tube80z
Super Moderators-
31
Everything posted by tube80z
The frame rails are nothing special except folded metal. You could make a pattern from heavy card stock and have them created locally and save a lot of money. Those would fit your car exactly. That will save you the tarrifs and the shipping. 1,5 mm thick rails should be more than enough. The other option is to split structural square tube and if you can't find a sheet metal shop. That will probably be more expensive, but is an option. The fender brace is a very simple item you could save money having made locally too. I helped a friend with a street car project and rather than weld items to the unibody and increase the potential for rust we opted to use some of the structural adhesives that new cars get built with. It's been on the car for 15 years and seems to be holding up well. Hope this helps, Cary
ideas on how to get this rusty bolt out
tube80z replied to adsdsasdasdasda's topic in S130 Series - 280ZX
I have a set of extractor wrenches that come in handy for things like this. Here's a link https://olsatools.com/products/7pc-offset-extractor-wrench-set?variant=41307851161651&country=US¤cy=USD. Cary -
On my C&R (Jeirco knockoff) I have a two-piece shifter similar to the original Datsun version or a T-5 shifter where only the handle needs to be removed. The C&R has all the linkage on top, so you have more side clearance, but it is exactly the same three-rod shift fork linkage as the Jerico. Bummer the clutch plate is still catching on the flywheel bolts.
I think the only downside, other than size, is the 180 pounds these weigh, from my research. DCGs are very heavy and have a deep oil pan that limits ground clearance. For a high HP car where the weight isn't a problem, I think that they could be a good solution. The MaxxECU is a nice bit of kit. I got to see one being put on a friend's car and it had tons of IO for the cost.
I'd suggest a flat metal bracket that bolts (rivnuts) to the inner fender and goes over the top of the battery and has a small jog bend to capture the side and then bolts to the upper angle of the drysump tank bracket. And maybe some aluminum angle riveted to the bottom to keep the battery from shifting.
On a friend's race car he has two things that help to speed up the removal of the transmission. A dry break on the clutch line and the second is the over the top of the bellhousing exhaust. Having the exhaust out of the way when the car is still warm helps a lot if you need to remove the transmission for gear changes.
Cool stuff Clark! I dig the ARB. Cary
The car I had planned to do this on was going to run very low, so all the suspension pick-up points were raised 2+ inches. The upper mount was a plate that bolted into the upper strut mount and used an 8-inch-long jack bolt with a clevis for the top of the shock to bolt to. The tube holding the jack bolt would have a sheet metal bracket supporting the end of the threaded section, or I'd extend the cage tubes directly into this to make the mount stiffer. That was work still left to do. I have some Penske 7350 Base valve shocks (eBay specials) that I planned to revalve. These have 7 inches of travel, but I didn't plan to use all that, and are very long. This has now been on the back burner while I try and deal with some back health issues. I also have a street car that I want to finish and I have been looking at doing a-arms but using a bolt-in solution to not destroy any value the car may have. So I have been thinking about this more lately, which is why your post has piqued my interest.
I'd probably start in the 400 to 450 range given the tires then. The struts were stock-style reinforced 280Z bodies. Spring rates were for springs but if I remember correctly MR should be 0.97 or close. I can't find my notebook at the moment. It's all detailed in buried threads on this site. There's a lot of it in the shock/unsprung weight FAQ I think 5 inches should easily be enough for a track car. By burm do you mean a banked corner? I know a few people on this site run their cars at tracks with high oval-style corners, and perhaps they can chime in on what they see for travel. My wife has a '65 Mustang. That's a sweet kit from the look of it. My mock was very similar, except it used a Joe's style front 2-piece a-arm. So you only needed to have two holes for the A-arm to poke through. I was doing the upper mount similar to what Griggs uses on their Fox body conversion. It comes down from the stock Datsun upper strut mount.
Hi Carlton, A lot of this has been hashed out over the years. There are some helpful stickies available in the FAQs for selecting damper and spring rates that you may want to refer to. Before you get too far into recommendations about springs, etc., would you tell us what you intend to use this car for (track only, dual purpose, autox, street, etc.) as this will help give you better recommendations. It would also be helpful to know what you intend to use for tires, as this is one of the most important factors to know. Low-profile radials will require softer springs than a higher sidewall racing tire (such as a slick, R-compound, or HP 200 TW). The more grip the tires can generate, the higher the spring rate needed to be able to deal with the forces that take up suspension travel. I'd agree with Mike Maier's criticisms of the Apex upper A-arm on the front suspension. It is going to always limit the amount of available suspension travel that can be used. With regards to how much travel you need, that will depend a lot on tires and the use of the car. On my autoX/hillclimb 240 that weighed 1850 or 2050, depending on class, I ran Hoosier bias-ply racing slicks and some of their radial slicks. The spring rates I typically used were 400 to 600 lbs/in on the front and 400 to 550 lbs/in on the rear. This car was droop limited, and front suspension travel on the roughest hill was typically less than 2.75 inches in the front and 3.5 inches in the rear. I experimented with softer and stiffer rates but found this range worked best. A friend's street legal dual-purpose car running on 200 TW or R comp low-profile tires weighed 2400+ (LS and T-56). This car was happier with 375 on 450 spring rates. It was also droop limited and I found out how horrible this made the car ride on normal street drives. So if you go down this path I'd recommend a quick disconnect when not needing the limited travel. My personal feelings on the Apex upper a-arm are that it should be about 7 inches long to get adequate travel. On my a-arm mock ups, the only reliable way I could see doing this was to use holes or pockets on the inner fender that allowed moving the inner pickup to the center of the frame rail. Then it looks more like a '90s to 2000s Mustang strut to a-arm conversion. The parts to do this are that bad if you use circle track components, and you can source used parts from eBay for trying out different ideas. This requires you to have access to fab equipment, so if you don't, this isn't a road to go down. Cary
If you're using the stock rack you need the 113 u-joint listed above. You can then mix and match to any custom (weld-in, double-D, etc.) linkage between the rack and the steering coupler.
