19
Everything posted by rturbo 930
Seems like HybridZ has had the bare minimum to run for a while now. The healthiest forums I'm on all have active admins that are proactive in keeping the forum running and improving, and on top of any issues. That is not the case for this forum, and one other I'm on, and both have been suffering. I would definitely like to see more active admin on here.
Those are all spammers, and can be banned.
What's the color? Looks great!
Why not just move to the increasingly popular Ford 8.8 set up? Seems like that'd be the easiest and most appropriate solution for you.
That area is reinforced compared to the 240z. If you look on the other side of the panel you should see that it's made of some pretty thick steel with some reinforcement, and tied into the subframe, which also has reinforcements to hold the bumper shocks. The 240z has just a pretty simple bracket welded to the rear subframe. Your early 260Z might be slightly different from my 280Z but I doubt it.
I would say a week + 10 posts, and see how that works. I think banning new members from posting links could also help.
Yet Another Axle Thread - Chosing the right setup in 2022
rturbo 930 replied to WindowsDown's topic in Drivetrain
Z Car Garage makes a great bolt in solution that appears to be able to handle plenty of power, much more than what you're planning. Expensive, but totally bolt in. The super 8.8 setup basically requires that you change your entire rear end, and if you're putting big brakes, 5 lug, etc. in the rear, then you kind of have to do the front now too. Lots of scope creep, vs simply dropping in the ZCG axles and being done. -
I'm assuming that head was for an NA build, doesn't removing the liners ruin the flow of the head? I have an N47 with liners removed, I was under the assumption it was junk based on research, and was planning to replace it with the N42 I have... eventually.
They're offering it in three types, A, B, and C. From what I can gather from the PDF, A comes bare, B and C come with a choice of valve guides and valve seats. http://www.pams-japan.com/30cafe/project.php
Yeah I've been following that. Pretty impressive project, it's basically the ultimate N42 head. And it'll only cost you about $5500 to $6800 depending which of the three types you go for. Unrealistic for most of us unfortunately, but for those looking for big power, might be worth it.
fabrication of fresh air vent "piece"
rturbo 930 replied to Alexander240z's topic in S30 Series - 240z, 260z, 280z
Doesn't look that bad. Why not clean it up and reuse it? -
Alright, like title says I'm looking to see if anyone has a copy of this video from years ago, pre-2010. It was a video of a Z doing a quarter mile run, it was a burnt orange color, had ZG flares, and bronze or dark gray 6 or 7 spoke modern wheels. I think it was recorded in Japan. It ran something like a low 10, was powered by, IIRC, an L28 stroker turbo that was clearly making a lot of power, and what I assume was a sequential, but maybe it was a dog box, I'm not sure. It was hosted on google videos so I suspect it's gone from the internet unless someone saved it. Long shot, but maybe someone has it.
That's better, looks like you've got a solid starting point.
Welcome! Can't see your images, I think you need to change the format. I have no idea what .heic is.
Is the engine builder Datsun Spirit? He's a capable engine builder by all appearances, but some time ago I noticed that the estimated power figures that he lists on his site with his different engine builds went from being crank HP to wheel HP. As crank HP figures, they were impressive, but feasible, but as WHP numbers, I think they're outlandish, and I question his ability to follow through. 350whp would be about 400hp+ at the crank which is what the all out drag race motors they build in Japan make.
What would you upgrade on my car?
rturbo 930 replied to fusion's topic in Brakes, Wheels, Suspension and Chassis
2015 Mustang rear brakes that are probably 13" and Toyota brakes up front I don't think is going to be a good combo given that the front brakes do most of the braking. So I'd upgrade those to something more appropriate. Nothing really sticks out to me as a major problem except maybe sway bars, I would probably just upgrade as needed. Sounds like you've already done a ton of upgrades already if you've got a Ford 8.8 diff and a turbo LS. Since it's just a street car I don't know how quickly you'll find the limit of the components you have, and I don't know your driving style, if you're just hammering it on straights, or trying to push it in corners. Another thing that just occurred to me, which I don't see any mention of, is the structure of your car. Do you have subframe connectors or any other chassis strengthening? If not, I would do subframe connectors at a minimum. -
Who is the builder? Datsun Spirit? 300whp is a ton of power for an L stroker, and 350whp is all out race build territory, unless you get one of the DOHC heads that member Derek has been working on. What is the intended use for the car? If you want a street car to cruise around in, I'd go with the turbo option, since you can have a pretty tame and streetable 300whp turbo engine. Probably a lot cheaper too compared to getting that kind of power out of an NA stroker.
No, you can pull the engine complete with transmission. Helps if you have a load leveler.
Based on what I've read, removing the liners ruins the port flow because the port is too big.
Twin cam head for the L6 from Derek at Datsunworks
rturbo 930 replied to Derek's topic in Nissan L6 Forum
There's an article about the KN20 head on Road and Track, nice to see this thing get some recognition. https://www.roadandtrack.com/car-culture/a37360407/datsunworks-kn20-head-brings-dohc-to-the-240z/ -
https://www.instagram.com/p/CR-vb6TrSjL/ https://www.zcarblog.com/2021/07/30/performance/datsunworks-twin-cam-power-for-your-l-series-engine.html 350hp/248ft lb at the wheels. Pretty damned impressive. -
I have no direct experience with them, but I know they've got a >500hp turbo L running them, along with at least one LS swap.
Agreed. And I really don't understand the secretiveness for anything outside of a competitive environment, which this is not. You would think he would at least tell Derek, the manufacturer of the head, what the numbers are. -
Best 280z rear end for lots of torque
rturbo 930 replied to 280cummins's topic in S30 Series - 240z, 260z, 280z
IMO the rear end is the least of your concerns here, that amount of torque is going to destroy your chassis if you don't reinforce it thoroughly. Honestly, I think that engine is totally inappropriate for a Z to begin with. It weights, what, 1200lbs? A 280Z weighs only about 2600lbs. I can't imagine it drives well.
