jthom5147
Everything posted by jthom5147
I have a short nose finned cover, if you’re interested. the mustache bar bolts are spaced wider and the housing bolts are slightly larger but would bolt to a long nose case.
I have a couple of extra pairs in SoCal. Pm me if you’re interested.
I have a complete turbo-back exhaust in SoCal if you’re interested. Not shipping though.
yes, some of them do. some use tunnel mounts. depends on the trans you're using and your chassis.
Modified Stock Transmission Mount for RB25 5 speed
jthom5147 replied to Jboogsthethug's topic in Nissan RB Forum
A quick way to tell: look at the shifter housing. If it is parallel to the tail shaft then it’s a 71c (commonly known as rb20 trans, but found on RB25DE). If the shifter housing slopes back toward the ground then it’s an RB25DET trans. Side by side the difference in size is obvious, in photos alone not so much. you could swap your RB bell housing onto a 240sx 5 speed from a KA car and it’ll move the shifter back.- 18 replies
- transmission
- 5 speed
(and 2 more)
Tagged with:
rb25det with rb20det tranny. speedo wont work need help !!!
jthom5147 replied to rb25detSpoolin's topic in Nissan RB Forum
someone on the dpan group found what appears to be a mechanical speedo gear for the fs5w71c trans. -
OP: you’re running an R33 cluster? The Navarra speedo gear is for a cable driven speedo gauge / cluster. No it won’t work for an electronic cluster. -
Awesome, thanks!
did you guys have to adapt the pushrod / clevis to the pedal at all?
Thanks for info!
What clutch master did you go with? if I remember correctly I’m using a 350z slave on my rb and may run into issues also.
R32 GTR Sumitomo 4 piston caliper brackets
jthom5147 replied to DakotaXPRO's topic in Brakes, Wheels, Suspension and Chassis
These the same as Z32? If yes, there was a guy offering group buy on a run of them. Uses machined Honda Odyssey rotors. pm me if that’s what you wanted and I’ll send you the contact. -
RB26dett transmission HELP! & 32 vs 33 engine
jthom5147 replied to brianZortiz's topic in Nissan RB Forum
I have an RB25DE trans if you're interested. Located in San Diego. -
see what you can glean from this. -
Your car needs work. But l would wager that the other chassis needs much more work. Do yourself a favor and do some rust clean up so it doesn't get worse, take a deep breath and then work on what you can when you can. Everything about an old car of any sort isn't cheap and you won't get your money out of it either, we do it cause we love Z's. You'll end up hating it if you're not doing it for the fun of it (like trying to make a 50 year old car your "daily" and keep it running properly). Edit: maybe I'm biased by the 5-years-ago Z prices, but even what I've looked at lately that other car is a ~$3000 or less car on my local craigslist, and I wouldn't pay more than $1500 for it. If it were a running turbo motor in the chassis, I'd pay $4
Nope. Sounds like you connected the starter wire incorrectly or your Z wiring isn’t what you thought. Double check your wiring. Use a volt meter to wire the starter wire to something that’s only hot when the key is turned to the right position.
It shouldn’t be cranking if the ignition switch isn’t in the start position. The key physically in the hole doesn’t matter, only where the key has been turned to.
RB25DET Vacuum source and Alternator wiring schematic
jthom5147 replied to Kclank's topic in Nissan RB Forum
Waste gate vacuum attaches between the turbo and the throttle body. Outside of that, location really doesn’t matter that much. Closer to the turbo is probably safer. Most internally wastegated turbos have the vacuum reference on the end of the compressor housing outlet before plumbing starts. The RB25 is no different except it first goes to a boost control solenoid. You’re supposed to connect the brake booster the bigger hole on the underside of the manifold in the center. Unless you’re not in the US, It’s BSPT, so use the nipple that came with the manifold or have it re-tapped to a common pipe thread. I retapped mine for 3/8 NPT and am using it for my megasquirt IAT; since I’m not running a brake booster. -
Vacuum source for? -
I’m having a vlsd installed in a 3.7 z31 case. The vlsd I bought was supposed to have 12mm bolts based upon what the internet says... which is always right... The 3.7 ring did have 12mm bolts. To take up some of the space, my fabricator turned some bushings to press in. There were no 12 x 13 units available on eBay, so you’re lucky with the 10x12.
I have one with an 8mm thread.
Big Phil has some stuff on his YouTube channel. essentially there is no factory RB30DE, only an RB30E (sohc). The head on an RB30D is a head from certain RB20/RB25 mated to a 30 block. There are other requirements such as running oil lines for VCT, etc. youll find a bunch more info on Aussie sites as an “RB25/30”
I’ve got a rb20 trans if you’re interested.
Looking for an S30 cross member that has been modified for a Subaru power steering rack (forester, wrx, etc)