That is a lot of work. Cool to see this come together and can't wait to see it run on the track.
tube80z replied to FastFloridian's topic in S30 Series - 240z, 260z, 280z
For a street car I think the rails make sense. For a race car that has a cage perhaps not. For a similar amount of weight you can triangulate the cage with tubing on top of the floor that extends to the suspension pickup points. -
You can find cheap options on eBay by searching for "used IMCA lower control arm." These straight arms can take various balljoint combos and use a rod-end mounting or a bushing. That will get you options like this https://www.ebay.com/itm/156253492635?_skw=used+imca+front+lower+contrl+arm&itmmeta=01JFH1PRRQS4VARS84HE8VBR09&itmprp=enc%3AAQAJAAABAHoV3kP08IDx%2BKZ9MfhVJKmlnKptmEq49QXHuYUVK0t%2FVqtBOgHRzDCm%2BhuINAAj7rXduUHGplWvDm0w32o9rUYodX6FM68bik%2FtkVdR1OEgMQ4I6PEadB120ZYc9zeSyv94OLc3GuJyjb6aYDdKVZxcAMN9rjS5T4ibk%2FjJBDnCv3n%2FZTMwwRG4otjIm1OadN3F8Hka5QshaeMFiCF5qnoASz4Twy1WWKQTodhNhuPEYc28a4ZzlZ8AqqHhHRyyLV34MiKRX9jF82K8A48bmtIK3tFolRCJaAaOOv6BNOSwfDE8qOE5oa9QaEviKS4QtPVw4DgxBXjo4Dm4bOU3SGk%3D|tkp%3ABk9SR7aM26H8ZA. Two types of TC links are used. One has a stud and uses a solid rod end for connection. The other uses a clevis that connects the TC link. For research, you can get a few used examples off eBay for $20 to $30 or get the manufacturer's catalog for options. Sorry for the hijack. Cary
Wish I could find an intake mani
tube80z replied to Bakerz22's topic in Gen III & IV Chevy V8Z Tech Board
Check Amazon. They have shipped by Amazon for the plastic piece of $115 and free shipping. I know you'll need the rest but this may help. https://www.amazon.com/ACDelco-89018187-Original-Equipment-Manifold/dp/B00S0A2JHY/ref=sr_1_13?crid=AOD5M4YFK7S2&dib=eyJ2IjoiMSJ9.IrazLZcks-CeAYxm7Nnw9H2LntY3DpM73oIQRsYT5Q4kI1yKjso87_ovlL4gKf7IZwTBIOQwjcjoCZ-wm6uIlepFewMz9Ayqdldqr6r87dC5Ehy4pmoQSIDcWD7pFUPZlXwOMxtO4QzB-smVvXAPewzAbfdukibkpMTnaMkrNUtvILiaJONc57aR6maJaoARvNG1cv-nVY5gaN78BHLNFCheIc7_v1jAALZ5NVwAAZU.S7qhbRJHRfu8O6PFfX2faRbbpk6JiNPx6YMpDGWCdPE&dib_tag=se&keywords=chevy+ls1+manifold&qid=1727123364&sprefix=chevy+ls1+manifold%2Caps%2C151&sr=8-13 You can also get the Blazer SS too. Good luck. Cary -
When I need inspiration I check out your thread. Cary
You can remove the core support but you'll need to add the structure back for support. If you needed the top out of the way you could make a new core support angled out of the engine bay for clearance. If you have a thicker cooling stack this could be moved out for engine clearance. I've seen a few on race cars where this is removable to make engine changes easier. There's been more of the make the top part of the core support removeable to ease engine changes. The often fall into the turbo DOHC engine swaps if I recall directly. You can do a search here or in Google (or search engine of your choice) and see how people have made this modification. Hope that heklps, Cary
240z SCCA vintage race car, restoration
tube80z replied to AydinZ71's topic in S30 Series - 240z, 260z, 280z
Aydin, I didn't mean the adjuster was electronically controlled. Just that with pressure sensors, if you found a sweet spot for brake balance wet or dry you could easily get back to it. Push pedal for 1000 PSI total pressure front to 700 and rear to 300 for a 70/30 split as an example. Easier than needing a helper use a torque wrench on a front or rear wheel to set balance. On the electronic side you could have a channel to send info to a stepper or servo motor connected to the adjuster cable and do fun things like preset pressure by corner or based on weight transfer (light vs, heavy braking). And you could implement the old 90s technology of pendulum brake bias. BMW and Mercedes had systems that used a hanging weight to adjust side to side balance on the front to help with inside wheel lockup. I think if you search groups on FB for E36 Bimmers and the 190 Mercedes they have pictures or video of them working. -
If you have a logger/dash and front and rear brake pressure sensors you can set it by pressure in the pits. Instead of turns. Turns are also hard to keep track of when you come running up to a corner. I have a Tilton pedal set and their bias adjuster already. I'm looking at changing from turns to a linear system of steps to easily change from max front to max rear. I've seen two systems I like. During the Schumacher era at Ferrari they created a stepped system so Michael could change brake bias between corners. Triple Eight racing (V8 Supercars) created a system like an ARB adjuster for their drivers and that's another option. I have had too many runs that rain started falling and I would have loved to be able to change bias and ARBs quickly. I'd like a Bosch motorsports ABS but it's too expensive to justify for me. -
