, I believe I've heard that the stock ones are a bit flexible, but I think this can be solved with some simple reinforcement. I recall John C talking about this somewhere on here, but I'm stretching my memory a bit. Quote Link to comment Share on other sites More sharing options...
NewZed Posted June 10, 2018 Share Posted June 10, 2018 When you're looking at parts like this you should break it down in to subcomponents. Machining the races and balls for the joint is the most important part. It would not be surprising to find that everybody gets their joints from the same off-shore manufacturer. Who just copied the Posrsche 930 design or some other easy tripod or other "CV" design. The rest is just axles and splines and flanges. And, in that link with the video about "looseness" it's not even clear what the guy thinks he's talking about. Watch that video, at about 40 seconds, and you'll realize that he didn't show anything. He wiggled a tire and that's about it. Quote Link to comment Share on other sites More sharing options...
mtnickel Posted June 11, 2018 Share Posted June 11, 2018 If you're resourceful enough to find some original Z31T axles, I still believe that's the nicest swap. The main benefit is that there are no fasteners on the diff end...the axle plugs right into the diff. It's just a matter of getting a companion flange on the outboard side to bolt it in. I'm biased perhaps as I sell weld on adapters...but adapters are $195, used Z31T cv's will run you 250-280, and welding the adapter in probably another $100 if you can't do it. So $550 all in. They are known to be very strong too. See my post in the Drivetrain section. Encouraging that Z garage has made a better set. I don't see how theirs don't have adapters though? Still looks like 930 style with adapter...maybe they weld them? I bought the wolf creek setup first hoping it was just a bolt it, but like Z garage found, the CV's they use are terribly sloppy. I then bought true Porsche 930 CV's, but the idea of 20 fasters for axles didn't appeal to me, so I figured out the Z31T setup. Quote Link to comment Share on other sites More sharing options...
trackzpeed Posted June 13, 2018 Share Posted June 13, 2018 I’m the guy with all the DSS fit troubles. Once they got the machining right we were good to go...... but to be fair, the problem was with the stub axle not the half shafts, and the extra expense involves the stub axles as well. My biggest fear was snapping a stub axle at pace..... after I had completed the swap, the stock half shafts were still in good shape. Other than changing out some hardware, the half shafts fit fine and I run them very hard on track with and LS1. Hope that helps. Jim. Quote Link to comment Share on other sites More sharing options...
primaz Posted June 14, 2018 Author Share Posted June 14, 2018 15 hours ago, trackzpeed said: I’m the guy with all the DSS fit troubles. Once they got the machining right we were good to go...... but to be fair, the problem was with the stub axle not the half shafts, and the extra expense involves the stub axles as well. My biggest fear was snapping a stub axle at pace..... after I had completed the swap, the stock half shafts were still in good shape. Other than changing out some hardware, the half shafts fit fine and I run them very hard on track with and LS1. Hope that helps. Jim. Jim, Do you feel now that DSS had changed their R200 Datsun CV solution and if so would yo recommend them now? Is there a link to their Datsun R200 product or do you just call them? Thus far the one that RTurbo listed from ZCarGarage seems like the best but it is a little on the steeper side at $1500. I have not made up my mind yet... Quote Link to comment Share on other sites More sharing options...
trackzpeed Posted June 14, 2018 Share Posted June 14, 2018 Call DSS. As I said before, my problems with their product were with the stub axles not the half shafts. They use the larger/stronger 108mm CV and are very stout. You won’t break one IMO. unless they have changed then supplied hardware, that’s the only thing you may need to source on the differential side. HTH. Jim Quote Link to comment Share on other sites More sharing options...
JMortensen Posted June 16, 2018 Share Posted June 16, 2018 Best? www.modern-motorsports.com 930 setup. It doesn't have adapters that bolt to the stock diff output stub and companion flange. It has a proper chromoly stub that plugs into the diff, and chromoly companion that attaches to the stub axle at the wheel. Couple with their 37 spline upgraded stub axles, and that IMO is as strong as you're going to get for the R200. Next best? www.modern-motorsports.com Z31T setup with shorter CV shafts. The Z31T shafts can be tough to find but they're pretty strong and with the shorter shafts they fit well. Same thing on the stubs, m-m sells chromoly stub axles and adapters to connect to the CV instead of an adapter that bolts to the stock companion flange and diff output flange. After that: everything else. DSS, Wolf Creek, Ermish, whatever other vendor you want to pick. These have adapters that bolt to the stock companion flange and diff output flanges and usually use 930 CVs. 930 CVs are strong, no doubt, but attaching to the stock flanges is going to be where the weakness is in terms of ultimate strength. Also 930 CVs are very popular with off road and racing crowd, so there is a wide variety of quality out there. Cheap ones have slack in them and will cause clunking. The other issue is the adapters: they bolt to the stock pieces and the bolts come loose. Seems to be the norm with this setup, bolts continuously coming loose. Heard of this happening to 510 and Z guys, most recently Mark Haag's car as he had issues with vibrations on the dyno, traced it back to the CVs. Quote Link to comment Share on other sites More sharing options...
