ZDrifter Posted June 30, 2007 Share Posted June 30, 2007 3/78 280z. RB25DET. Car will be used for track, drift, time attack, and autocross. Currently at 250whp, goal is 500whp. Quote Link to comment Share on other sites More sharing options...
wheelman Posted July 1, 2007 Share Posted July 1, 2007 I have a 73 240 with a completed LT1/5-Speed swap. Needs body work but heres the list of mods/replacements: 95 LT1, LT4 Hot cam, high rev springs, custom tune 89 WC T5, stock R200, 3.54:1, Power Brute LSD 300 ZX Turbo CV axles Toyota 4x4 front calipers, stock rotors Stock rear drums, all new hardware and shoes Steel Braided flex lines Fuel tank From 2001 Camaro All bushings replaced with urethane Energy Suspension parts Ground Control Coil overs, 225 lbs/in front, 250 lbs/in rear MSA Swaybar set DP biscuit type camber/castor plates Tokico Blue struts Taurus 2-speed fan JTR radiator and mounts Custom frame rails and sub-frame connectors Lots of other things to support the V8 swap. Dyno readings: 274 RWHP @ 5800 RPM, 307 Ft/Lbs @ 3800 rpm Wheelman Quote Link to comment Share on other sites More sharing options...
chrism Posted July 1, 2007 Share Posted July 1, 2007 75 280z. Just got it in the spring. Was going to be my daily while if fix the timing chain that my toyota truck coughed up one night. Got the Z home and it started have electrical problems. Saw all the relays and wires running all over the place and decided to swap with RB20. Now I have the new engine in and getting very close to starting it up. Thought it was just a drop in according to some people. The list is long for modes and parts needed to get this thing in right. I will start another thread on all the things I needed to do later. Just want to get this thing started. Quote Link to comment Share on other sites More sharing options...
speedgato Posted July 2, 2007 Share Posted July 2, 2007 1970 2.98 block ka24 pistons l24 rods ITS Rebello n42 head Nissan Comp header Port matched intakes Ztherapy SM needles (tripple Webbers next week!!) Crane optical ignition MSD coil Griffen radiator 83 5spd RPS 6 puck clutch HKS flywheel Nissan Comp 4:11 lsd Compomitive 15" staggared wheels V700 DOT's Toy 4 piston calipers (have Wilwoods, waiting for coilovers to install all at once) Quote Link to comment Share on other sites More sharing options...
Teekass Posted July 2, 2007 Share Posted July 2, 2007 Early '77 280Z 2+2 125k miles. 355sbc/th350. Only been driveable a few weeks.....lots left to do! I'm putting a V6 in the Barbi Jeep.......if I could only figure out how to get my Mig to weld plastic . Quote Link to comment Share on other sites More sharing options...
garvice Posted July 2, 2007 Share Posted July 2, 2007 76 260z 2+2 l28et Quote Link to comment Share on other sites More sharing options...
SkYBlue280Z Posted July 2, 2007 Share Posted July 2, 2007 1978 280Z here Quote Link to comment Share on other sites More sharing options...
ZXRockie Posted July 2, 2007 Share Posted July 2, 2007 oh well, 2 years ago this guy gave me a rusty 1974 260z, because he wanted it out of his parking space. Then I built a nice RB25DET for it and a bunch of cool parts, but I found it very rusty during the process, so I'm ancher right now. at the end of the month it will be going through micro-mineral blasting, bodywork, and a midnight blue paint job, then I can keep going with the project. wish me luck...lol.. By the way I need a 260z or early 280z fuel tank. anybody? Quote Link to comment Share on other sites More sharing options...
Chewievette Posted July 2, 2007 Share Posted July 2, 2007 '72 240z, owned it for over a year and I'm still trying to piece it together. but I'm getting twards the end, end of the summer maybe... Quote Link to comment Share on other sites More sharing options...
ktm Posted July 3, 2007 Share Posted July 3, 2007 '72 240z. I've owned it for a little over a year now. So far I've made the following modifications: Tokico HP Blues and Springs Urethene Bushings ST Sway Bars Swapped R-180 for 3.545 Gears L28ET Swap Wolf V500 EMS T03/04E 0.63 A/R 50 trim water-cooled turbo Supra 440cc injectors 1978 280z 5-speed 60mm T/B N-42 non-egr intake Quote Link to comment Share on other sites More sharing options...
Spyder Z 15 Posted July 3, 2007 Share Posted July 3, 2007 Real name- Dustin Car name to be -Zweet 72 '72 240z in pieces. Bought for $500 and already made that money back on parts that came with the car. Plans- Might run N/A L28 for a while unless I find an awesome deal on a stock Z31 or 280zx turbo. Current goal is to get the car running and on the road. Pics of the puzzle can be seen in the link in my sig below. Quote Link to comment Share on other sites More sharing options...
slownrusty Posted July 4, 2007 Share Posted July 4, 2007 Mine '78 S30....finally running well after 15years of sitting in a Forest and having to be dug out....rescued her in April Yasin Quote Link to comment Share on other sites More sharing options...
Guest 280ZForce Posted July 4, 2007 Share Posted July 4, 2007 Justin, but most call me J - 78 280z...check my sig for specs Quote Link to comment Share on other sites More sharing options...
justinr54321 Posted July 4, 2007 Share Posted July 4, 2007 Justin-1972 240z, restoration project, but runs strong... Quote Link to comment Share on other sites More sharing options...
spacecase70 Posted July 5, 2007 Share Posted July 5, 2007 I have a 76 S30 all stock 'cept for a MSD blaster 2 coil, and a turbo 5 speed. Quote Link to comment Share on other sites More sharing options...
RickyBobby Posted July 5, 2007 Share Posted July 5, 2007 76 280Z with a blown engine and mostly rust free I scored for $160 about a year ago. I think it was silver. Just purchased an 83 ZXT 2+2 for the donor swap. Don't worry about sacrificing a good ZXT for a donor motor, this car had to be the most completely rusted out car that I have ever seen. As I was pulling the car onto the trailer the tow/tiedown hook ripped off and took the bumper and most of the radiator core support with it. My goal is to be driving this beast to the 2008 Walter Mitty at Road Atlanta. Quote Link to comment Share on other sites More sharing options...
LT280z Posted July 5, 2007 Share Posted July 5, 2007 77 280z, L28, Holset, MS&S, And a bunch of other stuff.... Quote Link to comment Share on other sites More sharing options...
johndaniel.b.coffin Posted July 6, 2007 Share Posted July 6, 2007 my new project, just purchased in june 07. needs alot of work. not bad for $100.00 Quote Link to comment Share on other sites More sharing options...
Fuzz260z Posted July 6, 2007 Share Posted July 6, 2007 '77 260z, L26 stocky Quote Link to comment Share on other sites More sharing options...
76s30 Posted July 7, 2007 Share Posted July 7, 2007 76 Fairlady Z busted f54/n42 with 270/280 cam and triple 40mm mikuni's Turbo swap in progress. For now jack stand racing. Quote Link to comment Share on other sites More sharing options...
