37
Everything posted by Miles
Agree. Just spent two days searching radiator threads.
PLEASE HELP, rear brake conversion issue
Miles replied to Blob1620's topic in Brakes, Wheels, Suspension and Chassis
I can relate. This link has lists of what calipers go with which rotors and brackets: http://forums.hybridz.org/index.php?app=core&module=search&do=search&andor_type=&sid=c97dfedf362bd0134fa39338154643b0&search_app_filters[forums][sortKey]=date&cType=topic&cId=39435&search_app_filters[forums][sortKey]=date&search_term=280zx&search_app=forums&st=25- 17 replies
- s30 to s130
- disc brake conversion
(and 1 more)
Tagged with:
By the time you are done with your car project you will understand the manual and you will be a better mechanic.
Does anybody know what the items in the pictures are and does anybody have any suggestions as to how i should attempt to problem solve from here? Answer: You need to download a Factory Service Manual (FSM) for your car. It will explain what all of the parts do. Search HybridZ for a FSM. Get a volt ohm meter and learn how to use it. Use the FSM and the schematic posted above and check each part of the ignition system until you find the problem. Running hot wires as a test is going to burn a wire or some component. Asking what this or that is every few hours is never going to help solve your problem. You need to study the FSM and the electrical schematic and methodically go through the car's electrical systems. People are going to be more inclined to help you if it appears that you have been doing your homework first. Study, analyze and then ask the question. Sometimes you just have to think real hard: "Thinking is the hardest work there is, which is the probable reason so few engage in it." -Henry Ford
JCI Install Kit Instruction Manual?
Miles replied to JoeK's topic in Gen III & IV Chevy V8Z Tech Board
Post some pictures of the parts. -
http://forums.hybridz.org/topic/109702-hybridz-is-not-automotive-101/
Too much background noise and not enough of the "problem sounds".
Are you aware that there are two styles of 280ZX calipers? https://www.google.com/search?q=280zx+rear+brake+caliper&client=ubuntu&hs=zlP&channel=fs&source=lnms&tbm=isch&sa=X&ved=0CAgQ_AUoAmoVChMI2en4vr-FxgIVzFmICh3mPQBN&biw=1344&bih=704 http://www.autopartswarehouse.com/shop_parts/brake_caliper/nissan/280zx.html http://www.partsmonkey.com/en-CA/Part?id=153768&ptnum=4056&PartType=Rear+Brake+Caliper&pvid=9591775&Make=NISSAN/DATSUN&Model=280ZX&Year=1981&Engine=L6-2753cc+2.8L+F/I+TURBO+-+Vin+L28ET http://www.napaonline.com/Catalog/CatalogItemDetail.aspx/Brake-Caliper-w-Hardware-Left-Rear-Eclipse-Semi-Loaded-RemfdCaliper-w-Hardware-Left-Rear-Eclipse-Semi-Loaded-Remfd/_/R-SEBSE708A_0248582604 http://www.napaonline.com/Catalog/CatalogItemDetail.aspx/Brake-Caliper-w-Hardware-Left-Rear-Eclipse-Semi-Loaded-RemfdCaliper-w-Hardware-Left-Rear-Eclipse-Semi-Loaded-Remfd/_/R-SEBSE1118A_0248582665 You may want to consider using one of the 240SX rear caliper kits.- 17 replies
- s30 to s130
(and 1 more)
Tagged with:
Brakes have me lost...
Miles replied to Volition77's topic in Brakes, Wheels, Suspension and Chassis
When you check to see if the "reaction disk" has fallen out of place, also verify that the push rod that goes into the master cylinder is adjusted to the correct length per your Haynes or Chilton or Factory Service manual. Make sure that the reaction disk is in place first and then adjust the push rod. Do a search on push rod adjustment for the details. If you find the reaction disk glue it to the push rod to avoid it falling off the next time you have to remove the master cylinder. -
How about a Ford flathead V8. I bet nobody has done that one in a Z. Transmission: I have used Camaro T5 transmissions in two builds. The first one I got from a wrecking yard cost $400 and the second T5 was a new rebuilt for $700. The first build I used the wrecking yard T5 and a used SBC 350 engine with unknown mileage. That was 14 years ago and that car is still on the road.
280Z Turn Signal Flasher Replacement Source?
Miles replied to Phantom's topic in Ignition and Electrical
Just to be clear, you have replaced all of the lights with LEDs? -
Small block Chevy V8. It has been done thousands of times all over the world. It is a simple tried and true engine with parts available everywhere. There is even a book that tells you how to do the installation. A Goodwrench create SBC 350 with a mild cam is less than $2000 and will provide about 240 RWHP delivered to your door. It is an easy installation if you have automotive experience or have a helper who does.