trackzpeed Posted June 17, 2018 Share Posted June 17, 2018 Agreed.... DSS also bolts directly to the wheel side stub axle if you buy theirs but you will still need the adapter on the diff side. Moderns complete kit is hands down the top notch but it’s really pricey. On the other hand you will get what you pay for. Quote Link to comment Share on other sites More sharing options...
caperix Posted June 17, 2018 Share Posted June 17, 2018 Any thoughts on the ttt stub axle eliminators? They don't say anything about axles on the website but if factory Nissan axles can be used that may be a cheaper setup. I keep thinking j30 5 bolt outputs on the diff and s15 axles with the ttt stub axle eliminators would be a good strong setup. Quote Link to comment Share on other sites More sharing options...
JMortensen Posted June 18, 2018 Share Posted June 18, 2018 Eliminating the stub axle is a good idea. The TTT upright looks like a dumbbell weight to me. I'm not a big fan of shortnose R200 swaps either because of the way they usually attach to the strap bracket in the chassis. Some good, some bad there IMO. Quote Link to comment Share on other sites More sharing options...
Neverdone Posted June 18, 2018 Share Posted June 18, 2018 The RT Mount attaches to the strap mounting holes in the chassis as well for longnose R200 swaps as well. I'm not following why that really matters. Quote Link to comment Share on other sites More sharing options...
JMortensen Posted June 18, 2018 Share Posted June 18, 2018 The longnose R200 loads the strap mounting holes vertically, the way they are deisgned to take a load. The shortnose does not. It adds what acts like a lever to the mounting holes, then pushes up on that. This is why there have been a few cases of high hp guys tearing up the unibody right there with shortnose diffs. If it has happened with a longnose and RT mount, I haven't seen it. Quote Link to comment Share on other sites More sharing options...
Richard Oben Posted June 20, 2018 Share Posted June 20, 2018 Not saying better or worse in any way. Just my opinion. 930 CV joints, inners and outers which are 28 spline with 300m axles from RBP manufacturing. The inners mate to an 8.8 with 28 spline rear end from a Lincoln with aluminum case. The outers mate using Z car depot 930 to Z hubs. We used 280Z stubs, which are much stouter than the 240Z stubs 28 spline also. LS1 power, 6 speed, 3.73 gears have not had any problems so for but not a lot of miles on the completed set up. More pics in the thread on Gen III and IV forums. HTH, Richard. PS we put rubber hose on the axle to keep the boots compressed. Quote Link to comment Share on other sites More sharing options...
mtnickel Posted June 20, 2018 Share Posted June 20, 2018 (edited) Here’s what our slim welded adapter looks like. Basically converts the stock flange to a larger one. Stock z31t axles fit like this. 4 fasteners a side = winning. Edited June 20, 2018 by mtnickel Quote Link to comment Share on other sites More sharing options...
LLave Posted June 20, 2018 Share Posted June 20, 2018 2 hours ago, mtnickel said: Here’s what our slim welded adapter looks like. Basically converts the stock flange to a larger one. Stock z31t axles fit like this. 4 fasteners a side = winning. That is what I am running.... Once I get that far. Quote Link to comment Share on other sites More sharing options...
NewZed Posted June 21, 2018 Share Posted June 21, 2018 How do those locate, or center, the CV? Just curious. It also looks like you're using the outer edges of the original flange to locate the ring. Do you use some sort of fixture to center the ring on the flange before welding? Just wondering how to be sure the CV is on center and perpendicular when it's all welded and bolted together. Quote Link to comment Share on other sites More sharing options...
mtnickel Posted June 21, 2018 Share Posted June 21, 2018 1 minute ago, NewZed said: How do those locate, or center, the CV? Just curious. It also looks like you're using the outer edges of the original flange to locate the ring. Do you use some sort of fixture to center the ring on the flange before welding? Just wondering how to be sure the CV is on center and perpendicular when it's all welded and bolted together. Great questions. We found out the hard way that the square flange isn’t concentric. It’s a rough cast and can be off almost 1mm. The z31t axle centers on the locating ring of the adapter. The adapter sits flat to the machined face of the stock flange. That takes care of 2 orientations. To weld the adapter on correctly we made the square a touch small. That way you can strategically grind the edges of your square flange to be equal from the Center locating ring. We recommend using a dial indicator to verify you get it reasonably close. If it’s a little big, you can use feeler gauges, shim stock, or even paper as stock to shim it true before tacking. Or you can rent the jig we made to locate it. Haha both options shown in pics Quote Link to comment Share on other sites More sharing options...
