Everything seems reasonable now. I called Bilstein once again and got numbers very close to what rxsleeper and what I originally posted from the VW forum. I guess there was some miscommunication with the Bilstein rep. the first time.
If you want exact numbers see post #302.
I have his front 4 piston set. They're big and light with plenty of potential if set up properly.
I think his 6 piston set is way more than the car will ever need.
Did you take those measurments yourself? What were your measuring points?
I contacted Bilstein and was given these specs for the P30-0032
Extended length 19.74''
Compressed length 13.98''
Body 12.52''
Stroke 5.76''
Edit: called Bilstein Rep again changed body length.
That's good news i'm running spring rates in the lower 300's hoping maybe I wouldn't have to revalve.
I'm replacing my blown older version 8610's and hoping that the Bilsteins have similar dimentions which means something around a 15'' body with 6'' stroke.
Edit: I did some searching around in the VW rabbit forums for some specs on the Bilstein F4-P30-0032-MO and found some possible dimentions.
Body length: 12.52''
Body diameter: 1.5''
Extended length: 20.12''
Compressed length: 13.86''
Stroke: 6.25''
Anyone want to confirm?
I couldn't find the exact info but, does anybody know the spring rate range when using the Bilstein P30-0032's?
Also, anyone with these struts installed want to chime in on their performance?? Is the non- adjustable aspect a big downside?
Thanks!
There is about a 1/4 inch gap between the hood and front peice. I was thinking about sealing it up with some foam..?
I got the brake ducts at www.pegasusautoracing.com
Here's my version. I mocked it up kind of quick and didn't put too much thought into it so i'm open on any sugestions. I used to have a problem with my radiator cooling too fast but, now my water temps are much more stable at 75-85 celcius so I know i'm reducing the amount of air flow from the front.
I used a 3x6 sheet of .06 aluminum and rivited it all together. I still need to seal everything up and finish the brake ducting before I do actual testing but here it is:
I tried mounting the -19x 9.5 up front and it looked almost the same. However, I didn't check if it cleared everything without rubbing.
If anyone is looking for a set of 4 Gunmetal 9.0 x -13 (fronts) i'm willing to trade my 9.0 x -13 for a pair of 9.5 x -19 (rears).