You have packed a lot into your intro. There's some good advice below to consider in the posts to your question. But I have to ask you what is it about the 280 you love? I don't mean that coyly or as some flippant remark. What is it you really like? I'll give you why I like the Zs. I grew up around them when they were new, my uncle was a general manager of a Datsun dealership so we got to try out the new cars. We raced with my uncle at autocross and hillclimbs (I was a kid so I just went along). Back then the Z cars were fast and sounded awesome (I have the hearing loss to prove it), and were amazing at cutting through the corners both stock and modified. Our local racing club had about 10 people driving stock to all-out racing versions. 50 years pass and a lot of that coolness has mostly worn off except for the look of a lowered S30 with an airdam and rear spoiler. I have to admit the sound of a modified Z makes me happy when I hear it. But this site exists to help people get the most out of them. And the reality of that is as cool as the L28 engine is you're looking at spending a lot of money and you'll have an engine that makes 200 to 250 HP. Sure you can get more but then all the other parts that connect to that engine are starting to get pushed past their limits given the age. While I don't disagree with any of the posts below you should still read about a lot of the mods and why they were done. You'll find that in many cases they were driven by it costing too much, parts NLA, etcetera. A bit of advice from me. Never by an engine, transmission, or rear end unless you plan to use it within a few months. Even if you plan to use it that's not the same as ready to bolt in. If you want a street car with a certain coolness and triple Weber carbs, then build it. But when you spend 10K on an engine and find it's somewhat finicky to drive but cool all the same. But for less, you could have 350 HP V6 in the DI Chevy LV3. It won't sound the same as the L-motor but it's lighter, a lot newer, and will get excellent mileage, It will start anywhere if it's hot or cold by the sea or at altitude. This site has a ton of info on how to do the same for the suspension and how to get a cheaper rear diff, especially if you want an LSD. I could write a lot more but this is probably too long as it is. Welcome to Z ownership. Cary
Here's the Mustang GT-4 camber plate I mentioned Here's a slightly better picture. You can see they moved the center a bit. You could make something like this but has a square shape or even just a flat edge and easy shim adjustment awaits. I was looking at this for being able to make faster adjustments between runs when testing for autocrossing. Having to jack up the car wasn't going to help make it faster. In some of the events I run, we may get 10 minutes between turns. You need to add in looking at the data to see if it helped if the lap time doesn't seem to show an improvement. I have a long list of items I want in my next car. At the top is a lever adjustable brake bias with presets. So while driving I can change between slow corners and fast corners. Drive adjustable ARBs, and externally adjustable ride height. -
@AydinZ71 I'm not sure that bending the strut will work for Konis as they are generally tight. I've heard rumors but never seen them in person about a certain BMW team that had a jig that mounted in a hydraulic press to bend in some extra camber. Getting the tube out of the is going to be some work but I think that might be the best way to go. Another option would be to build a custom strut and use Nascar hubs 5x5s I think are called. That will help with pad knockback. Another option if you haven't used them is 280Z struts. They are thicker and should flex less. Or you can show up with some DTM inspiration Cary -
It's funny how certain rules are set in stone and others are ignored. You could make a custom camber plate that is mounted to the top of the strut using the tower edges. There would be no more center hole in this design as it would all be covered. If they challenge it you could argue that you wanted to be able to swap springs more quickly out the top. Take a look at rally car service videos and many of those cars come out the top. My personal choice for camber plates would be a square/rectangle design where you can shim for camber or caster/strut angle (rear). Ford has a really cool design I meant to steal but couldn't find it again on their GT4 Mustang. Hope that helps, or inspires some rule bending. -
You can use autotranslate to get a version that will give you the gist of what's being discussed.
