I have a 2002 plastic camaro LS fuel tank. The picture below is identical to my setup. I read that the fuel pressure is regulated inside the tank. Can anyone verify this?
I'm trying to figure out how to run the fuel lines. Most chev guys just one line from the front and mount a corvette regulator/fuel filter in the back with a short return line on there non camaro tank setups. I'm a ford guy. we run a feed and return to the front of the car where out regulator is. I'm trying to find the cheapest solution
Just help a buddy with an L33 5.3 L, Th400, LS6 intake, chinese head studs, arp rod bolts, ls6 vette cam, new supercharged vette head gaskets. DIY turbo kit, T6 turbo. Made just shy of 700 to the wheel on pump gas and meth
This was my preferred swap, I would still love to do this swap but I ended up going LS. The cost of the LS swap is so very cheap and everything is documented for swapping the motor into pretty much anything. The 2014 GT have the Boss 302 rods and are much stronger. They can make 750 whp on mild boost and still be reliable.
I used the ez-wire 21 circuit kit. My wiring was hacked. The previous owner used house wingnuts/marettes to attache the wires. The new replays and wiring sure helped with the dim headlights.
800 bucks? AM I reading that wrong? for a water pump?
This is the one I was going to order for my 5.3 setup
http://www.summitracing.com/cart/add/ADO-251-734
Serious fantastic work right there. I would proud of the small patched I had to make in my car but I cannot compare to you skills. Wish I had the know how and skill to make a few of those panels.
This is a 2005 L33 5.3L LS engine on CX racing mounts. Broom handle is laying across the frame rails. You have about 1 3/4 - 2" clearance using a LS1 intake. Truck intake will hit the hood.
This is a factory L33 truck pan on a non lowered factory suspension 71 240Z. I am swapping out the toe batwing oil pan.