I replied to your other thread. For LEDs you will need an electronic flasher because LEDs do not pull enough current to make conventional flasher work. It may come with two prongs and a black ground wire. Plug it in and attach the ground with to the car.
240z. I replied to your other thread on the same subject. If you have LEDs you will need an electronic flasher such as the one I mentioned above. Flashers are standardized such as a 552 type etc. You should be able to go to any parts store and get one. For example: http://www.oreillyauto.com/site/c/detail/LIT0/FLR536/01546.oap?year=1977&make=Nissan&model=280Z&vi=1209248&ck=Search_flasher_01546_1209248_3006&keyword=flasher&pt=01546&ppt=C0117 Is your flasher non-standard? -
I bought an electronic flasher at Oreillys. It has two prongs and a ground wire. It will work with LEDs. Also, Hotronics sells a flasher designed to work with LEDs and conventional bulbs and it has an adjustable flash rate. http://www.hotronicsproducts.com/ -
Searching for two minutes: last post page 2 http://forums.hybridz.org/topic/94717-will-not-turn-off-with-key/
Make a 1 to 2 minute video of the engine compartment with the engine running: one view from the driver's side of the engine and one from the passenger's side of the engine. Have someone raise and lower the engine speed a few times in each view. Same for a front view.
I'll take a stab at it. On one of my 240Zs an exhaust header came loose and blew out the header gasket on one cylinder. It made a mechanical sound very similar to this.
New Techno Toy Tuning Big Rear Brake Kit!
Miles replied to Turbo6.0's topic in Brakes, Wheels, Suspension and Chassis
Loy What was your rear brake set up before the TT swap and how do you compare the two? -
See videos here: http://forums.hybridz.org/topic/121812-no-power-to-headlight-fuse/
I just discovered using a syringe while bleeding a clutch master cylinder. I got the 60cc syringe from kitchen supply section of my local super market (hardware store has them also). The syringe comes with a needle that can be fitted into clear plastic tubing. For new brakes I use a Motive pressure bleeder (like a garden sprayer) initially to fill the system and have added speed bleeders to the MC and calipers to make follow-on bleeding easier. The syringe comes in handy to fill/remove fluid in the master cylinder. -
I wonder where Silvermine is getting new 15/16 master cylinders.
I agree with NewZed. Suggestions: If doing a V8 swap buy the Jags that Run (JTR) book and read it at least 5 times. Book is useful for any engine swap. Buy books/manuals for the engine and transmission you want to use. Download a Factory Service Manual (FSM) and buy a Haynes repair manual for your specific car. Download electrical schematics for your car. PDFs are easier to read than those found in books. Some are in color. Buy the book How to Restore Your Datsun Z Car by Wick Humble. It will save you hours of searching for "how to" info. Focus on searching Hybridz as 99% of questions have already been addressed. Make a detailed plan with parts list including cost before starting a project. Plan every system of the car. Start bookmarking Z car parts suppliers - there are many! Remember these are 40 year old cars and will need restoration to be safe and drivable. Join ClassicZCars.com website and search there as well. Become well informed about modifications before asking questions. People will be more inclined to answer informed questions. Have some money. I stopped counting after $12k. Read the new member FAQs. The engine swap is the easy part. It is understanding the details like brake fittings, adapters, drive shaft angles, brake system, automotive electronics, wheels, suspension and etc. that makes or breaks a build project. Recommend that you buy a running Z car and drive it stock. Do basic maintenance brakes, suspension, electrical etc. so you have a ready to drive platform when you finish the engine swap. You will learn a lot about auto mechanics and how the Z car functions as well. Useful Links: http://zhome.com/ http://www.atlanticz.../tech-tips.html http://www.classiczcars.com/index http://www.zcarparts.com/ http://www.blackdrag.../zZxCatalog.htm http://www.arizonazcar.com/
http://forums.hybridz.org/forum/81-powertrain/
You may want to exchange that 3/4 clutch MC for a 7/8 MC. The 3/4 MC has been shown to not have enough throw when used with a T5 transmission. I have used the 7/8 MC on two builds with T5 transmissions. Works good. Also, I discovered that the clutch pedal bump stop (sheet metal bracket) on the floor of my 240Z was preventing full clutch release so I removed the bracket. Currently using: Summit Racing Part Number: WIL-260-10374
